Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
D52w20b rca tv no power blinks 3 times
OK I pulled cap 150. It is slightly swelled at the top. 2200uf 16v tubular.
I've heard that the flyback is usually bad too. Any info you can give me would be appreciated. My e-mail: rickblue@verizon.net Thanks
I have the same problem, if you hear of anything let me know, or post it. AW
Posted on Nov 08, 2008
My TV will not stay on...the power comes on and off 3 times and then stay off.
Problem will be in the Deflection board,Located on the bottom left handside it will have FBT flyback Transfomer on it, check Capacitors CP150, CP120, CP114. If CP 150 is Swollen or vented on Top the replace all 3 caps.2200uf 16v use 25v, 220uf 35v.
You ship board for repair to PTS 1-800-844-7871
These sets are also known for having Bad FBT flyback Transfomers and alot of Poor Solder Connetions
Jul 01, 2011 | RCA HD52W59 HDTV Projection Television
I have a RCA 52 inch HDTV model D52W20B when you press the power button the green power light flash about 3 or 4 times and that's it no sound no video. Everytime it flashes you can hear I guess the power...
On Deflection board CK capacitors cp150 2200uf 16v if it is puffed up on top it is bad their is 2 more caps in same circuit replace them also cp114 cp120 220uf 35v also resolder all pins on FBT flyback Transfomer
Nov 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 gets power but won't turn on
Hi, thank you for visit fix ya.
Common problem on thi tv.
Capacitors on power supply bad.
Replace this:
2200uf 16V, 220uf 16V. Upgrade to 35V.
Located on power supply- deflection board.
(picture)a57b905.png Thank you
Jul 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA hd56w66
DO YOU STILL NEED HELP WITH YOUR TV IF SO ,I WILL TRY AND HELP! First ck capacitors cp150 cp114 cp120 2200uf 16v and 220uf 35v if 150 is puffed up on top replace all 3 capacitors also ck Ribbon connectors there is 2 of them thst conect deflection board to SSB board. resolder all pinns on FBT flyback transfomer.
May 28, 2009 | RCA HD56W66 56" HDTV
RCA D52W15 TAKES AWHILE FOR IT TO POWER ON THE GREEN LIGHT FOR
Ck 3 capacitors cp114,120,150, if any of them is puffed up on top replace all 3 2200uf 16v other 2 are 220uf 35v /resolder all pinns on Flyback Transfomer.
Feb 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power ligt blinks twice no high voltage
CK capacitors cp150 cp114 cp120 if cp150 is puffed up on top it is bad so replace all 3 caps.2200uf 16v and two 220uf 35v
Jan 16, 2009 | RCA D52W23 52" HDTV CRT TV
Capacitors
Sorry i am very sick with the Flu But the 3 caps you are looking for are on the deflection board which has the flyback on it Also all 3 caps will be green with gold writing cp 150 is 2200uf 16v use 25v the other 2 caps are neer by this one.
Nov 05, 2008 | RCA HD52W59 HDTV Projection Television
RCA big screen model# D52w20, Chassis# ITC222
Nine times out of 10 the problem is 3 capacitors cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v look at cp 150 if cap is bubbled up on top it is bad capacitors should be flat on top.
Oct 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
3 green blinks
Look on Deflection board cp 150 2200uf 16v capacitor and there is 2 more capacitors 220uf 35v replace both of them. Green and Gold writing on caps.
Sep 09, 2008 | RCA D52W19 52" Rear Projection Television
3 blinking lights after replacing CP150, CP110, Flyback, CL031, and (2) 10 Watt 1.5ohm 5% resisters.
Your right on these sets you have to replace all 3 capacitors 2200uf 16v and two 220uf 35v.
Aug 30, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
275 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
