Question about Timex 27191 Wristwatch
Timex Lady's "Carriage" watch
Indiglo works but watch doesn't - I put in a new battery but it's still not working and it's fairly new - should I send it in with $7 - and if so - who do I make the check out to...thank you
  • aftonandpaul Nov 17, 2008
    Just replaced the Battery (CR2106) in a Timex Mens Analogue wrist watch and now the Indiglo light and stopwatch hands all work, but the actual watch doesn't work, the mechansim doesnt move neither do the hands move autonomously. Any Ideas?
    Thanks
5 Suggested Answers
SOURCE: How to change battery for Timex Indiglo WR 30M
I ended up putting the watch between two layers of a shop rag and tightened it in my garage vise. First try didn't work so the second try I turned the vise another /14 turn. Voilla! Stupid watch!!
Posted on Sep 23, 2008
SOURCE: timex expedition indiglo wr 50m
I had the same problem, and could not find any answers on timex.com. After you place the battery in and it begins to beep, push all four buttons in at the same time. This should "reset" the watch -- at least it did for me.
Posted on Sep 28, 2008
SOURCE: setting day and date on timex watch
How do I set the day and date on my WR-30 M wrist watch
Posted on Jan 01, 2009
  • 7 Answers
SOURCE: can't put (back) back on my timex indiglo
I used to work with jewelry. !!BEWARE!!
This method is for face crystals that are completely FLAT! Any convex crystal will shatter without proper tools!!!
Any method of putting the watch cover back with the watch remotely near water/moisture is a mistake. The watch will rust sooner or later.
So if you don't want to pay a jeweler five dollars to put it back on, this is what I did to my sister's watch cover when I could not snap it back.
I took my cushy 1/4 inch mousepad to a vise. You may not have a vise. If you don't, stop reading now and take the watch to a jeweler --one who replaces batteries.
Inside the vise jaws, I used a 5 inch square piece of wood, then my cushy mousepad, then the watch facing the pad, then the back in the right place for restoring.
!!!!NOTE: Not having the back in the right place will smash the stem and damage can/will result!!!
To push the back on, I picked a 12 point socket out of my socket set that was the same DIAMETER as the watch back and placed it CENTERED behind the back.
Recapping, inside vise:
  • small board
  • cushy mousepad (to avoid scarring and crystal breakage
  • watch crystal facing mousepad
  • watch back in correct position
  • ratchet socket the same diameter as watch back centered behind cover
Slowly I positioned all these items with minimal pressure. Then when I was sure that I was ready (and prepared to hear the crystal break) I put as little pressure closing the vise that I could. The I heard a snap, and to my relief, it was the back going in!
I DO NOT RECOMMEND THAT YOU DO WHAT I DID. People with broken watch crystals become very IRATE when "all it needed was a battery"!
A screw clamp would also give adequate pressure. Any unsupported direct pressure over the crystal will shatter it!
Hope this helped.
Good luck!!!!
Posted on Aug 27, 2009
cmcduncand
  • 714 Answers
SOURCE: I have a Timex indiglo wr 30m wrist watch and I can't set the day
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 10, 2010
Watch stopped .flat battery ? Timex Indiglo watch
it the battery is more than 2 years old --probably
if it has a light on the dial then definitely as that uses battery up
if fairly new then take it in for a check up
Jun 04, 2016 | Timex Indiglo Watches
What's wrong with my watch?
New batterys can go bad, that is why they have a warranty. Replace the battery
May 16, 2014 | Timex Expedition Watches
My Timex Expedition Indiglo wrist watch has had two new batteries and keeps on stopping quite frequently. The Jewler cleaned everything and it still won't work properly. Is there somewhere that I can send...
The watch would have to go back to the manufacture, try www.timex.com for customer support and ask for technical assistance, they should be able to direct you to the nearest authorized store or they may have you send it to them.
Jan 19, 2011 | Timex Expedition T41261
I have a Timex Expedition watch which I have had for two years. I have been wearing Timex watches for 30 years and this one just doesn't live up to my previous experiences and expectatoins. The "indiglo"...
mcdevito75 here, Sorry to hear of your disappointment with your Timex watch, thru the years quality of workmanship and parts may have fallen a bit, try a new battery in your timex, a high quality Battery. Anyway here is Timex Customer service number, 800-448-4639 Regards, Mike D
Oct 20, 2010 | Timex Expedition Perpetual Calendar...
Hello, I just bought a Timex Acqua with Indiglo
Depending on when you bought your Timex, you shouldn"t need a battery just yet, your Timex came with a good battery. Look under the stem (winder) for a small piece of plastic that is not allowing the stem to go all the way down, remove that piece of plastic and push the stem down and your Timex will start. Or if your Timex has buttons, look for a tab of plastic on the back cover, this tab of plastic is keeping the battery from (ground) a complete circuit remove this tab of plastic to start your Timex. Changeing the battery while fairly easy, you"d need jewelers screwdrivers and of course the new battery, Best Bet, look for a small watch repair shop in your area for the battery change.
Aug 18, 2010 | Timex 2J611 Watch
I have a timex HRM. The indigo light just stopped working. I've had it for 3 weeks. There is a faint light on the edge, but it doesn't illuminate the face. Everything else works normal. Any ideas?
Check out if your watch has second battery for Indiglo function. It is quite common for Timex watches to have two batteries - one for movement and another for Indiglo.
Jan 21, 2010 | Timex 27191 Wristwatch
Timex 1854 chrono,indigo lght not working. 2nd one in 4 mths?
the same problem, after 3 years of use.
Night Indiglo light was very bad.
thought the battery replaced it, the battery was okay.
began to collect but probably need a special tool, the glass cracked)
Sep 09, 2009 | Timex Watches
Changed battery...indiglo works but time isnt working
Some Timex watches are fitted with two batteries (one for indiglo, another for watch movement). Check out if you have this sort of model.
Mar 28, 2009 | Timex 27191 Wristwatch
Timex T49271 Expedition Indiglo button dead?
There is no separate battery for the indiglo,maybe indiglo circuit is lose or defected already,just open the watch and check for lose connection.If happen the circuit is tight and still not working then replace the indiglo circuit.
Hope it may helps you;
Regards
VOTIT
Mar 23, 2009 | Timex Expedition 40141 Wristwatch
Timex indiglo. Indiglo feature died.
The indiglo technology is time limited (it dims over the years with use) and cannot be repaired - have you had the watch a long time? if so, I'm afraid it's time to get a new one. Sorry!
Dec 30, 2008 | Timex Watches
Timex 27191 Wristwatch Logo
106 people viewed this question
Top Timex Watches Experts
Ross Keen
freddyfox
Jerry Greenberg
Jerry Greenberg
Are you a Timex Watch Expert? Answer questions, earn points and help others
