Question about Bose 3 2 1 GSX System
NTSC I set the format to PAL now the screen is blank & I can't reset to NTSC
Hi. Got the same problem. Did u get a solution for it? Thanks
Posted on Nov 08, 2008
My car radio starvison fddv703 is showing ntsc how to reset Pls help
go to Video format settings and change it (NTSC) to PAL
and it depends on your device model number if it's support both NTSC and PAL or not
you can check the model number online.
Mar 23, 2017 | Cars & Trucks
Does my comp Video Card supports digital signal output through VGA function? If not, what kind of cable i have to use to connect it to TV Toshiba(flat ckreen, digital)? I'v tried many cables... just...
no vga is just analoge use a svideo cable and set it up as pal if your tv is a pal or ntsc if ur tv is ntsc the tv format is not right ntsc is us pal is japan it can be found the ati cfg utility
Jan 18, 2011 | Gateway MT6840 Notebook
When you insert a dvd it says PAL DISK
PAL is the format of the dvd and there are two main formats for a dvd and they are PAL or NTSC. The NTSC format is mostly used for the United States, and the PAL format is used more in Europe and Asia. An older dvd player will have the format options in the setup menu for the dvd player, and from the setup menu on the tv screen the dvd player can be set to play the PAL dvd's. However if that is not the problem and the dvd player no longer can tell a PAL from a NTSC format then the dvd player either needs a serious lens cleaning or it has a malfunction. Also, the back of the cover for the dvd should say if it is PAL or NTSC.
Jun 16, 2010 | JVC TH-A9 System
PS2 disk issues
ps2 PAL format cannot read NTSC\UC.NTSC\UC is for ps2 that have the logo NTSC\UC in the ps2.
Mar 05, 2010 | Sony PlayStation 2 (PS2) Console
Region code blocks DVD
Hi, you have to delete de region coding on your DVD, by using a computer (either a mac or PC, or linux) then you can play it. However, if the format is not the same (PAL&NTSC) it's gonna be impossible : for instance, if your PS3 is NTSC, you wont be able to playback PAL content, however, I think it might be possible to the opposite for PAL PS3 owners, since every PAL DVD player can read NTSC (but practically, none of NTSC player read PAL ...) Sad indeed mate.
Its a pain in the *** willing to try converting PAL to NTSC. You better forget it .... However, if its just a region code issue, as I said first, you can just backup it up deleting the CSS (it's illegal... whatever) and burning the region-unlocked movie to a blank DVD and play it ^^
Aug 21, 2009 | Sony Playstation 3 (PS3) Console
No colour..
Sounds like you're feeding the ADVC the wrong broadcast format. Either PAL when the ADVC is in NTSC mode, or NTSC when the ADVC is in PAL mode.
Alternatively, your capture software may have a broadcast format setting as well, and that may not be matching what the ADVC is sending out. Remember that the ADVC does not do NTSC<->PAL format conversion, so NTSC analog input becomes NTSC DV, and PAL analog input becomes PAL DV.
Aug 07, 2008 | Canopus ADVC-110 A/D Converter...
Pal or ntsc
Hey abinanth,
NTSC and PAL refer to two different analog TV broadcasting standards. In North America and Japan, PS2's and other electronic devices generally are sold in the NTSC format only, as that is the standard used in those parts of the world. PAL devices, on the other hand, are primarily used in Europe, Australia and portions of Asia.
While NTSC and PAL do share some similar properties, images are not displayed the same way on a TV screen with both formats. What this means for the average consumer is that in order to ensure that a PS2 will work with their TV, it will probably need to be purchased in the format used in their home country.
Please keep in mind that while NTSC-to-PAL/PAL-to-NTSC adaptors do exist, many electronic devices (including PS2's) are still subject to regional lockouts that prevent the use of any media/discs that were not purchased in the same region of the world.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 10, 2008 | Sony PlayStation 2 Slimline Console
My rca 2002 rtdvd1 player only plays ntsc format. I can unlock any codes so it will play PAL?
Unless it's built into the settings but most players designed for NTSC will only play NTSC. Those made for PAL will play PAL.
Theres too many radical changes in video signals to make one device handle both formats.
Jul 05, 2008 | Televison & Video
How to reset dvd recorder to ntsc from pal
After checking today to see no one offered any suggestions - I solved the problem the hard way - I went into settings and although the screen rolled, I was finally able to click onto the ntsc setting after about a half hour of tries and once I clicked it, my screen returned to normal -- i was then able to enter the code that made the player an all region player and was happily able to play a pal dvd I received recently. The procedure was simple -- offered by a European Cyberhome user -- the company is in bankruptcy so you cannot gt help from them. Note - my Cyberhome dvr is 1500- not 1600 as you listed it.
Feb 11, 2008 | Cyberhome DVD Recorder - DVR1600
Bose 3 2 1 GSX System Logo
64 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
