Canon PC20 exposure lamp replacement
What case covers need to be removed in order to replace the exposure lamp in the Canon copier PC20 ?
  • 318 Answers
Back cover,left cover,and top cover.In that order.(Left cover opens with 2 clips.)Remove the glass.And then you can replace the Lamp.
Posted on Oct 31, 2008
Error code h2
Pre-exposure lamp
Does the pre-exposure lamp turn on during copying operation?
Check the wiring from the DC driver PCB to the pre-exposure lamp; if normal, replace the pre-exposure lamp.
Nov 16, 2013 | Canon imageRUNNER 6020 Copier
How to replace exposure lamp canon ir8500
remove the covers to and the top glass to gain access to the lamp .
Ensure the A/c power supply is removed from the socket as at times the fuse / tripper may still be live . remove one end of the copper conector , gently slide the fused lamp out. Check the voltage with out replacing lamp, if the volatage reading is near about the lamp rating , replace lamp , if voltage is slightly higher ( 10 % ) it is ok as in many lamp circuits the supply is not a sine wave , but is a saw tooth wave.
Dec 21, 2012 | Office Equipment & Supplies
I have copier CANON PC981, when i copying theres an error coming out to displays says E2 followed by 20. and turns off automatically. how to fix this problem, thanks
Dear marlauris,
According to Canon this error is mainly due to faulty x-lamp, power supply, or exposure sensor.
As a technician I fixed this type of error by replacing exposure sensor in several similar cases. So replace exposure sensor it will solve your problem.If you have any difficulties to resolve this issue let me know.
Regards
Chandrashekhar
Aug 17, 2011 | Office Equipment & Supplies
Sir, my canon ir 400 machine shows an error code 803. how can i solve the my problem. give detailed information to my mail. thanking u.
the code 803is for faulty exposure lamp or fault in composite power supply(the power supply to exposure lamp is not sufficiant to operate the lamp).to remove exposure lamp, remove copyboard glass,remove back cover ,slide scanner in the line of rear exahaust fan at the right side of scanner, remove rear exahaust fan, remove lamp holder(one screw).slide out lamp on the rear side replace new one and reverse the whole process.
Jan 27, 2011 | Canon imageRUNNER 400S Copier
Hi i have a canon np2020 copier has code E221. the exposure lamp is not coming on . is there a way to check is the lamp is good with out replacing it .
There are a few possible problems? One is that the scanning lamp is blown or the thermal fuse for the lamp is blown. The question is will the scanning lamp turn "ON" and move and then codes out. If that is the case and most likely the power cable for the scanner lamp is cracked and it is shorting out to the frame of the copier. If you have a meter to measure resistance. You need to turn the copier off & unplug it & take the copy board glass off & put the meter on the ends of the lamp, to read it's resistance. If you have No resistance then the lamp is blown. You will need to replace it. Keep in mind you are working on a copier at least 15 - 20 years old, odds are the power cable is cracked. Good Luck.. If that is so, it is not a easy part to replace or find
Aug 13, 2010 | Office Equipment & Supplies
Hi sir ....... when the copier ( kyocerammita 5530
Optical system (AGC) problem
1. insufficient exposure lamp luminosity
2. defective engine pcb
3 incorrect shading position
4. defective CCD unit
check exposure lamp harness connections; adjust position of contact glass shading plate or clean/replace the scanner home position sensor; replace the exposure lamp or inverter pcb if needed; replace CCD unit or engine/main board if applicable
Jan 10, 2010 | Office Equipment & Supplies
My canon d320coping black no image. what is the
Hello sir; It seems like the exposure lamp burn out, lift up the cover and hit print , if it scan with on light means the exposure lamp out, replace it.
Dec 05, 2009 | Canon PC-920 Black and White Copier
My cannon ir400 eror e220
this error is related to exposure lamp , does the the two end of the lamp is blackened. Otherwise the exposure lamp needs replacement
Jul 20, 2009 | Canon imageRUNNER 2270 Copier
System halts while pulling the paper
Could be the problem of Exposure lamp .If the lamp end is blackened,it need replacement to get rid of this error(E 803)
Jul 16, 2009 | Canon ImageRUNNER 330s Copier
Black picture the lamp does't lit. no error message.
Hi sir;Try to make a copy with open cover ( check the exposure lamp is on), if exposure lamp not on andyou already replace a new one then check the thermos fuse at the end of the lamp, replace that one.
May 29, 2009 | Canon Office Equipment & Supplies
85 people viewed this question
jasbo
jasbo
