Here is the information that I found for you, if you need better instructions, you should probably contact your cell provider. However, this should be all you need:
To forward dial *72# ***-***-XXXX (the number you want to forward to) send.
To unforward *720# send.
After you dial, press send and you should hear two short beeps. You can then hang up and you should be set.
Thanks and good luck!!
EJ Kudelka
SOURCE: Call Forwarding
tell her to dial *72 followed by your home phone number then press send on your cell phone. she will hear a stuttering dial tone. the calls are now being forwarded. when you get ypur cell phone, press *73 then send to deactivate the call forwarding.
wg
SOURCE: blank screen on kyocera cell phone
mymomcallsme solution works, I had the problem, removed battery fer a while, viola! Screen is back.
Thanks mymomcallsme
SOURCE: My cell phone is not
If your plan allows forwarding these are the steps
to forward *72# XXX-XXX-XXXX (the number you want to forward to) send
to unforward *720# send
hope this helps
SOURCE: ihave a kyocera phantom cell phone i cant remember unlock code
go to nearest kyocera service center and unlock
SOURCE: how can i unlock my cell phone X-tc kyocera
I need help asap. Ok, i have my phone set to lock every time i power it up. But i kinda forgot my lock code. Does anyone know how to reset it?
Check your Voicemail
Just in case anyone still has difficulty in finding the instructions.....
Set Up your VoicemailBefore your phone can receive voicemail messages, you must set up a 4-10 digit passcode and record a personal voicemail greeting.When you have set up your voicemail, all unanswered calls to your phone are automatically transferred to voicemail, even if your phone is in use or turned off.1. Press and hold the 1 key.2. Follow the system prompts to create a password and record a greeting.
Best of luck!!
When you receive a voicemail message, a
notification with a voicemail message icon
appears at the top of your screen.
• At the voicemail notification, select Call to call
your voicemail number and follow the system
prompts to retrieve the message.
Select Ignore to clear the notification without
checking messages. The notification icon
remains on top of the screen until you listen to
the message
• When only the voicemail message icon
appears on top of the screen, select
Voicemailand follow the system prompts
