Question about Toshiba 46H83 46" Rear Projection HDTV-Ready Television
Major screen problem with 46H83 - HELP!
I don't even know how to describe this... sometimes I get no picture at all and the menu options appear "curved" on the screen. Sometimes the screen goes insane with different colors flashing all over the place. Sometimes I lose vertical or horizontal hold. Sometimes it appears that only the red/blue/green lamps is working. Sometimes, albeit very rarely, it works JUST FINE. The solution is to turn it off and turn it back on, but the problem persists soon thereafter. Has anybody encountered something like this? I'm desperate for help. Thanks.
  • 1 more comment
  • Dan Petersen Sep 14, 2006
    Also - sometimes it just sits there and flashes pink or green, or blue, or anything else you can think of. Sometimes these crazy lines and patterns form.
    I'm telling you, I think this thing is possessed!
    FWIW - the sound works perfectly fine, and there is no issue with screen burn in.
    The problems started approximately 1.5 years after purchase, which was about a year ago... still having the issues, and they're getting worse every day.
  • Dan Petersen Sep 15, 2006
    Thank you for your help -- do you have any idea what type of cost I would be looking at for a profressional repair? I'm guessing this is a pretty standard repair job?
    Thanks again.
    -'98
    Just curious - what if the issue, as you say, is the capacitor? Am I looking at something drastically more expensive?
    In short, I'm weighing the option of getting this thing repaired vs. buying something new... Obviously, I would like to extend the life of this instead of spending $3000 or so on something new.
    Thanks again for your help.
    President:
  • 3,130 Answers
The convergence IC first need to be changed and this might cause all of your problems to go away. if it does not then theres a bad capacitor in the sweep power supply thats bad also. but as I said change out both STK convergence IC's first.
Posted on Sep 15, 2006
  • Larry  Dillon
    Larry Dillon Sep 15, 2006
    If you pay over 350 bucks I think your getting ripped off cause these IC's are cheap!!
SOURCE:
How do I get rid of horizontal lines
The picture should be free of horizontal lines. If the lines are present on the TV screen, press the SMART button on the remote control and select Settings > SUPPORT > Picture Test. This menu will appear on the test picture. Select which option best describes the result you have.
Aug 21, 2017 | Televison & Video
I have horizontal lines
The picture should be free of horizontal lines. If the lines are present on the TV screen, press the SMART button on the remote control and select Settings > SUPPORT > Picture Test. This menu will appear on the test picture. Select which option best describes the result you have!
How to Add a Background Picture to a Microsoft Word Document 2007
t is easy to add a background picture by using the Watermark feature. First, you will click on “Page Layout”. In that menu bar (or ribbon), click on “Watermark”. A window menu will open. At the bottom of that window menu, click on “Custom Watermark”.
In the new menu that opens, check “Picture Watermark”, then “Select Picture” to find an image file on your computer to use. You have the option to have the picture look faded, as a watermark, or displayed in its full color. Check “Washout” for the faded option, or uncheck, to view the background picture in its full glory.
You will then need to choose the size of your background picture, by selecting one of the options under “Scale”.
To remove the watermark, simply click “Watermark”, and choose the “Remove Watermark” option.
Even if you don’t choose the “Washout” option, the background image will appear faded while you are working on your page. But, if you view the page through “Page Preview”, you can see how the background will look when printed.
To get to the "Page Preview" command, click on the button.jpgOffice Button on the upper left hand corner of the Word 2007 screen. Move your cursor over the "Print" option, and another menu will open to its right. On that menu, click "Print Preview".
Jul 21, 2010 | Microsoft Windows XP Professional With...
Hey can any one help me with my Toshiba 46H83 rear projection hdtv? My screen is off center by about 3/4 of an inch to the right. The picture is prefect except for this. I've asked this question two times...
OK, need to go to service menu of TV and adjust HPOS data, you can move entire picture left to right or right to left to adjust it on TV screen.
Be careful NOT to initialize service data memory otherwise all convergence will be a mess.
How to go into Service Mode is written in service manual of TV.
Thanks.
Sep 05, 2009 | Toshiba 46H83 46" Rear Projection...
All of the icons from the screen disappeared!
try to reboot your computer into safe mode.
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Then click start
click run
type in msconfig
uncheck everything under the startup tab except your antivirus
and reboot
Jun 05, 2009 | Computers & Internet
Toshiba 46H83 HD Projection TV with distored picture
if you are using an areal for your tv move your areal and see if it works or do the tuning for it .
Apr 19, 2009 | Toshiba 46H83 46" Rear Projection...
Picture is Dark on all stations
It sounds like a bulb. I would call toshiba and ask them what the replacement part is for that. I briefly googled for it but couldn't find the matching bulb for the 46H83
Dec 12, 2007 | Toshiba 46H83 46" Rear Projection...
Toshiba 46h83 tv projection not full orizontal pic
if you go to the menu on your tv it should show picture you may need to snoop around for it but its there and when you do find it adjust it untill you got a nice picture about the tv not being full on the screen try buying wide sceen movies it should help but the adjustments should help the most
Jul 30, 2007 | Toshiba 46H83 46" Rear Projection...
Background
Hi Adrien, the easiest way to set a picture as a Windows background is to open the picture in your web browser and right click on it. A menu box should appear, about half way down you should see an option labeled *Set as Background*. Left click on that option and Windows will automatically use that picture as you background image and tile it to fill your entire desktop. Alternatively if you have Windows XP and use the Windows Picture and Fax Viewer program to display the picture the process is the same except when you right click on the picture the selection will be *Set as Desktop Background*. When you select that option it will do the same thing. If you don?t like the tiled effect right click on the desktop and select properties from the popup menu. In the display properties box that appears click on the Desktop tab, and in the lower right hand corner you will see a field labeled *Position*. Left click on the pull down arrow and select center or stretch, depending on what effect you want. Let us know if you need any other help and don?t forget to rate the posting.
Jan 03, 2007 | Dell Inspiron 1150 Notebook
Toshiba 46H83 46" Rear Projection HDTV-Ready Television Logo
63 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
