Question about HP Computers & Internet
I have an HP Pavillion 512.00 MB can I change to 2 GB and will this make my computer much faster.? does this computer automaticly back up files ?
    President:
  • 1,901 Answers
Post back with the model number of your computer to determine max RAM. If you can go from 512MB to 2 GB, it will definitely increase the speed.
And no, the computer does not automatically backup your files. You need to set it up. There is probably a backup utility in your programs. Try Start>All Programs>Accessories>System Tools.
Of course, if you do backup, you will need a drive to backup to...another HD, flash drive, or external drive.
Posted on Oct 31, 2008
  • 849 Answers
No need to backup files in case of upgrading ram
1). Have HP nx9500 with 512 MB memory 2). The screen is 1/2 size 3). Can I load Windows 7 and upgrade to 1 GB memory Hershall
To succesfully upgrade to windows
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
  • Jul 31, 2011 | HP Compaq nx9500 Notebook
    Tip
    HP Computer Support
    HP is a reckoned organization, which is dominating the IT market interms of performance and security. Various models of computers andperipherals of HP are available in the market, which are demanded forsuperior performance and high processing speed. But, even HP systemsare not resistant to technical issues and improper handling or someother reason might cause some technical issues that you can fix on yourown.
    General issues that you can face while using HP products are enlisted here:
    - Performance issue
    - Slow boot/ startup activity
    - Installation and upgradation issue
    - Online threat
    - Network setup and configuration issue
    - Driver compatibility issue
    - E-mail access issue
    - Internet not working
    Here are some of the basic steps that you follow to fix a slow running Internet
    1. First method
    Step 1. Click Start > Control Panel > Network and Internet Connections.
    Select "Internet Options."
    Step 2 . Under Check for newer versions of stored pages, click "Automatically." Under browsing history, click "Settings."
    Step 3. If you're using dial-up, set the number under Disk Space to Useto between 250 and 1024 megabytes (MB). If you're using a DSL or cableconnection, set it between 50 and 75 MB. Click "OK."
    2. Second method
    You must be familiar with cache memory, which is often called astemporary memory and stores the temporary files of the web pages thatyou have visited. These temporary files need to be deleted as theyacquire a great portion of memory and may slow down the performance ofyour computer as well the speed of your Internet connection:
    Step 1. From browsing history choose "Delete" option.
    Step 2. Click "Delete files" under Temporary Internet Files to clear your browser cache.
    Step 3. Click "Delete cookies" to remove all cookies from your hard drive.
    Now, you will get your Internet browsing much faster that’s too without any investment.
    As a knowledgeable user, you should manage your data e efficiently. Ifyou are facing any issue in your HP computer, you can call yourtechnical team who is offering tech support to your HP computer.
    on Feb 18, 2010 | Computers & Internet
    I formatted a hp personal media drive 150 gb for a mac book pro because i needed to backup all my files using time machine. after I reinstalled my files (I no longer need the back up file) I tried to use...
    Right click on "my Computer" and select "Manage" then in the box which appears select "Disk Management. See if you drive is listed in the lower pane of the disk management window. You may be prompted to initialise disk, this may solve your problem, or if the disk is showing then right click and select change drive letter or paths, in the next box select add or change then select a letter from the drop down list andclick ok. Your drive should now show in "My Computer"
    Be certain that you are changing the correct drives letter as if you change your boot drive letter you will have lots of problems.
    May 05, 2011 | HP ( 0950-4320 ) 40 GB Hard Drive
    Can i play
    Yes you can play SIMS 2 in mac;
    here's the system requirements for you to play SIMS in MAC
    Compatibility Mac
    • Mac OS X v.10.3.8 or later
    • 256 MB RAM
    • Mac PowerPC G4 or faster
    • 1.25 GHz or faster
    • 3 GB free hard drive space
    • DVD-ROM drive
    • 32 MB VRAM
    • ATI Radeon 9000, NVIDIA GeForce FX5200 or better graphics processor
    Dec 31, 2010 | Sims 2 for Mac
    Upgrades for hp pavillion 533 such memory
    This is everything I could find on your computer.
    Base processor and speed Celeron 2.0 GHz
    • 400 MHz Front side
    • Socket mPGA478
    Back to top Chipset 845GL Back to top Motherboard manufacturer
    • Manufacturer for computer serial numbers starting with KR and CH: Trigem Glendale
    • Motherboard for computer serial numbers starting with MX: ASUS IT8708F NOTE: The serial number can be found printed on the back of the HP Pavilion computer, or while holding down the Ctrl and Altkeyboardkeys, press S. A screen will pop up with the serial number.
    Back to top Memory Component Attributes RAM (installed)
    Allocated to Video 256 / 2100 DDR
    Up to 64MB Maximum allowed 1 GB (requires replacement of the installed 256 DIMM) Speed supported PC2100 / PC1600 Type DDR SDRAM DIMM slots Two Open slots One Back to top Hard drive 60GB Ultra DMA Back to top DVD-ROM/CD-RW combo drive 16x/8x/8x/40x maximum speed Back to top Diskette drive 1.44 MB (3.5-inch) Back to top Fax and data modem Cheetah 2 V.92 Modem Back to top Video graphics Integrated Intel Extreme Graphics with up to 64MB shared memory Back to top Sound/audio Integrated AC97 audio Back to top USB specification USB 2.0 Back to top Network Integrated on motherboard: 10/100Base-T LAN interface
    Dec 26, 2009 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
    What is the ram limit of HP Pavilion 061 DW234A-ABA A530N I have two sticks of kingston 512 in it right now but want to put in two sticks of 1 GB each. Can I? Nvidia 7800 GS OC with 500 watt power supply,...
    From the HP specifications page for Pavillion A530N:
    Memory type DDR Memory speed PC 3200/2700/2100/1600 Memory sockets Two DDR DIMMs (184-pin) Maximum HP/Compaq approved memory Two x 512 MB DDR-DIMMS, 1024 MB total (1 GB)
    Mar 10, 2009 | ASUS Computers & Internet
    Wanting to upgrade the memory on a hp pavillion a6220a
    Standard Memory:
    256 MB or 512 MB or 1 GB (Removable)
    Maximum Memory: 2 GB Memory Expansion: 2 Sockets
    256MB Memory (PC2-5300) 396519-001, PX974AA, PX974AT KHEW974
    512MB Module (PC2-5300) 396520-001, EK477-69001, PX975AA, PX975AT KHEW975
    1GB Module (PC2-5300) 398038-001, PX976AA, PX976AT KHEW976
    You can upgrade your system to 2GB MAX
    Your memory type is PC2-5300
    Please be sure to get the right memory (above listed)
    Have a great day
    Pablo :-)
    Let me know if you have some questions about this issue...
    Oct 22, 2008 | HP Computers & Internet
    Computers shut down randomly while students are working on them. Red light blinks on the front of the CPU. The computers have Deep Freeze and Synchron Eyes on them as well.
    Open the PC box. Check the CPU heatsink/fan for dust clogs. After that is cleaned, put a little fan blowing onto the mobo. An over heating processor acts just like this. If the BIOS were changed try to scale back a little, first. Just see if the venting solves its prob. Wont cost you anything, and it wont hurt....
    Nov 14, 2007 | HP Compaq dc5100 PC Desktop
    Computers & Internet Logo
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
