Question about HTC S710 Smartphone
Firmware deleted Hi, I wanted to update my firmawre for my HTC s720. After the update manager said that everything is done, I've unplugged the phone from my PC< but it was still rebooting and installing some telus stuff. After 1 mins I came back to it and found that the screen was off. I just couldn't do anything so I just took ofthe battery and placed it back. After that whenever I turn on the phone it reboots in the telus screen and keeps doing that so I can't even reinstall the firmware again. PLEASE HELP?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 62 Answers
You will likely have to reset your phone to factory firmware
to do this:
1 hold down both soft keys (the 2 buttons under the screen that have no specific symbol, on either side of the launch pad)
2 while holding these, press the power button once
3 when phone turns on, release the soft keys
4 follow the on-screen prompts to reset phone to factory
5 (optional) try firmware upgrade again and WAIT FOR THE COMPUTER TO SAY ITS OK TO DISCONNECT BEFORE DISCONNECTING
hope this helps
Posted on Sep 13, 2009
How do I delete text messages from a verizon htc phone
If you just want to deleted text messages from HTC phone, you can do that on your HTC phone, entre the messages app, select the text messages you want to delete.If you want to deleted them without recovery, you need to use an Android data eraser program. With its help, you can delete text messages permanently.
Android Mobile Eraser Wipe off Everything on Your Android Device
Nov 21, 2016 | HTC Cell Phones
Htc mozart firmware update error how to solve
Carry it phone to fix the people in the phone company will know wat to do
Aug 12, 2013 | Cell Phones
How can I delete Apps I do not want?
press on the icon of the app that you do not want until it starts to shiver then press again and hold until it goes
Aug 09, 2017 | HTC EVO 4G Smartphone
My phone has problem 507 its blackberry 503 how do i fix it
Good Day,
Error 507 simply means that there is no OS or firmware found upon booting of the phone. Thihs happens on failed Software update or corrupted phone memory.
You can attempt repair on it by following the instruction here.
Please be sure first that you have installed Blackberry Desktop Manager; http://us.blackberry.com/apps-software/desktop/ Download then install BB Desktop Manager.
and a firmware or OS for your 9300, depending on your network provider: https://swdownloads.blackberry.com/Downloads/browseSoftware.do;jsessionid=7310B209ED254F016E31A5889BD1191D.node1 Just be sure to select the correct model number and network provider to download.
then check if you have existing Software on your computer Start by going to your Control Panel and then Add and Remove Programs (in XP) or Programs and Features (in Vista) and remove any BlackBerry device software currently installed on the computer. Reboot the computer. With your desktop manager closed and your BlackBerry unplugged, install that OS on your computer, then reboot the computer. After your computer has rebooted, plug your BlackBerry in and you can try using the BlackBerry Desktop Manager to load the OS on your phone, but in this case, you may find it easier to use the AppLoader file. You can find this under C:\Program Files\Common Files\Research In Motion\Apploader. To reduce the chance of any problems, you might also want to look through this folder for the Vendor.xml file and delete it first. After you've deleted the Vendor.xml file, double click on apploader.exe. This will open up the apploader which will load the device software onto your phone.
Uploading the OS to your device takes time, so be sure to be patient and never unplug the blackberry even though it may seem to hang on the screen. Let it finish its job until it says it is done. Unplugging it prematurely may render your phone useless.
Hope this helps you. Thank you for using Fixya.
Aug 15, 2011 | RIM BlackBerry Curve 3G 9300 Cell Phone
I purchased some software to monitor calls on my daughters cellphone. the software was sent to me and i need to save it to my computer and then download it to my HTC thunderbolt phone. how do i do this?
The software installation file you have purchased is in "APK" format which is what Android will recognize as an application installer.
To install applications outside of the Market you must select/check "Unknown sources" which is located under "Applications" which is located under "Settings."
1. Connect the HTC Evo to your computer via it's USB cable.
2. Select mode of connection as "Disk Drive" (a menu with these options will pop up after connecting through USB).
After that is done, your computer will now recognize your HTC Evo as a Disk Drive.
3. Go to the location of the file you've download and want to transfer to you daughter's Evo- Select it, hold down "Ctrl" key while pressing the letter "c" (to copy the file).
4. Go to the location of the HTC Evo now known to your computer as a "Disk Drive" then hold down "Ctrl" key while pressing the letter "v" (to paste what you've copied).
Now that the file is on your daughter's Evo you simply need to:
1. Change the Evo's mode of connection from "Disk Drive" to "Charge Only" or just disconnect the USB cable.
2. Browse to the phone's app directory to start a file manager application (download one from the Market if you don't already have one- I recommend "ASTRO File Manager").
3. Navigate (using the file manager) to the file you've transferred to the phone and just launch it. The next prompt will ask if you want to install the application- select "Install."
Done.
Aug 13, 2011 | HTC EVO 4G Smartphone
How to reformat samsung C3303K
To get a new firmware go to samsungs website and you should be able to get the firmawre update from there OR get it from the samsung service store.
First remove the sim card from your mobile, and to hard-reset your samsung mobile use this codes:
*2767*2878# or *2767*3855#
After hard resetting your mobile using the code above insert the sim card into your mobile and restart your mobile. Done : )
If this solution was helpful please rate, thanks!
Jul 04, 2011 | Cell Phones
Phone hangs
You need to end some tasks within the task manager. I notice my phone slows down. I'll check the task manager and find most of the apps that I've launched still running in the background.
Also...
What Firmware version are you running? There is an update a while back, you will have to contact T-Mobile to get it for your phone... I can't seem to find it on their web-site.
Here's how to check what version you are running though.http://support.t-mobile.com/doc/tm54429.xml
- Mark
May 21, 2011 | HTC HD2 T8585
I can't conent to my laptop with htc hd7?
First off install the HTC software on your computer
Now check if there is a firmware upgrade for the HTC phone and do it if there is one as it makes it a little easier
Connect the phone to the USB lead and then on the phone select MENU then NOTIFICATIONS
depending on the firmawre it may already ahve com up and asked you how you want to connect
CHARGE or SYNC or MOUNT USB
you can also get to that from the NOTIFICATION screen and selection
If you want to transfer things to and from the memory card select MOUNT
If you are syncing email then obviously select SYNC
and charge is just that
you cannot use any more than one option at a time
Mar 04, 2011 | Computers & Internet
My HTC hero will not allow me to delete text messages which is taking up all my memoery
My Hero used to take ages to delete messages and often used to freeze when it was doing it. However now my phone is running 2.1 update it deletes perfectly fine. Check if your phone is on 2.1 update, go to settings, about phone, software informations and it is the firmware version your looking at. If your phone is running lower then 2.1 update then go to settings, system software updates and press check now. If it says there is an update available then download it. Overwise you will have to download an app. The app i suggest is called 1-click cleaner, it allows you to quickly delete all the messages on your phone from the app. Hope this is of help to you.
Dec 19, 2010 | HTC Hero Smartphone
When i try login it says "please enter a valid mobile number for example: 8.
hi
Sound like it is the firmawre on these models, got to nokia.com get the update program, and update you firmware, or take the phone to your nearest nokia Store, or service provider they can help you
thanx
Oct 10, 2009 | Nokia 5300 Grey Cellular Phone
HTC S710 Smartphone Logo
280 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
