Question about Whirlpool GEW9250 Electric Dryer
Machine drys fine on timed cycles but shuts off before clothes are dry on automatic cycle.
  • beach8358 Feb 26, 2009
    My Kenmore electric dryer model 417-82142101 does the same thing. It dries fine on timed cycle, but it quit drying on auto-dry. What is the fix and is it something I can do myself?
    New Friend:
First try cleaning the moisture sensors with rubbing alcohol, these are two silver colored strips located inside the drier just below the lint cleanout
Posted on Feb 16, 2013
  • escholfie502
    escholfie502 Feb 16, 2013
    lint cleanout
  • 958 Answers
The automatic feature could be the problem. the damp sensor could be faulty. the timer would run even though the clothes are still damped. it is supposed to stop while the clothes are still wet.
tnx 4 using fixya,
drcool
Posted on Oct 31, 2008
Auto cycle does not work timed cycle works fine
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Apr 15, 2015 | Kenmore Dryers
Gas dryer does not dry in "timed Dry" setting
Mar 06, 2015 | Whirlpool LGB6300 Gas Dryer
Dryer is set to run 40 mins when it shouts off at 0 on the dryer is has only run 20 mins according to my stove timer
Dryer has a moisture sensor that detects the clothes are dry so it shuts off earlier. If the clothes are still damp then the dryer vent may be plugged and causing the unit to run hot or not able to fully evacuate the air from the machine. Clean the vent and make sure it's completely free and try again. If it short cycles again and clothes still damp you may have a sensor controller issue.
Jun 16, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
I have a whirlpool electric dryer and the automatic sensor mode is not working. In the automatic sensor mode it drys the clothes but will run forever. The timed mode works by drying the clothes and...
I wonder if maybe your wire is attached to the sensors? If it vibrated off the connection that could be the problem. Here is a video I made which shows how to connect the wire:
Oct 16, 2013 | Dryers
Kenmore gas dryer model 76812690 works perfect in timed cycle but will not advance timer and shut the dryer off in auto dry cycle. Vent is cleaned and it drys clothes but runs and does not advance timer...
Hi
I believe that everything else is fine rather it is the the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jun 28, 2011 | Dryers
DOESNT SHUT OFF AT END OF CYCLE
try timed dry to see if it does it
Apr 19, 2010 | Kenmore 63942 Dryer
Amana model LGA30AW automatic setting doesn't shut the dryer off
You can make adjustments to your Automatic Cycles by adjusting the Factory Dryness Level:
Changing the Automatic Cycle settings to increase or decrease drying time:
If all your loads on all Automatic Cycles are consistently less dry or more dry than you would like, you may change the default settings to increase or decrease the default dryness
level.
Your automatic drying settings can be adjusted to adapt to different installations, environmental conditions, or personal preference. This change is retained and will affect all of your
Automatic Cycles, not just the current cycle/load. There are 5 drying settings, which are displayed using the time display:
0 Much wetter clothes, 30% less drying time.
1 Slightly wetter clothes, 15% less drying time.
2 Factory preset dryness level.
3 Slightly drier clothes, 15% more drying time.
4 Much drier clothes, 30% more drying time.
TO CHANGE THE DRYING SETTINGS: NOTE: The settings cannot be changed while the dryer is running or paused. The dryer must be in standby mode (power is off) to adjust the default settings.
  1. Before starting a cycle, touch and hold DRYNESS for 6 seconds.
  2. Touch DRYNESS to select the dryness level shown in the time display: 0, 1, 2, 3, or 4.
  3. Touch START/PAUSE to save the new dryness level setting.
Oct 05, 2017 | Amana ALG331RAW Gas Dryer
Gas dryer wont trun off after drying
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 08, 2009 | Dryers
Drying cycle
Is the drying fan rotating(you should hear this)? Or the watertap closed. It uses cold water to make the steam into condense. If tap is closed, the machine has no water to cool the steam with. Check lint filter.
Jan 22, 2008 | Candy CNW156 Front Load Washer / Dryer
Whirlpool GEW9250 Electric Dryer Logo
605 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
