Question about Tyan S5396A2NRF Dual LGA771 XEON5000 5100 SATA2 Raid Audio 1394 GLAN ATX Motherboard (635872021268)
Tyan S5396 and Thermaltake 1500W
Have Theramaltake Eureka Case,Thermaltake W0171 1500W Psu,Tyan i5400XT S5396A2NRF, 2 Intel Quad Core CPU E5405A,Kingston RAM 4G Stick, Powercolor HD3870XT1GB GPU and 6 WD 5000aaks drives in Raid 1+0. OK when cold power supply only spins fans for half a second on startup.Have RMA'd both PSU and Mobo and came back with no faults.
Procedure used to try and isolate problem. First turned off power then drain mobo by holding front case button 3 seconds till light on mobo goes out then tried turniong power back on psu then front case button and still only get spins. My tech has spoken directly with tech at Digicor Australia in Clayton. When mobo RMA'd it had Bios update, tech seems to think it may have a short on the board in mounting. Ther have been other references on google about this startup problem but seems to be no answers. I have contacted Tyan directly but have no response. My tech seems to think it is a timing issue on between mobo and psu. Thanks if you can help.
  • 40 Answers
Tyan i5400xt.. to test for ground.. pull the board from the chassis and test with a different known good power supply
if the boot works... then you have a power supply issue...
does the board have a post code lighted signal ???
if so.. a bad power supply should goto FF error code
verify you have enough power on the cpu rail with your power supply specifications also
be sure you have all cables 4 pin 8 pin and 20/24 pin connections done correctly.. lastestly check if the board is touching the chassis edge anywhere... could cause a ground
also take and loosen all the MB screws from the chassis.. just let it hang there this will test the grounds needs the screw connections
mark@omces.com
tyan specialist
Posted on Sep 28, 2009
Intel Core 2 Quad 8200 with a 945GCT-M3? Will it work?
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=719&DetailName=Feature&MenuID=1&LanID=0
Here you can see the supported cpu list.
The quad core cpu will not run on this mainboard.
Here is info about the quad cpu:
http://ark.intel.com/products/36547/Intel-Core2-Quad-Processor-Q8200-4M-Cache-2_33-GHz-1333-MHz-FSB
But you can add a Intel Core 2 Extreme LGA775
This should give a noteable difference compares to the old single core cpu.
Remember also to buy a bigger cpu cooling element.
Here is no upgrade for the bios.
Good luck
Nov 18, 2012 | Computers & Internet
Intel core 2 Quad Q6600 compatible with ECS P4M800PRO-M2
According to their website, no. The core 2 duo is supported, but not quad core. http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=674&CategoryID=1&MenuID=16&LanID=0
Look under the cpu tab.
Oct 31, 2012 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
What model of cpu is this motherboard (Intel DG31PR) designed to accept?
Hello Kbda,
Intel DG31PR Motherboard support the cpu of following types Intel® Core™2 Quad Processor, Intel® Core™2 Quad Desktop Processor, Intel® Core™2 Duo Desktop Processor, Intel® Pentium® Desktop Processor,Collapse to hide the details Intel® Celeron® Processor, Intel® Celeron® Desktop Processor, Intel® Celeron® Dual-Core Processor, Intel® Xeon® Processor.
Also visit the link provided below :
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=dg31pr
Jul 08, 2011 | Intel DG31PR Motherboard
What power supply would you recommend for a quad core processor?
Greetings - Even though the CPU is Quad core you could get by fine with a 350W PSU, unless of course you're going to have a killer juice sucking high end video card and/or are planning to overclock your CPU.
A good quality 450-500W would give you plenty of margin. More important to get quality vs rating numbers. Cheaper manufacturers tend to overstate the specs of their PSU's.
Enjoy your new CPU!
Mikeywaf
May 12, 2011 | AMD Phenom X4 9750 Quad Core Processor...
What is the fastest cpu chip you can put in the mother board
Your motherboard supports the following processor upgrades:
  • Intel Core 2 Quad (Y) Q9xxxx
  • Intel Core 2 Duo (W) E8xxx
  • Intel Core 2 Quad (K) up to Q6600
  • Core 2 Duo E6x00 (C) up to E6700
  • Core 2 Duo E4x00 (C) up to E4400
Oct 08, 2010 | HEWLETT-PACKARD 461068001 Motherboard
Dell Motherboard/ OWG 855, what would be the fastest cpu that i could use
Intel Core 2 Quad Q6600 @ 2.4 GHz is compatible.
Good Luck
Mark
Dec 07, 2009 | Dell (2336V) Motherboard
New CPU, No display
in my view, ur motherboard doesn't support the new processor, so plz check the capability of your motherboard, and replace with the supported cPU. ok byee
May 16, 2009 | Intel Core 2 Quad Q9550 2.83GHz Processor
Will Intel Core 2 Quad Q9300, 2.50 GHz processor work on asus p5n73-am motherboard..is it compatible, will the motherboard crash or will the processor overheat. I am looking to change my current processor...
Motherboard info
Yes it'll work. Worst case scenario is that you will need to do a bios update. Overheat should not be a problem if you are using the intel reference cooler wich is provided with the cpu.
Mar 03, 2009 | Computers & Internet
Intel Core 2 Quad Q9550 2.83ghz displaying as Pentium III Xeon
This could simply be an issue with you bios. Flash to the latest bios version.
From the site it looks like the Mars has had some bios issues in the past.
Nice setup btw
Jan 29, 2009 | Intel Core 2 Quad Q9550 2.83GHz Processor
New Graphics card wont work
is the bios set to dispaly using a built in graphics card on the mobo?
Jul 02, 2008 | Intel Motherboard
Tyan S5396A2NRF Dual LGA771 XEON5000 5100 SATA2 Raid Audio 1394 GLAN ATX Motherboard (635872021268) Logo
234 people viewed this question
Top Tyan Computers & Internet Experts
Jerry Umali
Larry Chandler
Andrew Taylor
Andrew Taylor
Are you a Tyan Computer and Internet Expert? Answer questions, earn points and help others
