Question about Bass Pro STC-TGL2M Digital Camera
Stc tgl2m does not work with sd card
I have the stc tgl2m camera it works fine with out the sd card but when you insert the card it will not do nothing at all. It is like the power is still off.I have tried the lexar528mb, san disk128mb,kodak512mb and the panasonic 128mb and thay all have the same problem
Tried this but loc still on
It is probably caused by a defective SD card or dirty contacts for the card. There is also a "LOCK" switch on the side of the card, Be sure it is in the unlocked position. I have two of these cameras and use a couple of PNY SD cards. One camera with one of the cards gives me the LOC code after taking one picture. The other camera works well with both cards.
Mar 01, 2014 | Stealth Cam The Unit 8.0 Megapixel...
I changed the batteries in my stc-tgl2m, re-set my time/date info and everything seemed fine. When I came back the next day it hadn't taken any pictures and I noticed the time/date had not changed. I shut...
Look for corrosion on the terminals that the batteries connect to. Make sure these are shiny. It sounds like you are not getting the right voltage. With a camera that old the contacts may have gotten some battery acid on them at some point.
Nov 20, 2013 | Stealth Cam Wildview Game Camera -...
When i turn on my camera it says Meomory card unusable insert new memory card
Try formating the memory card using the camera's Menu - select format memory card.
Feb 27, 2013 | Kodak EasyShare Z710 Digital Camera
I cannot insert my Transcend SD 2 GB memory card in the camera. Is there only 1 type of memory card that can be inserted?
Make sure there's nothing in the slot, and you've got the card oriented properly. The i1237 works with SD and SDHC cards. The Transcend 2GB SD card should work fine.
Jul 20, 2011 | Polaroid i1237 Digital Camera
I have a samsung digmax s600 i works fine without the sd card inserted but when i insert the sd card the camara wont turn on
Be sure you have a standard SD card to put into this camera, not a SDHC type.
You will be limited to a maximum of 2GB with SD, but it should work perfectly.
If not, check the SD card in a notebook or PC's cardreader and/or replace the
SD card with another one. If this does not work the SD card interface in the
camera may be defective.
Jun 09, 2011 | Samsung Digimax S600 Digital Camera
My Fuji digital camera model Finepix Z20 is showing a protected card message when I insert both my old SD card and my new SD card. My old SD card was working fine yesterday but now it says protected c
Good day,
This is a common problem that many people experience with their SD Cards.
It is normally an easy fix and you can follow a method that I posted on my tips here:
Please feel free to let me know if this was helpful!
May 06, 2009 | Fuji Finepix Z20fd Digital Camera
SD card - camera won't work
What SD Card are you using?
Need to make sure it is compatible with the camera.
Let me know and we will go from there.
Mar 27, 2008 | Vivitar ViviCam 3815 Digital Camera
Insert memory card, LCD turns lank
Hello Rach326, try with a new SD card. If it does not help contact the nearest authorized dealer/service. Best regards, Arpad
Jan 12, 2007 | SeaLife Reefmaster DC310 Digital Camera
Bass Pro STC-TGL2M Digital Camera Logo
74 people viewed this question
Top Bass Pro Cameras Experts
Are you a Bass Pro Camera Expert? Answer questions, earn points and help others
