Question about GE Energy Star WCVH6260F Front Load Washer
How to Reset a GE top load Invensys washer timer?
Coins were getting stuck in the tray of the coin slide, so I opened the tray and realized that the actual timer was off track. Now when coins are placed in the coin slide they are deposited into the tray without the washer resetting to its correct 28 minute cycle. Instead it just eats the coins and robs you of washing your clothes. Any suggestions?
  • 725 Answers
Remove slide cover .. move the slide lever back untill it is on #1 or the lowest setting... hope it helps
Posted on Nov 17, 2008
Maytag 3000 series dryer, coins stuck in dryer fin
open the top of the dryer. slide the belt down to the power unit. of course you shoudl always unplug the unit first before removing the cover. carefully lift up ont he drum and they shoudl fall out. carefull y palce the drum back and the belt. replace the cover and plug in to see if that works.
Dec 04, 2009 | Televison & Video
Coins stuck in washer
I've used a butter knife or putty knife to pry them up.. just enough to allow the coins to slide back out. Just roll the drum back and forth with the knife wedged in there. Good Luck.
Jan 25, 2009 | Maytag Neptune MAH6700A Front Load Washer
I just bought a house that included in the sale a Maytag Coin-op Washer and Dryer. The coin box on each contains a key. How do I disable the need for putting coins in the washer and dryer so that I can...
  1. purchase a coin insert and blank the slot that coins fit in, then the slide will slid in without coins, just acting like a button, if you examine the slide you wil notice that there are plastic inserts in unused coin slots, any maytag commercial dealer has them.
  2. replace coin slide with 'free operation' converter, which is just a button plate that pushes the striker on the timer switch
  3. take top cover off and just push the striker on the timer, (this is NOT) a recommended option, 220v is enough to spoil you whole day)
Oct 24, 2008 | Maytag Washing Machines
Timer type
Give your parts distributer your model and serial number and they can get you the proper timer.
Oct 03, 2008 | GE WCCB1030 Top Load Washer
Machine not starting
These machines are owned by a company or your Landlord you will need to contact them for the repair on the Coin slide
Jan 28, 2008 | Maytag MAT12CS Top Load Washer
GE Washing Machine
It sounds like the pump may have something stuck in it take the front off and removed the hose's from the pump and check inside the pump for coins etc.. if not you may have to replace the pump I hope this helps.
Dec 21, 2007 | GE WBSR3140DW Top Load Washer
Coins in my front loader
remove element, remove coins with magnite telescopic type.replace element
Nov 06, 2007 | GE WSXH208A Front Load Washer
Coin stuck under tumbler on Duet front load washer
If you dont have screws on your tumbling vanes, you can take a very small screw driver and lightly lift the vain enough for the coins to slide out.
Oct 18, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Leep, open the hatch that the timer sits under. You will see the timer and actuator that the coin tray pushes to start the wash cycle. You can rotate this cam clockwise until it gets to it's home position, ususally right around the 12:00 position. Good luck
Jun 20, 2006 | Maytag MAT12CS Top Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
734 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
