Question about Apple Cinema Display 23" HD Monitor
Now the light signal is one short, one long and one short again and that repeats... when connected to my Mac Book Pro the laptop has a black screen and when I disconnect the Cinema Display the laptop screen comes on.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Hi all,
I had the “short long short” blinking led problem with my
23′ ACD after a power outage which left my screen blank and
my cheek wet with a tear for my baby. I read somewhere that
a guy was getting a 1 volt reading on the middle pin of his
damaged 90 watt power block. I figured maybe the display might
work if I could somehow block the middle pin. So I cut a small
strip of paper wide enough to block just the middle pin and long
enough to cover both sides and it looked like a “W”. I gingerly
pressed it into the brick receptacle with a toothpick leaving
just a little slack so it would not tear when I pushed in the
small white plug. It was a bit of a tight fit but guess what.
IT WORKED… I am now enjoying my beloved monitor anew and saved
$$$ on replacement brick or repair.
If you want to try it and you feel you’ve nothing to lose, make
sure you cover just middle pin (both sides) and you may have to try a couple of times. It worked for me, I hope you have good luck too.
Regards, Moozler
Posted on Oct 27, 2009
  • roger821 Jan 07, 2011
    WORKS!
    Unbelievable, I thought; ' impossible' but worth a try; and it works again!
    Did it with a small strip electrical tape...
    Strange thing is, I have two the same monitors and bricks swapping didn't work...
    But don't care, it works now!
  • w a p Jun 20, 2011
    Moozler is a genius! I tried his paper trick after I got the short long short error code blinking light. Covered the center pin on the brick power input. Plugged it back in and turned it on and it was like there was never anything wrong with it. I was told by my apple authorized service center that all they could do was test it with a new brick which they did and if that didn't fix it then there was nothing they could do. Of course it was still dead after that so I took it home and have been staring at it on my desk for a month wondering what to do. Thought I'd try it one more time but no go. Got on the net and found apples repair guide and noticed the short long short blinking light error code and its meaning. Means it the wrong brick for the monitor. Course we know thats not true so did some more surfing and stubbled accross this site and read Mozers fix and praise the lord halleuhaaaaaa he is a prophet!!
    On a side note you can't tell me apple doesn't know about this problem. Their fix is to sell you a new monitor for something as simple as this. Well I will not buy another apple monitor after this. When this one blows its the competition whos gonna get my loot.
I am having these morse-code blinking power light issues with my cinema display right now. I just found the 3 top blinking patterns and what they mean on Apple's site: http://support.apple.com/kb/HT2811
Posted on Feb 24, 2010
  • 11,361 Answers
The root cause of the problem is due to bad 3.3V Voltage regulator VR3 on the main board, it is putting out more than 3.3v which caused the mointor sensing circuits which is use to find out if the correct power supply is being used with monitor to malfunction. If you do not change the regulator, it will cause more damage since the voltage will be too high. Taping off the pin is a band aid fix but more damage will occur.
http://s807.photobucket.com/albums/yy352/budm/MAC%20Monitors/MAC%20CINEMA%20HD%20Display/
Posted on Jan 13, 2012
I thought you were "full of it" when I read this post but I figured what the heck, might as well try it. It worked!!
Thanks for the unorthodox resolution. :-)
Posted on May 19, 2011
  • 3 Answers
This sounds like a backlight invertor error! it means it could go soon and is expencive to fix.
bit of help here, different screen but same guidelines:
http://macguild.org/display-repair.html
Posted on Jan 11, 2009
Aple HD Cinema Display 23" is dead, no front LED light or back display light
Contact Apple support by phone 1 (800) 204-4427 US toll-free or chat, set up a repair, or make a Genius Bar appointment for iPhone, iPad Apple Mac Technical Support Phone Number 1 800 204 4427
Jun 14, 2017 | Apple Cinema Display 23" HD Monitor
My 23" Apple cinema display (2002) has black screen and code flashes three short flashes. How do I find out if the monitor is dead or the power supply?
The only way to test is to use a known working power supply or known working cinema display with the parts you already have.
Dec 11, 2012 | Apple Cinema Display 23" HD Monitor
Apple Cinema Display 23" LED short-long-short flash prob.
Hello, I had the "short long short" blinking led problem with my 23" ACD after a power outage which left my screen blank and my cheek wet with a tear for my baby. I read somewhere that a guy was getting a 1 volt reading on the middle pin of his damaged 90 watt power block. I figured maybe the display might work if I could somehow block the middle pin. So I cut a small strip of paper wide enough to block just the middle pin and long enough to cover both sides, folded it to look like a "W" from the side. I then carefully pressed it into the brick receptacle with a toothpick leaving just a little slack so it would not tear when I pushed in the small white plug. It was a bit of a tight fit but guess what. IT WORKED! I am now enjoying my beloved monitor anew and saved $$$ on replacement brick or repair. If you want to try it and you feel you’ve nothing to lose, make sure you cover just the middle pin (both sides) and you may have to try a couple of times. It worked for me. I hope you have good luck too. Regards, Moozler
edit December 2016. Still working after 7 years.
***CAVEAT AND WARNING***
Use this fix at your own risk.
A faulty voltage regulator is probably the cause of failure. Voltage regulators can start a fire if too much voltage is applied.
Bud Martin's post below describes the electronic component failure that causes this problem. Thank you Bud.
Jul 19, 2009 | Apple Cinema Display 23" HD Monitor
Apple 23" cinema display
thats supposed to mean theres a faulty powerbrick, however i have the same problem on mine and replacing that didn't solve it
Oct 28, 2008 | Apple Cinema Display 23" HD Monitor
Apple 23" Cinema HD Display went off
Hey - I just got done with 30 minutes of trying my cinema HD on my macbook pro and plugging and unplugging. When I plugged it into an extension cord in another socket the monitor started right up. I've had this configuration in my office for years with no problem...until today. Did mac send us a system upgrade that caused a problem with the monitor's power source???? Good luck!!!!
Jul 28, 2008 | Apple Cinema Display 23" HD Monitor
Apple Studio Display Flashing Power Button
For the brave of heart, You can disassemble the monitor. After you get in to the inside of it, you'll see a circuit panel with 6 ballast coils on it. On my Cinema display, what happened was that the solder joints on some of those coils had cracked, causing intermittent connection. After hitting all the connections with a soldering iron to heal the cold solder joints and re-assembling it, it is working perfectly fine now.
Jan 29, 2007 | Apple Cinema HD 23" LCD Monitor
Screen resolution.
Hello there!
It's fortunately quite easy to adjust the resolution your MacBook Pro sends over to your external display.  Try this:
  1. Click the blue Apple icon, at the top-left of your display (while connected to your 23" external monitor).
  2. Click on "System Preferences".
  3. Click on "Displays" in the "Hardware" row.
  4. A display preferences window should now open on each display... one on your laptop, and one on the 23".
  5. In the "Display" tab of this preference window, specifically the one located on your 23" display, should be a list of resolutions available.  Scroll down and select the highest resolution, which for a 23" should be 1920x1200.
This should adjust your resolution to the maximum.  To make these settings easier to get to in the future, check the box in the display preferences labeled "Show displays in menu bar".  You'll see a small icon, meant to look like a display, appear in your menu bar.  Going forward, you can click on this to set/change resolution settings without going through all the above steps.
Hope this helps!
Oct 10, 2006 | Apple Cinema Display 23" HD Monitor
Apple Cinema Display 23" HD Monitor Logo
2,503 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
