Question about GPS
I just got this Navigation Device TRAX350 GPS do i need a sd memory card for it work or just to down load
  • motherchook6 Feb 21, 2009
    I got a Trax350 and it just keeps shutting down. It comes up Warning: The application failed to start last time. Do you want to reset to factory defaults and lose all your POIs, tracks and settings? YES NO. It doesn't matter which you choose, it just shutsdown. Has never worked. Do I just send it back.. groan.
I have a TRAX350 and it worked straight out of the box just fine. No SD memory card required for basic operation.
Posted on Dec 28, 2008
My problem is keep ask me insert the memory card or insert sd card
Inserting a memory card
The SD memory card contains maps and navigation software. It also stores saved
destinations, routes, and logbook entries.
• Insert the memory card provided into the slot on the side of the device. Press the
card into the device until it locks into place.
If you don't have the card that came with it, you can buy one. It takes a standard "SD Card" (compatible with MMC/SD) I believe the original card was only 64Mb, which you should be able to find on eBay for $1.
Here is a complete manual for your unit: http://support.navigonusa.com/_pdf/manual/Manual_2100_2120_English.pdf
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this answer. Happy holidays!
Dec 05, 2010 | Navigon 2120 GPS Receiver
Tip
Motonav TN20 Firmware Fix
Motorola Motonav TN20 Firmware Fix
Does you Motorola Motonav TN20 GPS lock up, freeze, or not load properly anymore? Replacing the system software / firmware of your Motorola Motonav TN20 GPS will fix these and other symptoms of corrupted firmware.
Follow these steps to fix the firmware / system software of your Motorola Motonav TN20:
  1. Start by downloading the Motorola Motonav system software from Motorola from here.
  2. Extract the files onto an SD memory card.
  3. Make sure your Motorola Motonav is fully charged.
  4. Turn your Motorola Motonav off by holding the power button for at least 8 seconds, until the charging LED indicator blinks.
  5. Insert the SD memory card
  6. Turn your Motorola Motonav on. The software upgrade will begin automatically. Select “Yes to All” if prompted.
  7. The full upgrade process can take up to 15 minutes.
  8. When the software upgrade is complete, your Motorola Motonav will
  9. automatically load either the Map screen, Warning screen, or the Language Settings screen, depending on the state and configuration of your device.
  10. Remove the SD memory card from your Motorola Motonav navigation device.
The software upgrade procedure is now complete. Your Motorola Motonav is as good as new again.
I hope that helps.
_______________________________________________
Motorola Motonav TN20 Manual Download
Motonav TN20 Upgrade Manual
Motonav TN20 Firmware Download
on May 04, 2010 | GPS
Tip
Motonav TN30 Firmware Fix
Motorola Motonav TN30 Firmware Fix
Does you Motorola Motonav TN30 GPS lock up, freeze, or not load properly anymore? Replacing the system software / firmware of your Motorola Motonav TN30 GPS will fix these and other symptoms of corrupted firmware.
Follow these steps to fix the firmware / system software of your Motorola Motonav TN30:
I hope that helps.
Motorola Motonav TN30 Manual Download
Motonav TN30 Upgrade Manual
Motonav TN30 Firmware Download
I need maps for my Trax350 for UK - where do I buy and how do I upload to the device? I am in NZ
Hi Paul61101 more specifically, you can order maps for the UK HERE, but its rather salty...179.95 ...thats a direct link to the page for you to order the UK maps..
you should get a SD card and a CD, put the cd in your computer and it will auto run, then follow the instructions, but mainly you should just be able to stick in the sd card and reboot it, then change the region to the uk
if you need a copy of your manual, you can download a copy HERE for your trax350
let me know if you need more help
bill
Mar 07, 2010 | Uniden TRAX350 Car GPS Receiver
Hi, I mistakenly formatted my SD card for my Next Nav N35 incar navigation device. I am wanting to know where I can buy another SD card fully loaded with Australian maps or a backup CD for same, May...
http://www.buckscoop.com.au/forums/deals-bargains-coupons-vouchers-cashback/2520-expired-nextnav-n35-gps-satellite-navigation-system-289-5-off-coupon-4-4-cashback.html
Dec 04, 2009 | GPS
Tip
I hope that helps.
on May 04, 2010 | Motorola Mobility MOTONAV TN20 GPS...
Tip
I hope that helps.
on May 04, 2010 | Motorola Mobility Motonav TN30 Car GPS...
I have an A2265FF all in one navigation unit in my ford focus, the SD card had route 66 installed on the card which I updated and since then I have lost the files for loading the navigation, I have...
I can understand your problem, this problem arises with new SD card.
So, please copy Navione folder to memory card root directory, enter the directory, use Notepad to open Loader.ini to edit, enter your correct path, for example: \ Storage Card \ NaviOne \ NaviOne.exe save you, run to enter Loader.exe navigation procedures.
I'm sure it will work out for you. The error message shows similar indication. So, do it and load your route installed. It will work out surely.
With Regards,
Shyny
Apr 22, 2009 | GPS
Not enough memory and shut down
I'm really only giving an educated guess but as a technician with 26 years experience I suspect that either you have a faulty memory chip or the firmware which runs under Microsoft operating system may be corrupted. My Trax 350 works like a charm doing exactly what you have done WITHOUT a memory card.
Try push RESET which is at the bottom next to the SD card slot with a paper clip. If that doesn't work I suggest taking it back under warranty.
BTW, I ended up "pinching" the useless 32 MB SD card ( too small so I replaced it with 2GB ) that came with the camera I bought my son. More than enough size for me and my son couldn't care less!
Dec 29, 2008 | Uniden TRAX350 Car GPS Receiver
SD Memory Card Software For NVX200
please i need help my memory card got stolen and my gps is not working and all i need is the software because i have bought another memory card so please text back its a jensen nvx200 audiovox navigation and was online for hrs. looking for the softeare so please text back
Oct 13, 2008 | GPS
GPS Logo
64 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
