http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
Engine cuts out at 3000 RPM?http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
High rpm in neutral? Inconsistant high RPM in neutral?http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Jetski Sputters and Low RPM? http://whatisbyme.blogspot.in/2012/07/jetski-sputters-and-low-rpm.html
Fuel Injection Problem And RPM suddenly increaseshttp://whatisbyme.blogspot.in/2012/07/fuel-injection-problem-and-rpm-suddenly.html
2005 Toyota Highlander: Engine runs hard RPM below 3000?http://whatisbyme.blogspot.in/2012/05/2005-toyota-highlander-engine-runs-hard.html
1987 Toyota Camry: RPM Drops going Up hills?http://whatisbyme.blogspot.in/2012/05/1987-toyota-camry-rpm-drops-going-up.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500 http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
1990 Toyota 4Runner: Engine cuts off when reaches 2000 RPM?
http://whatisbyme.blogspot.in/2012/05/1990-toyota-4runner-engine-cuts-off.html
1999 Toyota Camry: Erratic stalling and high engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
1995 Toyota LS: Misfire at idle or low RPMhttp://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Lexus RX: Tapping noise under Valve Cover At Low RPM?http://technoanswers.blogspot.in/2012/04/lexus-rx-tapping-noise-under-valve.html
These will help.
Thanks.
