Question about Casio Exilim Zoom EX-Z700 Digital Camera
Memory Card Just inserted 2GB card and the camera will only let me take 3 pictures and then indicates Memory Full -
  • 4 more comments
  • monchie35 Oct 31, 2008
    yes
    Home computer
    home computer
  • bilud vel Dec 07, 2008
    Camera is probably not reading the card but its internal memory. Therefore you can only take 3 pic due to its small capacity compared to the memory card.
    How-ever, resetting the camera to original factory settings does not solve this. Try to upload pics from card to computer via some method other than using camera cradle and its usb cable,
    and then format the memory card. (if you do not salvage the pics before the formatting of card -all is lost). After formatting the memory card things should be back to normal. Othervise there is something wrong with the camera itself.
  • Cee Jai Bernard
    Cee Jai Bernard May 11, 2010
    which one sorry.. the instructions will change depending on wether it's a mac or pc.
  • Cee Jai Bernard
    do you have a mac or PC as your home computer?
  • 849 Answers
Reformat the card
Posted on Oct 31, 2008
I have a sandisk 2gb will it automatically load my pictures from my phone onto the memory card that was already in my phone
The answer is NO. Do the following if you want to have all your pics on the memory card.
1. Insert the card into the phone.
2. From Menu slect the pictures that you want on the card.
3. Move them to the card. After that they will be deleted from the phones memory.
4. Configure your camera to save all pictures to this folder on the memory card for future.
Feb 08, 2011 | SanDisk 2GB microSD Memory Card
Display reads "images recorded in internal memory" but there are none and I can't take more than 4 pictures until the camera says the memory is full. Also the memory card says it is full after 7 pictures,...
hi, the memory card you are using is to small for the camera it has not got enough memory on it you need to get at least a 1gb memory card or 2gb memory this will then allow you to take between 500 and 1000 pictures the 16mb card you have in is not worth using it will only hold a couple of pictures so go to the well known auction site and buy a 2gb memory card of the same type such as sd card or micro sd or mini sd it should tell you on the 16mb card what type it is then just buy the same type but with either 1gb or 2gb or even 4gb of memory this will then let you take 1000s of pictures
the 16mb card is no good in your camera get a bigger card and your problem will be solved
let me know if you have any problems with the new card ok
Aug 15, 2010 | Fuji FinePix A800 Digital Camera
Memory card saying "full" when its not
Your problem is that you are using an incompatible type of memory card.
Your camera was designed to use SD cards with a maximum capacity of 2GB. It cannot use larger capacity models, and is also incompatible with the later SDHC cards.
SDHC cards are the same shape and will fit your camera, but have differences beneath the skin and so won't work properly in your camera. Without any memory card in place your camera uses internal memory; it's then only by lucky chance that your camera has sufficient SDHC compatibility to allow you to transfer the internal memory image to the SDHC card when you subsequently insert it into your camera.
Your only solutions are to either use an SD card with a maximum capacity of 2GB or to replace the camera with a later model which is fully SDHC compliant.
Apr 29, 2010 | Samsung Digimax D73 Digital Camera
I have a Z1015 IS kodak camera and inserted a 128 MB memory card in it. I shot 25 pictures when it told me the card was full. Yet I used the card on a kodak 135 camera and it took over 200 pictures. Am I...
Sounds like you have the picture quality on the Z camera set to a higher setting than on the 135. Higher Quality photos are much larger and will fill up a small 128MB card very quickly. Get a 2GB card.
Jan 02, 2010 | Kodak EasyShare Z1015 IS Digital Camera
I just got a kodak camera today for christmas. i took 3 pictures before the camera says "internal memory full" i know it cant be full because no one would sell you a camera that only takes 3 photos. does...
Hello. You need to buy a SD card to store your pictures on.This card slides into a slot on the side of the camera.You may have a 2GB limit check with Kodak or your manual before you buy anything larger.The 2GB card will store several hundred pics at 7 megapixil size.
Dec 26, 2009 | Kodak EasyShare Z710 Digital Camera
Does "memory card full" mean you have to purchase another for canon powershot sd750 or can you erase?
You can either erase the pictures or transfer them to a computer using the supplied USB cable or remove the flash memory and insert directly into the computer's sd card port.
Sep 08, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
2GB SD card is brand new but camera says it is full.
Some of the older cameras will not take the bigger cards. You can use the bigger card with your computer to store your photos.
Jun 03, 2009 | Kodak EasyShare C330 Digital Camera
Have blank 2GB card, camera tells me memory full. How do I get camera to accept the card and send the picture to it no the camera?
this camera takes only cards wich are formatted first on the camera.It will display an error message if you do not use a formated card.See your manual page 59
Apr 14, 2009 | Samsung NV7 OPS Digital Camera
New memory card
insert it again after resetting.
Sep 28, 2007 | Kodak EASYSHARE CW330 Digital Camera
"Memory card is full"
This error message indicates that there is no more space on the memory card in the camera. To resolve this problem, do one of the following: Turn off the camera and insert a new memory card. Transfer or delete pictures from the memory card. Change the storage location to use the internal memory.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Casio Exilim Zoom EX-Z700 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
