Question about Hoover 24 in. HD96M Free-standing Dishwasher
Dishwasher tripping fuse box
When I try to use the machine, it trips the RCD circuit breaker in my fuse box. The only exception is the short rinse cycle which works fine. Any ideas?
  • 258 Answers
Has the door got any heavier, as mine started tripping the electrics when a spring broke and short circuited the connections.
f so you will have to get the spring out, from the underneath is best and replace it if you want the door to work correctly again. On mine the second one went a month later.
Posted on Jan 18, 2009
Bosch diswasher,model Sms68m02AU trips circuit breaker
rcd units trip from the milliamps that are in a short
it trips the rcd to prevent electrocution and acts in nano seconds besides being a circuit breaker for excessive current
the trip can be from moisture allowing a current leakage to ground or some other simple operation
I suggest that you get in a qualified electrician / bosch service technician to find the reason for the problem rcd
Sep 15, 2016 | Bosch Dishwashers
As soon as i plug it in the circuit breaker trips.
You have a short. It is either short to ground or short circuiting. Check the cord very carefully for breaks. Make sure the ground plug is in tacked. Also try a different outlet to make sure the problem is the tool.
Mar 13, 2016 | Dewalt Dw303m Reciprocating Saws
How to I locate the fuse
Hi Sharon
I might be mistaken....but
Washing machines don't use a local fuse or circuit breaker!
The fuse (or circuit breaker) is usually in your meter box.
Washing machines can often trip the safety RCD device also.
If your country uses them it will also be in the meter or distribution box.
Circuit breakers & RCD's are easily Reset!
Cheers
Sep 18, 2015 | Kitchen Ranges
Machine displaying general alarm the infuser slide was very tight freed up and reassembled now turning the machine on results in an arc at the motor brushes which blows the RCD breaker.
Hi Chris
Good Job freeing it all up etc. Your 90% there
Can you remove brushes & clean and stretch a millimetre more out of brush leads to stop arcing. Or perhaps the load is to great.
I did notice you said RCD.
RCD's usually only trip when an in-balance occurs between the hot phase wire & neutral wires.
Eg... what goes in via phase wire must come out on neutral wire. Even a small millivolt trickle to ground will trip an RCD. (20-30ma)
The Residual Current Device is for electric shock Safety.
It is not the main fuse or circuit breaker.
RCD's can be a real pain when there is a slight moisture leak.
For Example.
My fridge in my Winnebago would trip the RCD after it hadn't been used for awhile. The insulation around the 10A heating element was damp & tripping the RCD continually.
So how do I bypass the RCD to heat the element up and get rid of moisture. My method was to use a stand alone generator with no RCD to power the RV.
Worked great. Once the element surroundings were dry it ran fine on the home 240vAC.
So... If you really are tripping the RCD then the problem is AC "LEAKING" to Earth. Usually Moisture.....Try a hair dryer
If it is really blowing a Fuse or Circuit Breaker then the problem is too much current being drawn in circuit.
Hope this Helps
Trevor
Apr 07, 2015 | DeLonghi Prima Donna Avante ESAM6700...
Tv when plugged in trips main fuse box
If there is a short circuit inside the TV, the fuse should normally blow first before tripping your breaker. The only exception is if you have a short in the ac cord or the line filter of the TV set. Have you tried the tv on another circuit to see if it trips that breaker? If not, it could be that your first circuit is close to an overload and the TV is simply pushing the circuit "over the edge".
Sep 02, 2012 | Televison & Video
I have a Bosch Classixx slimline dishwasher. I completes most of the cylcle but trips out the electricsnear the end of the cycle - probably the drying cycle - any ideas Garry
Hello Garry,
I suspect the element in the water heater is either burning out or shorting to earth. If it's burning out, the increased resistance will cause an overload and trip the breaker or blow the fuse for that circuit. If it's shorting to earth, it may trip both the breaker and the RCD in your fuse box / consumer unit.
Next time it happens, check whether the RCD switch (assuming you have one) is in the 'OFF' position. Most breaker boxes will be fitted with an RCD which protects many, or all, of the individual circuits. It's easily identified by the presence of a 'TEST' button.
That's only going to be a clue to the likely cause of the fault though. You really need to do some testing of the element with an ammeter and/or multi-meter, if you have one. I can provide instructions for testing if you have the equipment and inclination.
Unfortunately, if it is the water heater, the cost of a replacement is about £100 for the part alone, for the SGS43C12. Water heaters for most other Bosch models are roughly the same price and some of the older models can be £130+. If you need to get someone in to fit it, you could be looking at a total bill of between £150-200. Considering the age of the SGS43C12 / Classixx, it may be time to consider replacing the dishwasher.
Obviously, I'm assuming it's the water heater as this is the most likely cause, but there are other possible faults. If you need any instructions on testing, etc, please confirm the correct model number as the SGS43C12 isn't a slimline model.
Hope this helps. Please let me know if I can be of further assistance.
Regards,
BElectric
Oct 17, 2011 | Bosch 24 in. SGS43C12 Classixx...
Hotpoint Aquarius SDW60 is tripping the mains power
is the circuit protected by an rcd/rcbo or a standard mcb as this may be a neutral to earth fault/insulation breaking down...try and get the machine portable appliance tested
Sep 05, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Faulty Diplomat Dishwasher - tripping mains fuse
My dishwasher a diplomat 12 program (hja8640) was doing exactly the same where every now and again when turned on at the plug it would trip. After engineers coming out several times and failing to fix it, they condemed it. New one was supplied, however did exactly the same thing. The electrician came back, checked the RCD power breaker and this was fine. It was then discovered that some dishwashers and washing machines send out a lot of earth leakage, combine this with other appliances on in the house can be enough to trip.
Soloution. The electrician removed the kitchen circut from the RCD breaker and intalled another breaker RCD just for the kitcehn loop, this therefore means that the kitchen has a seperate trip from the rest of the house, and touch wood, has solved the problem. This mind you has taken about three months to work out so i hope it saves you some time.
Always use a fully qualified electrician though.
Thanks.
Oct 21, 2008 | Dishwashers
SMEG DWI410 TRIPS CIRCUIT LATE IN WASHING CYCLE
just possibly
take the kick panel off. On some smeg, there is a small suppressor capacitor on the lhs tucked in the wiring. this breaks down. snip it off - no need to replace
Jul 18, 2008 | Smeg 18 in. DWI410 Built-in Dishwasher
Dishwasher tripping the circuit breaker
Andy, leave the breaker off and remove the toe panel (bottom panel) from the dishwasher. Remove the cover of the junction box where the cord connection or wiring is made. Look at the wire caps and see if they are not burnt. Sometimes these connections become loose and arch, tripping the breaker. If so, cut the wires, strip a new end and reconnect. Catriver...post back.
Aug 21, 2006 | Hotpoint 23 in. BF50 Built-in Dishwasher
Hoover 24 in. HD96M Free-standing Dishwasher Logo
677 people viewed this question
Top Hoover Dishwashers Experts
Jose Pino
Philip Postlethwaite
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
