Channel search only picks 9 channels - Televison & Video
    Genius:
  • 1,269 Answers
Are you using a satellite dish or cable? Try to use the auto search channel feature or auto store. By the way what is the exact model of your unit?
Posted on Oct 31, 2008
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
what the brand of your Projections??
  • 456 Answers
It depends on the frequencies supported by the television
other channel supplier putset top box and antenna so they can get the frequency
so its normal
4 Suggested Answers
SOURCE: DH Channels
is there a setting for hdmi cable on this tv
Posted on Dec 18, 2008
SOURCE: my rca won't pick up channels when doing a channel search.
It sounds like you need to auto program the chanels on your t.v. There should be an opition in your menu. If there is not something called auto program or channel manager it my be in your set-up menu. I hope this helps.
Posted on Jan 08, 2009
Slinteriors
  • 8617 Answers
SOURCE: auto channel select not picking up all channels it should be.
You need the signal board. You can get one at the following link.
http://servicemanuals.vstore.ca/
Posted on Jun 01, 2009
When I did the air auto scan it only picked up two channels. How can I get more channels?
The auto scan picks up whatever channels are available, if it only picked 2 then that is all you have available
Dec 11, 2015 | Pegasus 7" ST07-B Portable Handheld...
Audiosonic hdt909
Posssibly antenna orientation could be a factor. Also, STB suppliers recommend repeating channel search periodically so that missing channels magically appear.
Apr 22, 2014 | Televison & Video
My new olin set top box will not pick channel tcn 9
Just try to retune all the channels it should pick it up. Everyone had to retune because 9 changed their frequency
Nov 29, 2013 | Computers & Internet
Need to scan channels
you can do the auto search channel. just press the tv menu and then find the channel search and select auto search. so that all available local channel will tuned.
Aug 30, 2012 | Insignia NS-LTDVD19-09 LCD TV
I have done an autotune on my sony bravia tv but am not getting channel 9 sbs. the television in the bedroom is a smaller digital tv and that picks up all the channels. the two tv's are connected
Is the splitter an amplified splitter or not? Have you tried the channel search when you connect the antenna directly to the TV? (Disconnect the cables from the splitter and use a coupler to join them together.) Tuners do vary in their sensitivity. For digital signals, your TV should report the signal strength. This is often under the Settings sub-menu. Some TVs will give this information in the Channel Edit option.
If the straight through connection gives a better signal, check your antenna direction and try a different splitter. Amplification will often help; however, when my amplified splitter was damaged the less sensitive tuner lost a number of channels that the other TV received. (Looking at the signal strength, one TV was getting adequate signal with one bar out of 8. The other needed at least 4 bars to process the signal.)
I hope this helps.
Feb 01, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How do I do get to the set up mode using controls on the TV set? Want to do a channel search
Hello
To autotune do the following steps.
1.1 Press MENU to access MAIN MENU screen,
then press CH UP (8) or DOWN (9) to
move the " " mark to "SET UP".
1.2 Press VOL (+) or (-) to access SET UP
mode, then press CH UP (8) or DOWN (9)
to move the " " mark to "CH SETTING".
1.3 Press VOL (+) or (-) to access CH
SETTING screen.
1.4 Press CH UP (8) or DOWN (9) to move
the " " mark to "CH SEARCH", then press
VOL (+) or (-) to access CH SEARCH
mode.
START
2.1 Press VOL (+). The tuner will search
through all available channels in your area
and add them into the TV's memory.
STOP
2.2 Press VOL (-). CH SEARCH will stop at
the current channel and will not add any
higher channels.
2.3 Press MENU to exit.
Nov 21, 2010 | Sharp 25K-S180 25" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
