Question about Sony MHC-GX8800 CD Shelf System
Stereo won't play
My power indicator light keeps blinking on and off constantly, and my stereo will not stay on.
  • guce124 Apr 30, 2009
    Red power light blinking and won't turn on
  • ladybird7277 May 23, 2009
    indicator light blinks consatntly when i turn on my stereo and will not stay on
Only use original speaker, check cable circuits..
Posted on Feb 22, 2010
I connect the acc wire to 12 volt and stereo stays on all the time
The accessory wire is suppose to be hooked up to your ignition wire and not a constant 12 volt power source. Hooking it up to your ignition wire will only give the stereo power when your key is in the accessory position or in the running position. The constant power source that you mostly connected to is meant for the memory wire on your stereo which will allows it to save your setting when you turn the vehicle off and your stereo kicks off. Otherwise you will end up setting the clock and adjusting your EQ every time you turn it on.
Feb 22, 2014 | 2004 Pontiac Sunfire
New radio in truck wont power dont when truck is off
There are two 12 volt sources from the vehicle behind the stereo, one is a constant which the stereo requires to keep the clock circuit powered, the other is a switched ignition source which is designed to supply power to the stereo when the key is turned backward from the off position and or forward, you likely connected both wires from the stereo to the constant wire. Perform a Google search to obtain a wire color diagram of your vehicle.
Dec 22, 2013 | Radio Communications
Tring to find out which color wire is for the ignition switch so i canhook up my stereo
You will want two of them, one is constant power, and can come from the battery if needed, and the other will be accessory power. It'll be the one that only gets power when your key is in and not in the "lock" position. You can actually hook both the stereo's wires to the constant power, but then you'll need to shut the stereo off manually, it won't go on and off with the car.
Oct 19, 2012 | 1995 Plymouth Neon
Rpm won't go over 4000 and will not do over 30 mph
2002 GMC Envoy Car Stereo Wiring Chart
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox or ignition switch harness for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jul 23, 2012 | 2001 Dodge Stratus
Car battery keeps dying
Myguess is that you have an electrical short which is causing a drain on the battery. The way to check this is to get a 12 v test light. Unhook the negative side of the battery. Hook the test light up between the negative battery post and the battery cable. If the light comes on, You have a short/drain. To find where the short is, you leave the test light hooked up. Then you start pulling fuses until the light goes out. However, your car stereo needs to be completely unhooked before you do this test because most stereos have a constant electrical source so that the clock stays accurate and the memory stays active so your programed stations don't get lost. GOOD LUCK> Keith Lewis-Dayton,Wa.
Jul 09, 2012 | 2000 Ford Mustang
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
Stereo plays on acc. after u start engine plays 2-3 seconds
IS THERE AN AMP? ARE YOU SURE YOU HAVE DECK/ AMP HOOKED UP TO A CONSTANT "KEY ON" POWER SOURCE? I WOULD GET A TEST LIGHT(REAL CHEAP AT WALMART, OR AUTOPARTS STORES) AND SEE IF MAIN WIRE IS NOT A TIMED KEY ON CIRCUT.... ALSO IF AMP IS BEING USED MAKE SURE ITS HOOKED TO REMOTE ON WIRE(USUALLY BLUE WIRE) AND NOT POWER ANTENNA LEAD OR SOME OTHER TEMP/TIMED POWER LEAD. GOOD LUCK
Feb 12, 2009 | Car Audio & Video
Power flashing in and out
Take your ground connection directly to metal, this is to insure you have a good ground. Stereo going in and out could be because of a shorted or miswired speaker. Disconnect all speakers and test the stereo. If the stereo continues to blink, you have a stereo problem.
Nov 10, 2008 | Sony CDX-GT100 CD Player
STEREO 2000 TOYOTA 4RUNNER
One possibility is that the light in not firmly seated in its socket inside the stereo. If you find that the blinking is worse when driving over bumpy surfaces this will help confirm that the issue is related to an intermittent electrical connection.
Jul 25, 2008 | 2000 Toyota 4Runner
Sony MHC-GX8800 CD Shelf System Logo
325 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
