Question about Dell E151FP 15" Flat Panel LCD Monitor
151FPb My monitor sometimes works correctly than after a few minutes displays all white screen. Is the fixable and how?
One of my customers had the same problem. So last night, I took it apart and found a cold solder connection on a coil that had white goop on it. Goop is usually put on coils to stop oscillations. This is probably an inherrant problem. If you tap the back of the monitor with the back of a screwdrive, it should start working for awhile. Take it apart and take the shield off and do the same till you find the loose component. Don't hit it too hard. When you find the loose component. If you move the component back and and forth, it should work and not work. Take the board off and re-solder the component. Put the board back on and tap it lightly and see if you got the right component. If not repeat the proceedure until it works or pitch it...
Posted on Dec 17, 2006
I have the same problem too with exactly the same model of Dell Monitor. Looks like a problem with this model.
Posted on Jun 14, 2007
Display jumping vertically
I had same problem.
Narrowed it down to C637 on logic board.
Replace C637 or logic board.
Sep 21, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Screen goes pink and green starting with a few pixels
Best thing to do, try a different known working monitor to hook up to the computer. If the screen works and doesn't change colors then you know its the original monitor that is bad.
If you hook up the known working monitor and the same problem happens then you know its the video card that is bad and the video card would have to be replaced.
Aug 23, 2009 | ASUS VW222U Monitor
Screen goes blank (white), sometimes screen display will get big
You can update graphics driver, if that does not fix the issue check the display on external monitor. If the external monitor works fine you can isolate checking the display in BIOS Setup scree (Restart your computer and keep tapping F10 to getinto BIOS). If the same issue in BIOS, you may have to change display of the unit.
Jun 26, 2009 | HP Pavilion TX1320US Tablet PC
Screen has turned white no display
my screen is not appearing it started last four moths after some few minutes the time comes and when any of the key pad is pushed sudden it will vanish and the screen turns white.
Jun 08, 2009 | Sony Ericsson K750
Mw22u monitor has white screen.
Manufacturer out of business. Local repair shops want more $ to fix than the cost of a new one.
Solution --- Trash old and replace with new display.
Mar 25, 2009 | X2Gen MW22U Monitor
Lcm-17v8 monitor
This is a problem with the cable that runs from your laptop to the monitor.
Or the VGA Output socket, on your laptop itself.
1:) Try using the monitor, on a different PC Or Laptop.
2:) Toggle The LCD/VGA Button on the laptop. ( This should change the display Mode )
Sometimes you Have A fn key, on the keyboard. Press fn And LCD/VGA.
3:) Check that there is no damage to the cable from laptop to Monitor.
If none of the above work, it,ll be the monitor itself. faulty panel or invertor board.
Mike @ Compurepair.
Sep 15, 2008 | Computers & Internet
Faulty LCD Monitor ?
off hand it sounds like a power supply issue. sometimes fixable sometimes not.
Robert
Aug 26, 2008 | Scanport Computers & Internet
Inspiron 8500 - Display issue
with the external monitor attached press <FN><F8> to toggle between internal and external display. if still nothing then it sounds like the video card.
MANUAL
Check all the connections (especially the ground screws) that was a problem with one I worked on last year.
May 29, 2008 | Dell Inspiron 8500 Notebook
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Dell E151FP 15" Flat Panel LCD Monitor Logo
208 people viewed this question
Clive
Clive
Alun Cox
