Question about Lexmark Office Equipment & Supplies
Printer cover open....error...
I think something is broken inside because I changed the ink cartridge and closed the printer...and it won't even print the alignment page for a new cartridge. it says....printer cover open..
what can i do?
my email is dkathy@netzero.com
  • 849 Answers
Find the cover switch, must be lever is broken or switch gone bad.
Posted on Oct 31, 2008
When opening my printer to get to the cartridges, they are stuck inside the printer and won't move. The on/off button is flashing.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 26, 2011 | Lexmark Z2320 InkJet Printer
How do I change the ink cartridges on a lexmark 5495
Please follow the steps below on how to replace ink cartridge on the Lexmark X5495 printer:
  1. Make sure the printer is on.
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier latch to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
I changed my ink but it wont let me print it keeps saying i need to change my ink why?
What is the version of your ink cartridge? It could be that it's not seated properly in the cartridge carrier. Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power outlet in the wall to reset it. When the printer turns on, open the printer cover and reinsert one cartridge first. Close the cover. If no error, open the printer cover and reinsert the other cartridge. Replace whichever cartridge is causing the error to appear. You could also try to insert a different known working cartridge to determine if the other is faulty.
May 19, 2011 | Lexmark Z2300 InkJet Printer
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
May 15, 2011 | Lexmark X4650 InkJet Printer
Just need to know how to put in black ink in the z1300
Follow these steps on how to install the cartridge: 1. Make sure the printer is on. 2. Lift the access cover. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. 3. Press down on the left cartridge carrier lever to raise the cartridge carrier lid. 4. Remove the used print cartridge(if you are replacing). Insert the new black cartridge in the left carrier. 5. Snap the lid closed.
3. Remove the used cartridge.
4. Load the new black cartridge. Close the cover.
Apr 29, 2011 | Lexmark Z1300 InkJet Photo Printer
Do not know how to change ink cartridge x2650
Lift the scanner unit, and then press down on the cartridge carrier latch to raise the cartridge carrier lid. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Remove the used print cartridge. Insert your new cartridges.
Apr 28, 2011 | Lexmark C533DN InkJet Printer
How do i change my ink cartridges in my kexmark x3650
Turn the printer on.
Lift the lid that covers the print-head mechanism.
In a few seconds, the print-head will slide to a position from where you can "unlock" and then remove an ink-cartridge.
Apr 10, 2011 | Lexmark X3650 Printer
How to change printing cartridges
Here's how to change your cartridges: 1 Make sure the printer is on. 2 Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. printmastert_25.jpg
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid. printmastert_26.jpg
4 Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
You may also refer to this link: How to Set Up the Lexmark X3600 or X4600 Series All-In-One
Apr 04, 2011 | Lexmark X3650 Printer
Hey,I am a big problem.When I want to print...something, I can't print because I have an error. Look here what "the printer" sais:"An ink cartridge is not installed properly.Open the...
this like your cartridge has problem with connection
open printer cover/door
then disconnect your printer cartridge, both the color and black, then connect the cartridge again
close the printer cover/door
try to print again, if message still appear, it mean you need to change your cartridge with new one
Mar 17, 2011 | Canon PIXMA iP1300 Printer
53 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
