Monitors
Problem for Monitors
Generic problem for all Monitors
Computer boots fine but the monitor is bla...
By dhanushkald on Oct 31, 2008
i have a Samsung CRT monitor. sometimes when i turn on the computer the monitor is blank, but the computer boots fine. when this happens i have checked plugging the vga cable of the monitor to the laptop vga port and the monitor works just fine. sometimes the monitor works and in such a situation, if i shutdown the computer and turn it on again sometimes the monitor is blank. im begining to think this could be something wrong with the mother-board. cannot say for sure when it would work or when it wouldnt. sometimes it works for 2-3 days without any problem and stops working for another 2-3 days.the first time this started i was working with the computer and the whole screen suddenly went white. then i turned the computer off and then turned on again, then the monitor was blank.
Thanks,
Dhanushka
Comments:
Oct 31, 2008
- thanks Lemmor. my main-board is a new one and i've been using it only for 7 months. i'll get the main-board checked. Thanks. :)
Best Solution
posted on Oct 31, 2008
Helpful)
Lemmor
Rank: Wiz
Rating: 84%, 613 votes
if the monitor works fine on your laptop, the problem definitely is at the computer, possibly with the video card (if it is using one). it could have loose connection, or parts might have damages. it seems the problem is intermittent so electronic component of the video card could have parts partially damages or leaky components.
if your still using the motherboards built in video out put, try installing a new video card.
Was this helpful?
Yes
No
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
I need a monitor to work on a old industrial machine it must be vga compatible
Answer
need to remove the rear panel of this xa3-17b monitor to replace data cable which is broken near the... (More)
Answer
I need Philips 105e Crt Monitor Rgb Cable Pin Diagram
Answer
what to do when your screen goes black and says analog
Answer
I have a Dell Optiplex 360 computer with a service date of 9/7/09 that operates on the XP system. ... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
in Tulsa, OK
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
