Question about MB Quart RAA2400 Car Audio Amplifier
Power and speaker cables
I have the amp. Don't know if it works yet..no burned up parts that I can see.
Where can I get the Power cord and Speaker cables?
Thanks,
Bob
planetoons@aol.com
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 59 Answers
Most electronic stores carry these, radio shack, circuit city, best buy. One thing, when buying the power wire, make sure the guage is right for the wattage.. to small of a wire may hinder the performance of the amp.
Ciza
Posted on Oct 31, 2008
I have a power acoustik subwoofer, how do I know if the amp at the back of the round tube works the12" speaker wrks 500w voice coil 2, 89db low Q Driver. know it's for car's but I use it with tv spk
the shown photo is a bit confusing too me , clearly this is an automotive speaker , but in the photo there is clearly a home power cord shown , is this power cord connected anywhere on this speaker ? as if it is , id be afraid that amp has received home power and not car power , as the two are not the same and have tremendous differences and would be quite damaging to this amp possibly unrepairable damage
Feb 19, 2016 | Power Acoustik Car Audio & Video
Missing cord to speaker to speaker, what dose it look like?
According to the owner's manual, the 'speaker to speaker' cable is not removable. The speaker to computer cable is.
It's a 6' 3.5mm stereo to 3.5mm stereo cables such as this: http://www.walmart.com/ip/Link-Depot-AUDIO-6-35MM-Link-Depot-3.5mm-Male-to-Male-Audio-Cable-6/15779608
Apr 02, 2014 | Altec Lansing Speakers Acs43, Tested,...
I have been given a Technics system with tuner (st ch7l), cd (sl ch7), amp (su ch7) & tape deck (rs ch7) with 2 Bi wire speakers! But I have no ribbons or speaker connections! Can anyone tell me where...
What AJIN GOPAKUMAR says.
You can buy cables and speaker wire at Best Buy, Wal-Mart, Parts Express or Amazon. Even a "dollar store".
One thing to keep in mind - do not fall the hype of people who want to sell you very expensive cables because they will sound "better". $2-8 for a set of RCAs should do nicely.
You don't need Monster Cables or their even more expensive brothers. There are many cables that fit your needs. One example on Amazon is "Hosa Cable CRA202 Dual RCA To Dual RCA Cable - 6.5 Foot". Another is Parts Express's "RCA Patch Cable 6 ft. Gold Plated" for $1.80 plus shipping.
More expensive cables will not hurt anything. But they won't help anything in your set-up.
And keep them short, if you can, for neatness ... though long ones won't hurt anything.
Before you buy speaker cable do some measuring ... and add several feet. You will be just fine with lamp cord or zip cord from a hardware store. "Speaker cable" is the same thing with clear plastic covering, often color-coded. This can be helpful because the most important thing to know about wiring speakers is that the MUST be in-phase -- red to red and white-to-white, or plus-to-plus and minus-to-minus. THIS IS VERY IMPORTANT! Check and double check!.
Oct 24, 2012 | Audio Players & Recorders
I have a beringer sx3242fx, i need to know the best compatible amplifier to use my samson speaker that pushes up to 500 w
Almost any amplifier will work so there is no "best"... Just make sure the amp RMS rating is a bit below the RMS rating of the speaker for safety of the speaker. A QSC GX5 would be a candidate. You would use one side of it for each speaker if you have two, or use only one side for a single speaker. A lot of pro's seem to use these amps. USE BALANCED interconnections either XLR or TRS cables AND for sure power the amp and the mixer from the same receptacle... it often means running an extension cord like the pro's do to avoid ground bounce noise AND damage to the equipment.
Sep 02, 2011 | Behringer Sx3242fx Eurodesk 32-channel...
No low end from speaker. Sparks came out of backplate when switching the plug from jacks. Now the horns are only thing that works
If you failed to turn off the amp before changing speaker cables you have fried something. Since the plug shorts when unplugging, if the amplifier were on, the amp would sense the short and will often fry the amplifier or the speaker. You don't mention what the amplifier was. If the speaker were daisy chained to other equipment a ground loop probably formed and blew out the woofer. The horn often has Peavey's "SoundGard" circuit so it probably survived. NEVER change speaker cables while amp is on. ALWAYS secure the 1/4 inch type cables through the handle of cabinets so they can'tbe inadvertenly pulled out and burn up equipment. Your amplifier driving one of these should be rated at no more than 200 watts RMS. These "400 watt Prrogram" ratings are for the birds... fake advertising. Put 400 watts into this RMS and it blows out.
Aug 02, 2011 | Peavey PR15 400w PA Speakers
My Behringer Ultrabass BX600 has a very loud, constant hum. I tried a new power cord, and speaker along with checking the internal parts for a burn spot and tight fit to no avail.
It is likely the power amp chip has shorted. This puts the unregulated dc into the speaker and you will hear the hum. DO NOT operate this way as you can burn up the speaker. You will find that the LM3886 chip on the heatsink has failed. They are about $7.30 from Digikey. They come in two lead bent versions. Make sure to get the correct version and use heat sink grease wheen installing.
May 26, 2011 | Behringer Bx4500h Ultrabass 450w Bass...
I lost one of my speaker cords for my BOSTORN MICROMEDIA SYSTEM.The system has bass floor subwoffer, and two 3" X 3" soeajers,\r\nThe serial number iw EJ0102668 on the subwoofer,and the part# is...
You can order replacement speaker cables from Gateway Spares online.
These look like the appropriate cables:
8001844 - Gateway - Boston Acoustics Black Volume Control Speaker Cable
8001845 - Gateway - Boston Acoustics Micromedia Black Speaker Cable
8001846 - Gateway - Boston Acoustics Volume Control Speaker Cable
I hope that helps.
Mar 08, 2011 | Boston Acoustics BA735 Computer Speakers
I dont know how to set it up. I put the green cord in the computer..but theres one black cord and i dont know what to do with it.
There should be ONE stereo miniplug to be connected to the headphones output of the computer, and one power supply plug to be connected to the AC adapter. These speakers do need a power supply, since they have an internal amplifier.
Dec 26, 2009 | GE HO98010 Computer Speakers
Sony AMP/Subwoofer Problem
It is probably the tweeter, inside the Sub. it's the small ceramic disk between the cone magnet, and the speaker. id this thing is cracked or broken, this will cause the problem. if this is not it, then it is a problem with something in the wiring, and the only way to rectify it is to buy a new sub. Sorry due :(
Jan 26, 2008 | Audio Players & Recorders
Sub hook up to PPI D3000 amp
I'm not familiar with this amplifier but in most cases, if a mono amp has more than one positive speaker terminal and more than one negative speaker terminal, the positives are directly connected and the negatives are directly connected. So  as long as you connect the speaker positive to a positive speaker terminal of the amp and the speaker negative to a negative speaker terminal of the amp, it will work properly.
Oct 12, 2007 | PPI D3000/1 Car Audio Amplifier
MB Quart RAA2400 Car Audio Amplifier Logo
Top MB Quart Car Audio & Video Experts
xxxxxx xxx
Are you a MB Quart Car Audio and Video Expert? Answer questions, earn points and help others
