Question about Car Audio & Video
Sony XR-C350 Car Stereo - can't use cassette adapter for ipod!
Hey -
I have a Sony XR-C350 Car Stereo. The tape player is screwed up so I can't use the adapter cassette to plug in my ipod. Can I get around this problem by plugging something into the back of the stereo? I tried the Bus audio input RCA jacks on the back of the stereo, but the unit does not recognize the signal (apparently) give me the option of switch to the "CD" setting. Does something also need to be plugged into the "Bus Control In?"
Any thoughts?
Thanks -
Chris
  • JaguarDreams Nov 23, 2008
    My cassette adapter is for a normal CD player but it still won't work in the tape deck
I have a Sony car cd playerXR-c350 with a ten Cds unit,I want to know if there exist a Cd mp3 music player to use instead of the cd player, thanks.
Posted on Mar 20, 2009
    Scholar:
  • 67 Answers
For Sony radios you need an aux Bus adapter called the Sony XA 300. It works with the Bus IN RCA, and there whould also be another plug spot for the Bus power and signal interrupter. That is how the Sony knows to access that port.
Posted on Jan 30, 2009
I want to connect my ipod to the radio
According to Apple, over 90 percent of new cars retailed in the United States are equipped with iPod connectivity.
The iPod has become such a popular device, that many car stereos are now furnished with a 30-pin dock connector cable in order to link to the portable media player.
But this built-in compatibility is not essential for connecting your iPod to your car stereo. In fact, there are numerous options for integrating your iPod with your car.
Recently manufactured vehicles can support an iPod connection through an auxiliary input.
And FM transmitters can be used to stream your iPod's audio files through an FM frequency. iPods can even be connected to much older car stereos with the use of a tape adapter.
Connect an iPod to a Car Stereo Through the Auxiliary Input
Insert an extension cable with 3.5 mm stereo connectors on each end into the headphone output of your iPod. Insert the other end of the 3.5 mm stereo connector cable into your car stereo system's auxiliary input. Press the "Aux" button on your car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With an FM Transmitter Insert the FM transmitter into the 30-pin dock connector of your iPod. Turn on your iPod to activate the FM transmitter. Select the FM frequency you want your device to stream audio to on your car stereo. Turn on the car stereo and tune it to the same FM frequency as the FM transmitter attached to your iPod. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With a Cassette Adapter Plug the jack connector of the cassette adapter into the headphone output of your iPod. Insert the cassette into the car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod.
http://www.apple.com/ipod/car-integration/ http://www.pcmag.com/article2/0,2817,1865467,00.asp
Feb 10, 2013 | Apple iPod Audio Players & Recorders
Tip
How can I connect an iPod to work through a car stereo?
<p>An iPod can store hundreds of songs makes it an ideal source for music on your car. Buy an adapter is the easiest and cheapest way to connect your iPod to your car stereo system. Do you know which adapter fits you best and know how to use the first steps to expand their musical possibilities. <br /> <p><br /> <p>Tape deck <br /> <p>1. Buy an iPod adapter cassette player, if your car has a cassette player. This is one of the easiest and cheapest way to get your iPod to play music from a car radio. A cassette adapter is shaped like a tape with a wire connected to an end. <br /> <p><br /> <p>2. For a cassette adapter or a store of electronic music in good standing. This adapter is relatively easy to find and can usually be purchased for less than $ 20. <br /> <p><br /> <p>3. Slide the cassette tape in the car. Take the end of the cable and connect the headset to your iPod. Select a song to your iPod and press the "Play". Be sure to order the car stereo's cassette player. <br /> <p><br /> <p>FM Transmitter <br /> <p>1. Purchase an FM transmission adapter if your car has a cassette player. This type of adapter connects to both your iPod headphone jack or car cigarette lighter and stream music via FM radio signal. <br /> <p><br /> <p>2. In an FM adapter to send any electronics store. This adapter is a little more expensive than a cassette adapter. Make sure you have an FM transmitter instead, for many FM stations broadcast from a transmitter can only be transmitted to a unit to buy. This gives you more options when you're in certain areas where FM stations are vague or nonexistent. <br /> <p><br /> <p>3. Connect the FM transmitter for the iPod to a lighter (depending on model purchased). Turn on your car's FM radio and find a channel that is unoccupied. Adjust the transmitter to the channel number exactly the same and then to match the iPod. For example, 99.1 FM if you find a free channel in your area, the FM transmitter on 99.1 reading. Connect the iPod and press "Play." <br /> <p><br /> <p>Extra- <br /> <p>1. Purchase an additional cable if your car has an auxiliary input panel. This type of iPod adapter is one of the easiest ways for your iPod to play music in the car. <br /> <p><br /> <p>2. Find a reputable shop and buy an electronic overhead. This type of iPod adapter is usually sold for about $ 10. <br /> <p><br /> <p>3. Connect the cable to the extra auxiliary input on the dashboard of your car and plug it into the iPod headphone jack. Make sure the sound of the car is in standby mode. Select a number and press the "Play" button on the iPod to the music to start. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How do I use my iPod adapter in the SX4 Crossover
<p>The SX4 is a small car produced and designed by Japanese automaker Suzuki. There is a vehicle that comes with the option of an iPod sound, but there are numerous adapters that can be purchased and installed for this purpose. <br /> <p><br /> <p>1. Buy a cassette adapter and the SX4 has a cassette player. Place the tape in the stereo. Connect the other end of the adapter into the iPod headphone port. Press "Play" on the deck. The adapter will play on the iPod as if it were output through a stereo cassette on the SX4. <br /> <p><br /> <p>2. Purchase a wireless FM transmitter. Connect the transmitter to the iPod. Tune in the FM radio station without a SX4 to use. Tune the transmitter on the same drive, and press "Play" on the iPod. <br /> <p><br /> <p>3. Buy an auxiliary input, and installed by a professional if you do not have extensive knowledge of the years SX4 radio. Many retailers will provide free installation with purchase. The cable is connected to the auxiliary input on the stereo, and into the cockpit of the SX4. You can connect the headphones to your iPod while you listen through the speakers is the SX4. The sound is almost perfect. <br />
I need code for sony car stereo xr-m510
If you have the original remote control, you can use this website to decode the passcode for you. They charge a small fee however.
http://www.dndservices.co.uk/Sony-XR-M510-code.html
May 04, 2011 | Sony XR-M510 Cassette Player
Sony XR-C350 - cassettes get rejected
Hi I do not have a solution but my XR-C350 is having the exact same problem. I just had some repair work done on the car and the baterry had to come out. I have not reset the the system so I might try that? Any help would be greatly appreciated
Tony
Oct 10, 2009 | Sony XR-C350 CD Changer
Can get my cassette adapter for my ipod to work it keeps ejecting the cassette
I also have a '95 ford explorer. Same problem. I took the screws out of the tape and opened up the adapter. I took out all the gears EXCEPT for the one large one in the middle two on either side. Now it works perfectly.
Nov 19, 2008 | Audio Players & Recorders
Cassette player in car
Unit has a problem with loader mechanism, have serviced
Jul 31, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
TV upgrade in my Motor Home
You have to convert the coaxial digital output to non digital right left output! this is done with an adapter which you can get from EBay for $7.79 and free shipping! go to mEBay and search Toslink Digital coaxial signal to Analog converter audio adapter rca! good luck!
Jun 10, 2017 | Sony XR-CA330 Cassette Player
Car Audio & Video Logo
846 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
