Question about Belkin (F5D7230-4) Router (587009)
I tried to set up a secure connection and failed!
I tried to secure my connection by going to 192.168.2.1 and I used the defalut sign on because I didn't know my password. I used the paraphrase config and applied it. Now I can't us my wireless! I am in another wireless...just what I was trying to prevent. How do I reset this? How do I set up a correct secure connection?
  • Anonymous Nov 03, 2008
    I need to secure my network (WAP).
    Cheers Darryl
I forgot my router user name and password
Posted on Nov 02, 2008
Error Code OxFFFFFE70 fixing
since we have no idea what machine has this code we cannot answer this question.
May 08, 2017 | Office Equipment & Supplies
I use to have the ps3 hooked and on a new service moved forgot everything and trying to connect to the wireless interent and it keeps popping up psn failed
Everytime you disconnect from a network you ll have to go into the network settings again to reconnect. Find your wireless connection on the list, select your security, enter password and then hit "test". If all credentials were correct, it will quickly breakdown the connection attempt for you, showing you where the connection succeeded and where it failed to better triangulate the issue. If all connections succeed during the test, simply go back to the main screen and sign on. Hope this helps.
Apr 23, 2015 | Sony Playstation 3 (PS3) Console
I can't sign in Y!M clicked troubleshooting and I got this Checking virtual IP servers... [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [PASSED] [VIP Raw] Sending HTTP request to the...
Bruno
Start your troubleshooting with a clean browser
Download 'ccleaner' and use it daily. Run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.Never make changes to your Registry without saving the information.
http://www.filehippo.com/download_cclean...
On the sign-in page click Messenger > Connection Preferences - make sure there is nothing untoward in the lower 2 boxes - if incorrect make changes using the drop-box options > OK
Copy this Yahoo secure site URL
https://www.yahoo.com/
Open Yahoo Messenger > Tools > Internet Options > Connection tab > LAN settings > Uncheck everything then check 'Automatically detect settings' and 'Use a proxy server' > Advanced > Paste the address in the secure box and type 5050 in the port box > OK
Sign in.
Hope this helps.
Mar 12, 2011 | Yahoo Messenger
We can't sign you in to yahoo! Messenger.There might be a problem with your Internet connection. Make sure your computer is connected to the internet. Click Troubleshoot to begin a series of tests to try...
1) Yahoo are concentrating their efforts to resolving sign-in issues with Messenger 10. You may have to upgrade to this version if you cannot resolve your problems and make use of the troubleshooting software - even if you want to retro install an older version later.
2) users who opt for a default browser other than IE may be neglecting to keep IE up to date unaware that IE plays a crucial part in the running of Yahoo Messenger. I use Firefox as my default but note the amount of cleaning in IE when I run ccleaner.
3) Start your trouble shooting with a clean browser
Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
http://www.filehippo.com/download_ccleaner/
4) It will be worth making IE your default browser while you troubleshoot
5) Download the latest IE from Microsoft
http://www.filehippo.com/download_internet_explorer/
6) Ensure 'work offline' is unchecked :- > Tools - uncheck Work Offline.
7) Update your support software for IE using the links on this page
http://help.yahoo.com/l/us/yahoo/messenger/messenger10/notices/mstabuguqscripterror.html
After updating check you do not have old versions of Flashplayer, Shockwaveplayer and Java running alongside the latest - this can cause conflicts
Start / control panel / programs
delete any old versions
8) If your log-in fails, interrogate the troubleshooting log for 'failed items'
Two Yahoo servers are used for initial log-ins
The log-in server checks your username and password are correct
If this has 'failed' check your IE can access a secure website by signing in here
https://login.yahoo.com/
No luck? check IE settings >Tools > Internet options > Connection tab > LAN > 'Use a proxy server for your LAN' > Advanced - Under 'Proxy address to use' check the info in 'Secure' and 'Port' are correct > OK for each window.
The connection server helps find the right location to synchronise with other servers- if this shows 'failed' change your YM settings to connect via a proxy.This can be done from the menu on the sign in page > Messenger > Preferences > Connection -adjust settings > Apply > OK
If all else fails - try dis-abling your firewall and do a test sign in.
Jan 09, 2010 | Yahoo Messenger
Sign in problem in yahooo messenger
just click menu -> connection preferences -> select connect to internet directly.also select the broadband/DSLclick OK
if it fails,
Download CCleaner.
Cheak ALL boxs'
Analyze
Repair.
it repairs the Registry
Dec 30, 2009 | Yahoo Messenger
NB100 fatal error while upgrading xp home to xp pro - pls. help
Hi
Try to go into System BIOS. Once you are in use the option Load Defalut settings.
And if any external device is connected other than CD-ROM, please disconnect it.
THEN TRY AGAIN TO INSTALL
Aug 03, 2009 | Computers & Internet
Windows live messenger
Error: 80072745 If you are encountering the error code 80072745 when you sign into Messenger try the following: 1. If you are connected to the Internet through a router, remove the connection to the router. Then, directly attach the network or modem cable to the computer. This will help determine whether the issue is related to a firewall setting on the router. Try to sign in to Messenger after you connect to the Internet. If you can connect to Messenger after bypassing your router, the issue may be related to router settings. Try resetting your router (Note: This may revert your settings back to factory default settings and may delete all your custom settings.). Please contact your router manufacturer's Help documentation or customer support channels to determine how to reset your router or enable port 1863 through the router firewall. 2. If you are signing in from a corporate environment, contact the network administrator to determine whether port 1863 is being blocked inside the network.
3. If you have Zone Alarm with IM Security installed on the computer, turn off IM Security for Messenger: 3.a. Right-click the Zone Alarm icon in the notification area, and then open the Control Center.
3.b. Click IM Security or click Security to open the IM Security settings window.
3.c. Click the Main tab or the Status tab.
3.d. Slide the Protection Level slider to Off to turn off IM Security.
Note: This procedure will change the IM Security settings for any instant messaging programs that are installed on the computer.
3.e. Sign in to Messenger again to determine whether the issue is resolved.
4. If you are connecting to the Internet using a Wireless Data card through a mobile phone network, please contact your mobile internet provider to verify if you need to additional data plans that enable you to connect to the Messenger service. Hope that helps!
Apr 23, 2008 | Microsoft Office Outlook 2003 for PC
Belkin (F5D7230-4) Router (587009) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
