Question about HP Business Desktop dc5700 - Intel Pentium Dual-Core E2140 1.6GHz - 512MB DDR2 SDRAM - 1 x 80GB - DV...
Xp or linux couldnot load in my laptop
Xp couldnot recognized the hdd and given a error on the screen.
my laptop model no is hp pavilion dv5 enterprise
tanumaydas@yahoo.co.in
Try change the HDD setting in the bios from AHCI to IDE
Posted on Jun 05, 2009
  • 61 Answers
I've successfully installed XP SP3 on a DV5Z (custom build). Here is what I did, you will need to check that your DV5Z has the same components before using these drivers.
Step 1 Create an XP boot disc
Get the AMD motherboard/SATA drivers slipstreamed into an XP SP2 installation disk. I use NLite for this from http://www.nliteos.com
Drivers are available at:
http://www.gigabyte.com.tw/Support/Motherboard/Driver_DownloadFile.aspx?FileType=Driver&FileID=3517
Other forum posts have more information on how to create the disc but I found NLite pretty easy to use. I suggest slipstreaming the SP2 patch into your installation disc.
Step 2 Install XP
Install XP from a Bootable disc you created using NLite. Get XP working and upgrade to SP2 if your installation disc wasn't already SP2.
You should see all the devices now in Device Manager in XP, but with exclamation marks.
Step 3 Get the XP drivers/software
The HP Compaq 6735s shares many components so you can get many drivers from this link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3687622&prodTypeId=321957&prodSeriesId=368762
1&swLang=8&taskId=135&swEnvOID=1093
Audio UAA bus driver sp33867 Install this before upgrading to XP SP3
HP Software update sp38874
Synaptics touchpad sp39032
Wireless assistant sp39374
Quicklaunch 6.40F1 sp39425
XP SP2 updates sp39429 I guess these will be in XP SP3
Driveguard software sp39602
Webcam driver sp39606
Driveguard driver sp39738
AMD CPU driver sp40535
AMD SATA driver sp39719
The following is on other laptop models but you can just search for it manually or use the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-62438-1&prodTypeId=321957&prodSeriesId=3687621
Audio IDT driver sp39671
Drivers from other sites:
1) Realtek Ethernet driver
http://www.realtek.com/downloads/downloadsView.aspx?Langid=1&PNid=13&PFid=5&Level=5&Conn=4&DownTypeID=3&GetDown=false
If the link doesn't work you want the PCI Express versions fromhttp://www.realtek.com
2) AMD Dual-Core Optimizer
http://www.amd.com/us-en/Processors/TechnicalResources/0,,30_182_871_14098,00.html
If the link doesn't work look around on http://www.amd.com
3) ENE CIR driver version 1.3.306
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/MSI-GX600-08-ENE-CIR-Driver-133060.shtml
I found that the 1.3.306 Vista driver works fine on XP but newer Vista drivers do not. I couldn't find an XP driver
4) Atheros Wifi AR5008 driver
http://www.atheros.cz/
5) Realtek Card Reader
http://www.realtek.com/downloads/downloadsView.aspx?Langid=1&PNid=15&PFid=25&Level=4&Conn=3&DownTypeID=3&GetDown=false
If the link doesn't work look around on http://www.realtek.com
6) ATI graphics
Get these from http://www.ati.com you need to get the Integrated chipset version if you have HD3200 graphics.
7) Realtek Audio Codec
http://www.realtek.com/downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
I installed both the ATI HDMI Audio device and the Windows XP driver, you may only need the ATI HDMI.
Step 4 Installation
Install the drivers first (after devices have been detected), then the software. You will need to force install some of the drivers by going through Device Manager but most of the drivers have installation programs. CANCEL ANY DETECT HARDWARE DIALOG BOXES TO AVOID AUTO-INSTALLING THE WRONG VERSION OF A DRIVER.
