Question about Citizen ST-555 2.2 in. Television
Citizen st-555 how do i adjust the horizontal hold for the citizen st-555
I accidently locked my citizen tv and I can't access any buttons
Front Panel Lock
This feature allows you to lock the buttons on the front of the TV. Even when the front panel lock
feature is ON, the TV operates with the remote control.
• To lock the buttons on the front of the TV, make sure the TV is turned ON, then press and
hold the ON•OFF button on the remote for approximately 5 seconds.
• To turn off the front panel lock, make sure the TV is OFF, then press and hold the
ON•OFF button on the remote for approximately 5 seconds. Now the buttons will operate
properly.
http://support.ttetech.com/RCATV/Assets/pdfs/E13320_1558177E_IB_e-02.pdf A manual for a similar model if you need it. Many of the controls should work the same. Good luck and please leave feedback!
Oct 10, 2010 | RCA E13309 13-Inch Diagonal XL-100¿...
Screen rolls and jumps
look at the back of your tv and see if you have anything in relations to verticle hold or horizontal hold. it would look like a round piece with a flat to put a flat screwdriver into . this way you can adjust your screen etc.
Mar 12, 2010 | Naxa Electronics NX-503 Television
HOW CAN I INTALL ANTENNA TO WATCH MY TV
if this is a portable tv; your state might have gone digital programming which you can only receive canada stations only. but see if you have an external antenna jack then you need the adapter to use with an antenna you can find it at radio shack.
Feb 25, 2010 | Citizen ST-555 2.2 in. Television
Sanyo 13 or 14 inch TV, C 03 shows on the screen, how to remove
i can't able to oscillate the horizontal output of sanyo tv model no. ST-14se1 tho power indicator keeps on blinking only what component should i consider to replaced?
Sep 30, 2009 | Televison & Video
My citizen tv is locked and i dont have the remote to unlock it is there a way to do it manually
Hold menu button +power+volume up you will go into service mode. Scroll down to see if you can find the reset which will reset the tv to factory setting erasing the password. I never had to do this it might work.
Jun 30, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
Coby Tv Screen Wiggle and vhold makes it worse
Hi I am Vortash I gather you mean by wiggles that the picture tears sideways .. if this is correct this is called Horizontal tear .and the Vertical Hold control will not do anything to adjust this . If there is not another button for the Horizontal Hold then you will probably have a scan fault that needs to be seen to , it could be just dry joints more likely a capacitor is drying out and needs replacing on the Horiz sync circuit a common fault but if you're not electronically minded or trained will need an engineer to fix it .. regards Vortash
May 31, 2009 | Jensen 5'' Black and White Flat Screen TV...
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Locked channels and No remote for Citizen (JCTV 1592)
I pressed some key on my remote accidently and thereon i have not been able to move to any other channel except adjusting the volume in this one...pls suggest...I do not know if this got locked..
Apr 19, 2008 | Televison & Video
What are all the remote codes for the citizen tv, is there a web sight
some tv do not have code for sky remote or sky+ but will work ok but no volume control or on/off use tv remote to do this
Blank karaoke machine
Try looking on the back of the machine for vertical and or horizontal hold controls (marked V-Hold and H-Hold) and try adjusting them, especially the horizontal hold.
If that doesn't help, then the next troubleshooting step would be if the machine has a video output you could try connecting to a TV/Monitor and see if the graphics appear there.
Feb 01, 2008 | B&W 5.5" TV/CD+G Monitor Karaoke Machine...
Citizen ST-555 2.2 in. Television Logo
57 people viewed this question
Top Citizen Televison & Video Experts
Electro Med Services...
Are you a Citizen Televison and Video Expert? Answer questions, earn points and help others
