Question about Philips MMS 203 Computer Speakers
Philips MMS 203 2 Speakers remote pin out
I need help with the remote on this product
i need the find what the pin on the connector connect to inside the cable
you can email me at ggcooler4u@yahoo.com
  • matinpiker Dec 01, 2008
    I have the Philips MMS 203/17 Multimedia Speakers System
    I have the Philips MMS 203/17 Multimedia Speakers System but it does not work
  • 258 Answers
SOURCE: connection to tv
Yes you need an adapter see
http://www.maplin.co.uk/Search.aspx?criteria=scart%20adapter&source=15
#But you may also need an AMP
Posted on Jan 13, 2009
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
  • 6 Answers
SOURCE: I NEED A USB ADAPTER FOR A PHILIPS MMS 321 Computer Speakers
This post is very old but will answer it anyway. the Round 10 pin plug you were talking about goes to the powersupply that came with the speakers.the one speaker plugs into the other speaker and the double ended cord plugs into your Pc sound out and the other end goes to line in on the powersupply.
Posted on May 16, 2010
gopakumarg43
  • 74858 Answers
SOURCE: I NEED A MANUAL FOR PHILIPS MMS 321 SPEAKERS
Hello
Try these links to download the user manual.
http://www.retrevo.com/support/Philips-MMS321-Speakers-manual/id/448ci076/t/2/
http://www.dataentryjobs.us/67948.html
http://www.manualowl.com/p/Phillips/MMS321/Manual/94342
If you feel any difficulty in downloadnt the manual, inform me by Fixya comment. I'll send a copy of the manual to you by return mail.
Posted on Mar 14, 2012
proton77
  • 1183 Answers
SOURCE: I'M TRYING TO CONNECT MY MMS 321 PHILIPS COMPUTER SPEAKERS TO MY 32 in LG TV CAN YOU HELP ?
Hi Richard,
Connecting the speakers tot he LG Tv is fairly simple.. Connect the audio cable from the speakers to the headphone jack on the TV. The headphone jack will be either on the left or right side of your TV depending upon the model number.
I'm attaching the user manual for the speakers for your reference
Thanks for using Fixya
Proton
Posted on Mar 15, 2012
Philips mms 5.500i
My philips mms 5.500i remote is damage pls tell me how & where we buy new remote
Sep 13, 2013 | Audio Players & Recorders
Need help with a VGA cord
I dont know, but I do know it is a proprietary cord, it is meant to work only with that model of unit
Jul 28, 2013 | Audio Players & Recorders
Screw driver type for Phillips MMS 203/17
Its called a torks (spelling not correct) and usually a #10 or smaller, you can buy a set of 5 or more for under 20 dollars at home depot and most hardware stores sell the larger ones---
A set of the smaller ones is handy for a lot of things including cell phones and devices that are small----Philips started all this, going from conventional to torks----Had several Philips Plasma sets with over 50 to remove to just take the cover off.
Dec 13, 2012 | Philips MMS 203 Computer Speakers
Hi Richard,
Proton
Mar 13, 2012 | Philips MMS 321 Computer Speakers
Hey ,,i bought new philips dsp 2500 mms system. but i cant connect it to my led tv.,becoz the speaker system has 3 input slots(hp stereo slots) n my led is havin only one output slot(stereo slot).....n...
audio out from the TV into the audio in/ Aux on the HTS2500.
Back connectors a AC MAINS~
Connects to the power supply.
b SPEAKERS
Connects to the supplied speakers and subwoofer c AUDIO IN-AUX
Connects to the analog audio output on the
TV or an analog device.
here's the link for the manual:
http://download.p4c.philips.com/files/h/hts2500_94/hts2500_94_dfu_aen.pdf
I hope this helps.
Sep 12, 2011 | Philips Audio Players & Recorders
I have the philips 2.3/mms203. Sound is only coming out of 1 speaker. If I wiggle the line in wire, I can get sound out of the 2 remotes, but not the subwoofer. Any thoughts on how to correct. Thank you
In most cases when you "wiggle" the jack plug and there is a difference in sound output, the problem is going to be with the jack itself on the soundcard, whether it is integrated in the motherboard or on an expansion slot....there is a small falt tension spring inside the jack itself and overtime, this spring weakens and can no longer hold proper tension on the plug. The only solution is to either desolder the jack and remove it from the motherboard or card, or just buy another inexpensive sound card and install it into a free expansion slot. I do not think it has anything to do with the speakers themselves.
Aug 25, 2010 | Philips MMS 203 Computer Speakers
I would like a wiring diagram inorder to connect inside to the 5.1 connection as there is no cable available
I know this is coming awfully late for the original poster, but for the sake of others in the same situation here's the pin diagram for the Phillips 9-pin connector. (See the image in the comments section)
And for those interested also the receiver data cable pinout.
Nov 10, 2009 | Philips A5.600 Computer Speakers
Sep 14, 2009 | Philips MMS 321 Computer Speakers
No sound from my speakers
Have a look under Device Manager if you can see the sound card installed fine . ( Control Panel - system - hardware - device manager ) . Look under sound, video and game controllers .. They shud not have a " ! " , "?" or a ' X ' next to them.
If they do , you would have to reinstall their drivers. Hope this helps
- Ranjit
ranjit@supportminds.com
Nov 27, 2007 | Philips MMS 203 Computer Speakers
Philips MMS 203 Computer Speakers Logo
591 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