You will also need to carry out a registry fix for the wireless LED. Copied from another post:
"For the Wireless LED its a little trickier. If you can find the root directory for your wireless network adapter like Paddy MacSeamus mentioned above its pretty simple. Follow his directions until you find your Wireless Network Adapter listed next to DriverDesc. In that same directory, i.e., 0003, add these Dword values just like you did above:
New-> Dword
Value Name=gpioFunc0ActHi and Value Data=0
Click Ok.
New-> Dword
Value Name=gpioPinFunc0 and Value Data=3
You are done. These values should be seen in the same window as DriverDesc and the name of your Wireless Network Adapter. The LED will work correctly after you disable and re-enable your wireless."
After doing all this, my DV5Z works correctly except for the following:
- Mute button LED always on orange
- No on-screen display of volume/mute etc. You can use Microsoft Intellitype (use the Digital Keyboard device and download this) instead of the HP software - see other forum posts if you need more info on where to find this
- QuickPlay key doesn't work. Presumably this can be fixed by installing the QuickPlay software for another notebook eg DV6000 series but I've not tried this
One final thing - I was given incorrect SP details by an HP person on an online chat session and told to refer to manufacturer websites for other drivers. The latter is incompetent but acceptable in my view, whereas the former is clearly unacceptable (why give out incorrect details on their own drivers and pretend they're doing me a favour?).
Posted on Oct 31, 2008
Pavilion dv5 white screen
Common problem with ANY model of laptop with the specific Nvidia graphics you have.
HP Still Getting Heat on Nvidia Graphics Chips
They overheat easily, causing so many issues.
Get a new laptop. If you fix it, it will happen again. Not worth the money
Don't hate on HP's. Get any laptop with Intel graphics.. you will be fine.
Jun 14, 2014 | HP Pavilion dv5-1159se Laptop
Dear sir. my laptop hp pavilion dv5, its comming
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Aug 27, 2010 | HP Pavilion dv5000z Notebook
Where I can download drivers for HP Pavilion dv5 operating Windows XP SP3
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
www.hp.com/#Support
Jun 03, 2010 | HP Pavilion dv5-1000us Notebook PC
Boot failure self HDD test #1-7 XP PRO.
Hi this Alex You can use Ntfs for dos programm which allow you to access ntfs partions on while dos loaded. then you will be able to get you data copied
Sep 23, 2009 | HP Pavilion dv4000 Notebook
How can I install Winxp on HP pavilion DV5 laptop ?
You're Hard Drive may be dead. If XP is starting to install and then it goes to the Blue Screen of Death, that's most likely your problem. There's a slight chance that you're power inverter has a fluctuating power level that is causing a disruption, but that's very unlikely. Have you done any tests with any boot CD's to check the hard drive's function?
Jun 09, 2009 | HP Pavilion dv5110us Notebook
I am trying to downgrade my new laptop from Vista to XP it is a HP Pavilion dv5-1235dx notebook. When I run XP setup disk I get a BSOD right after it goes to load windows to begin setup. I know this is...
In your BIOS, do you have option: "Native SATA support - Enable/Disable"?
If yes, - DISABLE it.
If not, - you'll need http://downloadcenter.intel.com/license_agr.aspx?url=/17412/eng/IATA88ENU.exe&ProductID=2800&agr=Y&sType=&PrdMap=&DwnldId=17412&strOSs=All&OSFullName=All+Operating+Systems&lang=eng
put it on USB flash drive and press F6 when prompted during Windows setup.
Mar 23, 2009 | Computers & Internet
How can i install xp to hp pavilion dv5-1126em model when i try to install its come blue screen error
try with another cd this causing bcoz of faulty cd........................Sameeraryan
Jan 13, 2009 | HP Pavilion dv6000z Notebook
HP Business Desktop dc5700 - Intel Pentium Dual-Core E2140 1.6GHz - 512MB DDR2 SDRAM - 1 x 80GB - DV... Logo
657 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
