Sony KP-51WS510 51 in. Rear Projection HDTV-Ready Television
Problem for Sony KP-51WS510 51 in. Rear Projection HDTV-Ready...
Color distortion and arched picture
By bob510 on Oct 31, 2008
When turned on my television has color distortion where the three colors separate and the picture on the screen is arched. please help! COLOR DISTORTED PICTURE ARCHED. I have the same problem but in a KP-51WS510 51 inch.Sony Rear Projection TV HDTV-Ready. Separate colors and image to the sides and arched picture problem
Same Problem
Feb 15, 2009
-   whem i turn on my 52' kp-51ws510 sony television i get 3 very distinct phases of color one blue one yelolo wna done the color of whatever happens to be on at the moment and they arch and i cant seem to figure out why-   wesmary02
Best Solution
posted on Nov 05, 2008
Very Helpful)
tmoore15
Rank: Apprentice
Rating: 77%, 3 votes
you have a bad or maybe 2 bad stk392-560 ic's..
and or a bad pico fuse on your g board.. (there are two of them and 6 of them under your ic's
You can check with a vom meter. (resistors) Not ic's need special meter for that
Jason
Tmoore15@indy.rr.com
Was this helpful?
Yes
No
Solution #2
posted on Feb 22, 2009
Very Helpful)
Ecollier2012
Rank: Guru  Sony Expert
Rating: 93%, 558 votes
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Sony KP-51WS510 51 in. Rear
Questions and Unsolved Problems for Sony KP-51WS510 51 in. Rear
Do you recommend Sony KP-51WS510 51 in. Rear Projection HDTV-Ready Television?
Answer
Answer
I have a Sony Model KP-51WS510 Rear Projection TV. My convergence STK need replaced the only parts... (More)
Answer
I have a sony 50 in rear projection. 9 years old the guns were calibrated 3 years ago... now there... (More)
Answer
Sony KP-51WS510 the picture is blurry, except for the center of the picture and the picture looks... (More)
Answer
my 51' sony hd television no longer has red color. why did the color red go out and how can i fix... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
