Question about Kenmore 98702 Stacked Washer/Dryer
How to remove front panel of washing machine
Tub is agitating but not spinning and draining water
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
There are two screws at bottom. unscrew. then lift up and out.
Posted on Nov 13, 2008
  • 943 Answers
Hi thanks for your question. could i have the make and model # please
Posted on Oct 31, 2008
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Whirlpool duet wash machine
Yes it can hopefully it won't, hope it goes thru the large drain tube and sticks in the drain screen, problems it can cause it if turns the right way it can bind the rotation of the basket during agitation or spin causing a fault code to get pin out unscrew the cap on the drain filter to remove residual water remove the heater in the plastic tub 10mm nut loosen and pull out you should be able to see the pen fish it out. Forgot drain filter behind lower front panel.
Jan 28, 2014 | Washing Machines
The washer agitates, but then will not spin so water is at the bottom of the tank
The washer will not spin if it cannot drain the water. There is a filter in the hose from the tub that leads to the pump. You can access it from the front by removing the front lower panerl. Remove the large, black rubber hose on the bottom of the tub and the filter will pull out. Water will come out, so be prepared!
Kelly
Mar 24, 2011 | Frigidaire FTF2140F Front Load Washer
Washer does not spin but water goes out. Agitation does occur during wash cycle. Belt is in place and does move when pulled. When turning the agitator the tub moves. What would need replaced?
Motor will not turn the one way...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 19, 2010 | GE Spacemaker Washer and Dryer Electric...
Washing machine wont wash screen says test.
Its a draining problem.the drain pump is either got blocked so needs cleaning or the drain pump is faulty and needs replacement. --------------------------- If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Jun 11, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
My whirlpool front loading washing machine wont drain
It won't drain If your washer won't drain, check these:
May 07, 2009 | Tecnik TKL9260 Front Load Washer
Full of water, won't drain past the agitation stage, just goes dead
May 04, 2009 | Washing Machines
Won't rinse or drain
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Apr 06, 2009 | Washing Machines
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Make noise during wash cycle, has no agitator action and no spin during spin cycle/drain cycle
Looks like the bearings may have failed. TURN OFF the POWER and try and rotate the agitator/tub by hand. If it is jammed you should investigate why. Possibly caused by bearing failure or something wound around spindle.
Take care and do not attempt to investigate the problem without first disconnecting from the mains!
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
972 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
