Question about Bosch Dryers
Bosch dryer wta3500ug start runing gos on and off over and over with no heat...?
  • nizaraaa Nov 01, 2008
    thank you for your help.it is oaky now...nick
    Problem Solver:
  • 10 Answers
Nizaraaa:
What you are describing sound as if you have the dryer set on a Wrinkle Sheild setting which it will go on and off for a set time with a low heat, so wrinkles do not set in the clothing.
woodychoppers
Posted on Nov 01, 2008
No heat from wtmc3300us Bosch dryer. Pushed reset and the heater started working. Next load and no heat. If it tripped the overload again, what now?
Looks like you may have an over heat problem. Look for a problem with your vent system and pipes. If its partially blocked you will trip the heater over temp thermostat.
Apr 07, 2015 | Bosch Nexxt WTMC 3300 Electric Dryer
I have a Bosch nextt 500 series dryer and after 2 years of use the problem I have is the heat will shut off and the dryer will keep running and I have to press the reset button on the backside of the dryer
Open the front panel, remove heat exchanger and clean. also clean out lint tray. this might help a little. Now lets check if the thermal sensor or heating element needs to be replaced.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button. To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the thermal sensor. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Feb 01, 2011 | Bosch Axxis WTL 5410 Electric Dryer
[06 road king] after starting the check eng.
Have you checked with HD to see if yours is part of the Fuel Pump recall?
Apr 13, 2010 | 2006 Harley Davidson FLHRI Road King
I have a Bosch WTL5410 dryer, which has no heat going to the otherwise functioning tumbler. Do you know where I could purchase another heating element and where I can get instructions regarding the...
Open front panel, remove heat exchanger and clean.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the switch. This is your reset button. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Mar 24, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Bosch wtmc3521 dryer will not heat. Runs, but no
There are two things that could be wrong with ur heater
1 your heating element is bad
2 your thermostat is bad
check those two things and it should be back in order
Nov 20, 2009 | Bosch Dryers
Bosch Axxis Condensation dryer not working
Try to vacuum clean inside the door contact breaker (female part). If you can remove the dust it should start working again.
Jun 08, 2009 | Bosch Axxis WTL 5400 Dryer
While runing the clean cycle on my 2 day old bosch hgs7282uc gas range, it came up beeping error code 120 after an hour or so of it running.
I PURCHACED A BOSCH HGS7282UC GAS RANGE 6 MOS AGO. THE DOOR WONT CLOSE TIGHTLY,THE HEAT ESCAPES AND HAS MENTED MY KNOBS ON THE STOVE
Apr 29, 2008 | Bosch Kitchen Ranges
Bosch nexxt 500 series dryer
I just had the same problem, motor runs but no heat. I had a fun time figuring out how take the front panel off, hint the rubber seal comes off easily. It looks like mine tripped the resettable over heat sensor. So far so good.
Jul 30, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryers Logo
121 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
