Question about Canon MX300 Office All-In-One Printer
Faded colors with brand new printer
We just baught and set up our printer. When I tried to print a colorful page, the colors where seriously faded. No streaks, or missing colors, just very faded looking. We tried to change the intensity to darker, with no results at all. When we did a straight copy the colors where better, normal looking, but the scanner didn't seem to pick up on backgroud colors very well. I changed the intensity again to all the way dark and it was better but still not very good.
  • 3 more comments
  • Morley1 Nov 01, 2008
    Yeah - brand new printer and everything is printing out like it's at 50% intensity no matter what settings I use. But copying or word document with only black ink ok.
    Slightly better when I use high quality photo paper but on plain paper looks like pale version of my colourful artwork.
  • j726m9302 Nov 05, 2008
    What I was told to do was change the paper setting from plain to matte. This worked great for me, and no more issues with faded colors
    What I was told to do by canan support, was to change the setting from plain paper to matte. This worked great and we have no more problems with faded colors.
  • Stormi_e Nov 26, 2008
    Isn't this "solution" using the hell out of your ink? It saturates the paper with ink using matte setting. I thought this was just a faulty unit, but it seems canon isn't as great as I thought. I'm taking it back and buying the Lexmark. Ink is more expensive than the damn printer to keep using the matte setting.
  • dovecut Dec 07, 2008
    Where are refilled cartridges available for this printer at a cheap price?
  • 849 Answers
Cartridge must be expired
Posted on Oct 31, 2008
Why is my printer not printing the right color? its very faded
Is your printer set to Economode in the printer settings? It may be and so its printing at low quality.
Jul 16, 2014 | Xerox Phaser 7400DN Laser Printer
Color is offset and blurred. There is no problem printing in black. Printing test page shows the same symptoms.
Hello
The color of HP LJ 2600n fades due to following reasons
1. the color cartridge near to empty 2. due to dust on reflection mirrors inside the printer
if the color cartridges are OK, then you need help of HP technician support, because cleaning of mirrors is very technical in nature for 2600n.
Dusty Environments can lead to Laser Scanner Contamination. The dust layer on the mirrors prevents proper transmission of the laser output in the imaging system leading to faded colors on the printed page. The initial stages of this failure typically occur in the magenta or yellow color planes as faded or light color. Often the left side is more faded than the middle.
You may need to contact the nearest Authorized Service Tech and get teh Laser Scanner replaced with the new released service part that has a mirror in a location where the dust ideally cannot reach easily.
Also, please ensure that the printer is relocated from the current location to a more dust free zone.
Hope this helps, if so do rate the solution
Jan 08, 2011 | HP Color LaserJet 2600n Printer
While printing in black middle of page fades out both sides of the page print well. this is about a 1 inch fade out in middle of page.
Replace the drum of the particlular color cartridges. To know which color you have to print in single color one by one. If problem persist then replace transfer belt .
Jan 05, 2010 | Samsung CLP 300 Laser Printer
Printer no longer prints legibly
My CLP-300 color laser printer does not print clear in black. The left side of the page is worse then the right side. what can be done to fix this problem
Oct 30, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Phaser 7300 - one color fading on diagnostics page
Are you using third party toner? That is one thing that causes that problem. Use only xerox toner.
The other thing is that your image unit could have come defected, if it was brand new. Try changing the image unit and that should fix that problem. Good luck. 016-1993-00 image unit & toner 016-1977-00
Oct 02, 2009 | Xerox Phaser 7300DN Laser Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
Where to disable color management in printer driver dialog box
When you go to print.  In the box that say's print with printer/presets there's another that say's copies and pages, scroll down to Color Management. Then you will see a Off (No Color Adjustment). Try that and also in the same dialog box is Print Settings that's where you put your paper type selection. Hope this helps
Dec 18, 2008 | HP Photosmart D7460 Printer
HP 5610 - printing fades down the page
the printer carriage might be wearing out, it happens on the 5610's, may be time for a new printer. The fading issue sounds like a cartridge issue. Try a oem?
Nov 14, 2008 | HP Officejet 5610 All-In-One InkJet...
I need an alignment page!
open the color properties in printer properties, then set the color ratio as u need ,then start printing.
Aug 16, 2008 | HP PSC 1350 All-In-One Thermal Printer
Canon MX300 Office All-In-One Printer Logo
225 people viewed this question
old marine
old marine
