Question about EliteGroup Via P4M266A (P4VMM2 V7.3) Motherboard
Booting Problem I have every settings in the bios for booting from Harddisk but it doest work when i boot from cd rom it works but when i set settings on bios it oesnt work it goes on either network boot or MAB confirguration and i also feel that it does not supply power to haddisk.
  • 781 Answers
It cannot find your hard disk to boot from
Check the 4 pin power cable is correct and that the ribbon cable is fitted correctly. with the stripe side nearest the power cable and next to the No.1 pin on M/board
Posted on Nov 02, 2008
Hi, I'm using Asrock P4I45GV R5 Motherboard. but when i attempt to install OS, it shows NTLDR Missing. but HDD is working properly. at the next time when i try to boot from the CD it fails. and i need to...
just go to in bios setup using F2 or del key and change the booting sequence.and set 1 cd-rom 2.hdd
now save and restart system now you are able to boot from cd rom r dvdrom
Apr 10, 2011 | Asrock P4I45GV R5 Motherboard
What steps will be done in order for me to reformat my computer?
1) All computer has BIOS ( Basic input/output system). Here, you can set up how your PC will run. It is a blue colored full screen with different tabs like general, exit, devices and many more. Go to BIOS by simply hitting del (delete) continuously after restarting your computer.
2) Once in BIOS, look for the booting set up. Listed there are the devices which computer normally boots. ( Harddisk, CD-rom, Floopy Disk and Network)
3) Place the CD-Rom as the first boot and see to it that the bootable CD of Operating system you want is inserted in the CD-Rom. Then Place harddisk as the second booting device. Third and fourth booting devices are not usually important.
4) Save the changes and Exit. This will restart your computer automatically.
5) When your computer restarts wait until you see a message saying.........
Boot to CD........<----if this showed up hit any key to boot to CD. This will make your computer refer to the CD.
6) They will ask you if you want to delete or to create a new partition. For me just delete the partition and do not create anymore partitions. This will only slows your computer down.
7) After Deleting the partitions, they will ask you if you wanted to format you PC. There are 4 choices in there:
a. Quick format (FAT)
b. Format (FAT)
c. Quick format (NTSF)
d. Format (NTSF)
Choose the format either NTSF or FAT. Sometimes quick formatting result to corruption of some files.
8) The computer will copy the contents needed from the CD to your PC and installs it. Windows will appear but i know when you see one you can understand what to do. It will just ask for date and time and user name if you want to.
9) After the installation is complete the computer will automatically restart.
10) Once restarted, set the display in your choice. You can do anything now. Congratulations, you now can reformat
Jan 16, 2011 | Computers & Internet
My laptop won't boot from cd
to reset the BIOS, there is a small battery somewhere in your computer. if you unplug it for 3 seconds, it will reset the BIOS. I RECOMMEND THAT YOU DO NOT TRY THIS! get a service professional. If this doesn't work you might need to get a new laptop.
Dec 29, 2009 | Toshiba Satellite A105-S2712 Laptop
I have an old Presario 5000 series PC, hard disk crashed, bought a new hard disk and tried to use the Quick Restore CD's to Restore to Factory settings. Can't seem to boot up from Disc 1 of the Quick...
For boot from disk first you have to set first boot device option in BIOS.
for that when you power up the computer press F1 or F2 or "del" key to enter in bios.
Then go to boot menu then set first boot device as your cd/dvd rom.
then save settings then insert recovery diks in rom then check.
Then it boot from disk if your disk and cd.dvd rom works fine.
Let me know if you need more assistance.
Thanks.
Nov 05, 2009 | Compaq Presario 5000 PC Desktop
Acer Aspire 5100-5674 won't boot. Keyboard won't work, mouse initializes. PXE-E61 : Media Test Failure then PXE-M0F : Exiting PXE ROM I really need some help, I just bought it. And would really like to...
PXE errors are generated by the network boot ROM. In other words, the boot process is attempting a network boot (your BIOS' 4th boot option), which means that your system was unable to boot from a HDD, CD-ROM, or USB device (the first 3 boot options).
PXE-E61 Media Test Failure, System won't boot:
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration
Also verify if your harddisk is detected by BIOS
Jul 30, 2009 | Acer Aspire 5100 Notebook
BIOS SETTINGS
Go to BIOS setting by pressing F2 or Del while booting..and change boot priority as first boot device as hard disk then save and exit...
Feb 19, 2009 | Intel D845GLLY Motherboard
Toshiba a205 laptop wont boot
try to boot the windows from external DVD or CD ROM on USB if you have acces to your BIOS set the bios to boot from USB. i think your CD/DVD rom is not working properly, or is no booting from it bios is not setup corectly.
Jan 17, 2009 | Toshiba Computers & Internet
Hp laptop and system
OK there could be many reasons behind it
1) If your CD is booting  and the harddisk is not  it means  that maybe your harddisk has moved  form its loacatio  try to place it in its location
2)U might be having a SATA hdd
   if that is the case maybe ur  BIOS settings have changed and you might have to enter the BIOS and  change the settings there.
If u cannot find the settings pls post back I would be happy to  provide the settings
Nov 04, 2008 | Computers & Internet
Pc wont boot up after reformat.
After format your computer will not boot if don't have the Sys files on it. Try to put your hard drive back to your computer and start booting with some cd with hard drive utilities like http://www.ultimatebootcd.com/
Sep 24, 2008 | E-Machines eMachines Desktop PC
Install hard drive
Dear PBRIM ,
First of all you have to format new Hard disk then you have to install the Operating system and drivers on it then it will be work.
Cheerup and Be Happpy always
Mar 11, 2008 | Computers & Internet
EliteGroup Via P4M266A (P4VMM2 V7.3) Motherboard Logo
59 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
