Home | Canon | LBP 800 Laser Printer | The printer takes all...
Canon LBP 800 Laser Printer
Problem for Canon LBP 800 Laser Printer
The printer takes all the papers in but prints on one how can i make it take one pagg at a time
By elijah on Sep 14, 2006
hi, every time i want to print i must feed the printer with one page at a time or it takes all the pages in and prints on one of them.how can i fix this problem?
Same Problem
Mar 14, 2008
-   my epson c66 printer will not print and it keeps pushing paper through. i replaced the ink cartridges and its just driving me crazy, what can i do.
-   Guest
Dec 27, 2007
-   When I print somthing, the toner heat increses .-   Guest
Dec 24, 2007
-   From the first day that I used the printer, I've had to load paper one at a time. This is tedious on time, but also because it leads to other problems such as the paper not loading correcting (i.e. paper jams) and then I spend more time trying to fix the problem the printing. I barely use the printer because of this problem. I appreciate the advice about the replacement rollers and how the cost of fixing them would be about the same as buying a new printer.-   Guest
Nov 15, 2007
-   After two years, my printer is taking in multiple sheets for printing instead of one at a time. I haven't tried to resolve the problem because I can't figure it out, so I must sit here and feed the printer one page at a time. At least it is still working, but it is tedious all the same to feed the printer each page! The solution offered on this site recommends to just buy a new printer...-   Behrens
Best Solution
posted on Apr 25, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I've heard that a little sanding the rollers with some course sandpaper sometimes gives them a little extra life...
Solution #2
posted on Sep 14, 2006
Helpful)
dugiehowsa
Rank: Wiz
Rating: 77%, 871 votes
Sounds like the rollers used to grab the paper are worn down.
According to this page that references replacable parts for that model, it doesn't look like the rollers are on the list:
http://www.dttservice.com/printers/canon...
It looks like with the price of the replacement parts anyways that it may be just cheaper to buy a new printer.
Was this helpful?
Yes
No
Solution #3
posted on Nov 02, 2007
Not Rated)
Kemo
Rank: Guru
Rating: 88%, 94 votes
Printers have feed rollers and separation rollers or separation pad.In your case, separation roller or pad is the problem.
Separation rollers separate sheets from each other.Clean it or replace it.
Was this helpful?
Yes
No
Solution #4
posted on Oct 10, 2007
Not Rated)
Cops
Rank: Wiz
Rating: 79%, 92 votes
you will need som of these rollers:
Paper feed Roller Ass'y
part No: RM1-0037-020
Paper Pick-Up Roller ass'y
Part No: RM1-0036-020
Google the part number and you should be able to find a local dealer of them
Was this helpful?
Yes
No
Solution #5
posted on Aug 07, 2007
Not Rated)
CanDo
Rank: Wiz
Rating: 81%, 172 votes
Take a soft cotton wiping rag with warm water and mild detergent and clean your printer surface areas well being careful not to break or damage any thing or get any electrical part wet just the surface areas where the paper feeds. After thoro cleaning carefully dry the same areas you clean with a dry cotton rag.
You should see a noticable difference next time you use your printer. Cleanliness is next to Godliness and Computers and Printers like it too.
Was this helpful?
Yes
No
Solution #6
posted on Jun 19, 2007
Not Rated)
n1wgk
Rank: Master
Rating: 94%, 74 votes
It's a pickup roller problem. You can try cleaning them with alcohol, realizing that eventually that process will dry out the rollers. The problem is the paper dust gets on the rollers and "clogs" them, making them slippery...or it could be the separation pad opposite the pickup rollers...I would clean that as well.
Was this helpful?
Yes
No
Solution #7
posted on Apr 29, 2007
Not Rated)
clynnm
Rank: Apprentice
Rating: 0%, 0 votes
I had this problem and I cleaned the rollers. It worked for quite a while after that. Worth the effort.
Was this helpful?
Yes
No
Solution #8
posted on Apr 16, 2007
Not Rated)
printerman
Rank: Wiz
Rating: 80%, 75 votes
clean the separator pad, just under the paper pickup rollers. Water and cloth. or a toothbrush soaked in water,.
Was this helpful?
Yes
No
Solution #9
posted on Mar 07, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I just took the back of the machine off by unscrewing five screws and that gave me access to the feed rollers.
I used isopropol alcohol and Q-tips to clean the rollers and the pads under the rollers.
This fixed my problem.
Popular Solutions for Canon LBP 800 Laser Printer
Questions and Unsolved Problems for Canon LBP 800 Laser Printer
Do you recommend Canon LBP 800 Laser Printer?
Answer
Answer
i want a printer driver for lbp 800 for window xp
Answer
the printer not print anithing(don t start to print on letter
Answer
Let our Experts solve your "i install my canon lbp 800 printer but it need windows logs how i... (More)
Answer
how can i make windows logs for printer lbp 800 in windows xp
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon LBP 800 Laser Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
