Question about GE 27GT722 27" TV
GE 27GT722 Picture problem
My T.V. powers up, but sometimes there is no picture, not even snow. Sometimes i power it up and the picture comes on right away, other times it takes several minutes for the picture to come up. Also, sometimes i turn on the T.V. and the picture never comes on.
    Sergeant:
  • 337 Answers
Regarless of the reason I will give you ,call a service tech for an estimate since is the safe way to correct the problem. First when you loose the pix put your forearm in the face of picture tube and if the hair in your arm stands up is a good sign because you are not loosing high voltage to the picture tube but if the hair does not stand up it means the crt looses high voltage and for that you need a service tech to troubleshoot.The other reason might not be as expensive If you have high voltage by doing the previus test it might just be a loose conection in the crt board.Do not remove the back cover unless you know what are you doing.Is not safe.
Posted on Sep 14, 2006
While we're trying to watch TV, our Panasonic PT-AX200U HD projector will sometimes start alternating from a green screen to a blue screen and then to snow, and finally back to a normal picture. It's
You are experiencing Power Fluxuation. The Power Supply seems to be going out or on the way out... How old is the TV? Is it still under warranty?
Apr 08, 2013 | Audio Players & Recorders
No video playback
Sounds like a classical video head problem. May be quite expensive to fix. Of course you can first try spraying the head with a "no residue" contact cleaner and then dry it out with pressured air to see if that fixes the problem.
Jan 07, 2008 | Canon ES50 8mm Camcorder
Sanyo TV has no picture or sound
better to take this tv to service shop,possibiliy defective or cracked tuner,broken pc board,cold or intermittent solder in power supply or in main board..
Dec 16, 2007 | Sanyo DS24425 24" TV
Red power light comes on and no picture
Sometimes after a move,a bad solder connection causes a
part failure,maybe just a fuse device....have it checked by a
qualified technician.............T.
Nov 30, 2007 | Hitachi 43FDX01B TV
Mitsubishi WS-65819 2002 rear projection
1)possible bad RF modulator (the small box the A or B signal first goes thru) 2)Bad tuner (mounted on signal board) 3)or missing voltage to run tuner You could replace signal PCB,but that gets a little pricey.
Oct 03, 2007 | Mitsubishi WS-65869 65" Rear Projection...
27gt722 sound ok, no video
I found one of these that had an inductor coil which is in series with the hoizontal output transistor base open up. It had a bad solder connection where it goes through the circuit board. This might be what happened to your tv. If so, it needs to be resoldered. What happens is that you loose horizontal drive and since the voltage that lights the filiament of the picture tube is derived from the flyback transformer this voltage is gone. Another possibility is that you may have an opem filiament (rare) or a loose connection on the picture tube driver board which is mounted on the neck of the tube. Stargazer
Feb 23, 2007 | GE 31GT740 31" TV
Open Questions:
GE 27GT722 27" TV Logo
77 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
