Question about Audio Technica Audio-Technica AT2020 Professional Microphone
Microphone gives a really boomy distorted sounds on certain chords with an acoustic guitar
I just bought the AT2020 USB mic, and I'm having a problem with getting it to record an acoustic guitar. I'm fairly new to recording (at least to good recording), and I need some help. I've tried all sorts of distances in combination with different levels of input and none of it has seemed to work. I still get a booming noise on the low end of some chords! Can I/Should I just fix this through software, like using an EQ to get rid of it? Thanks!
  • nicholaswils Oct 31, 2008
    Thanks robotek!
    That's exactly what I needed to know. But now my question is, if I use EQ, should I only lower the low end of those specific parts that are booming, or should I do the whole track? Because when I do the whole track just enough to get out the booming, I can't get it to sound full still. Do you know what I mean?
    I also experimented with the high pass filter in my software (I'm using Audacity right now), but same thing -- whenever I do it just enough to get any boominess out, it makes my track sound not quite full. Any suggestions on that? Thanks for your answer, and thanks in advance for further help!
    -- Nick
  • d87midnite Dec 19, 2008
    I'm having a slightly similar problem with the AT2020 USB, it always sounds muffled or like the treble is really low. I can fix this with an EQ, but this won't fix the problem for someone listening to my songs on their own computer, right? I'm also using Audacity
  • 1,512 Answers
Hi Nic
Thats exactly how you do it:) Some times it doesnt matter what you do, you will get strange resonances. Careful EQ is the best way to tone it down. Some guitars will present boominess on certain notes, thats just the way they are. Acoustics rely on this boominess to some degree. Good luck and happy recording. :) Happy to talk more to you about it.
regards
robotek
Posted on Oct 31, 2008
Help...my mxl v69 vac tube mic records well until the end of a song that has a sustained ending. Like it will record an open chord strum, but as the sound of the acoustic guitar starts fading away the mic...
I would see if the Phantom Power is OK.
Check with a voltmeter between pins 2 & 3 on the feed cable.
Should be around 40 Volts.
If not, check it on another mixer.
Now you know.
Peace-
Nov 27, 2011 | Marshall MXL-V69-MEDT Microphone
I just bought an audio technica at2020 cardioid condenser mic its the 20 series and i cant figure out how to get it to work on my toshiba laptop
Unlike 'Dynamic' microphones all condenser microphones require some sort of power supply to make them work. Sometimes this can be by way of an internal battery but many of them work on an external 'phantom' power supply.
I am not familiar with the exact model number you quote but AT make 2 types of AT2020 condenser microphone.
1) If your AT microphone is fitted with a USB plug then you can connect it directly to the USB socket on your computer, which will provide it with the power that it needs to make it work. The USB bus should automatically recognise the microphone and allocate an audio channel to it but you may still have to select this device as your input source in your recording program. How you do this will differ from one program to another.
2) However if the microphone is fitted with a standard jack-plug then it will not work by you just plugging it into your computer microphone input socket as this is not powered. You will need a separate 48volt DC power supply to power the microphone.
You will almost certainly also need some sort of microphone pre-amplifier to match the output voltage and impedance (electrical resistance) of the microphone to the levels required by your audio input socket on your computer.
Probably the best way to achieve both of these requirements at lowest cost would be to purchase a small audio mixer with a phantom power option such as the Phonic AM220 http://cpc.farnell.com/phonic/am220/mixing-console-am220/dp/DP29303
WARNING - most audio mixers only have one on/off switch for phantom, power - thus the power is either on or off for ALL channels. Some other devices - like radio microphones, keyboards and electric guitars may be damaged by having 48v dc current supplied to them
Here is a link to the technical specs sheet for the AT2020 http://www.audio-technica.com/cms/resource_library/literature/49f63e6efc082082/at2020_english.pdf
More information is available here http://www.dolphinmusic.co.uk/article/40-why-do-i-need-a-microphone-preamp-.html
Jan 28, 2011 | Audio Technica Audio-Technica AT2020 -...
I bought this microphone w/ sonar LE. The mic is
You can probably solve your problem by plugging your mic into a powered usb hub, then plug the hub into your computer.
Jul 01, 2010 | Samson C01U Consumer Microphone
What drivers can i download to make my at2020 usb work with windows vista
i hav just bought a at2020 mic and i tried recording bought it's not workin for my dell inspiron i forgot the model anyway it's running on windows 7 so please help me out am screwed with this ****
Mar 13, 2010 | Audio Technica Audio-Technica AT2020 -...
Recorded acoustic guitar is fuzzy and distorted
Try anouther Microphone sounds like the frequence sprecturm is to low.
Jul 09, 2009 | Samson C01U USB Condenser Microphone...
AT2020 Not showing in recording software
find the drivers online then restart your computer. hook up the mic then restart again
Feb 21, 2009 | Audio Technica Audio-Technica AT2020 -...
Problems recording with Sony Acid mucic studio 7!
This probably has to do with the levels you have set for the sound card - take a look at your mix levels AND the volume input level 0 this is not the same control as output
Sep 30, 2008 | Sony ACID Loops - Ugly Remnants: Volume...
Inputs
ok, heres what try contacting the support line on your samson mic and ask the setup if you are going to connect an acoustic guitar, there might be some info for it. actually there is here check this out
Acoustic Guitar
There are a variety of ways that the G Track can be used to mic an acoustic guitar. The
microphone placement will depend on the type of instrument and what kind of sound
you’re looking to capture, for example the tonal quality you want to focus on, and how
much finger slide or pick noise you may or may not want. When miking a standard
steel string acoustic, a good place to start is with the microphone positioned pointing
towards the end of the fingerboard at a distance of about 6 inches to 2 feet away from
the instrument. You can experiment by moving the microphone slightly in the direction
of the sound hole, which will produce more low frequencies, or move it in the direction
of the fingerboard to capture more high-end or to remove any unwanted boominess.
For nylon string acoustic, try positioning the microphone above the bridge to emphasize
more of the attack from the sound of the finger picking, or for less, move the mic closer
to the sound hole. If you have a pair of G Tracks, try one positioned at the fingerboard
and the second over the sound hole.
Jun 04, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson
try using the instrument input lets see if its going to change something.
Audio Technica Audio-Technica AT2020 Professional Microphone Logo
577 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
