Question about Brother MFC-465CN InkJet Printer
Brother mfc 465cn printer
Is it possible to print black only? especially when one ink runs out and you only want to print black text page?
  • Anonymous Nov 13, 2008
    how to reset the printer? Or print Black only....?
  • townview Jan 16, 2009
    I haven't tried it yet but it sounds good. Probably the only liability will be that where the original has a colour text or diagram, this will not actually print. Nevermind, we mostly print black originals so no prob!
If you remove the empty cartridge, you will see a small window on the egde that plugs into the printer, in the center. This is where the printer optically scans for ink levels. On the empty color cart, you can try covering that raised spline with electrical tape or by coloring it with a black permanent marker. That should fool the sensor into thinking your ink is full.
Posted on Jan 03, 2009
I just installed new ink in my Brother MFC-465CN and the black will not print.
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Dec 16, 2010 | Brother MFC-465CN InkJet Printer
My brother printer model mfc 465cn, it has ink but the print its not coming out, dont know what to do
try cleaning the carriage assembly. the that the ink is installed at. then do the print alignment at the printer settings.
Jul 02, 2010 | Brother MFC-465CN InkJet Printer
My brother mfc 465CN wont print black only color
Have you tried cleaning the print head? Find the instructions in the troubleshooting and maintainance section of the manual here http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_465cn_EN_1269.PDF
Jun 04, 2010 | Brother MFC-465CN InkJet Printer
I have a Brother MFC 465CN and cannot get the black ink to print. I have cleaned it several times, and am quite irritated! If i print a page from my computer, the colours come out fine, but not the...
Another user here suggested that you change the Media Type in Printing Preferences to 'Inkjet Paper' instead of 'Plain Paper' and this worked for me. Of course I don't know if it's pulling from the black nozzle or not, but I do get black now.
Dec 26, 2009 | Brother MFC-465CN InkJet Printer
Brother Mfc-845cw and Mfc-465cn both stopped printing Black about the same time. Using Non brother Ink. Tried cleaning, replacing carts, unpluging maching. how can I fix this.
the black ink that was used in the refilled cartridges was probably to thick for the nozzels on the head, you can try buying the original cartridges and then cleaning again, or check with the store you got these cartridges from as some of them offer a warranty
Nov 20, 2009 | Brother MFC-465CN InkJet Printer
Black will not prtint. All the colors print fine on my Brother MFC 465CN. Have already: 1. Changed black ink cartridge 2. Reloaded printer driver Almost seems like some deeper issues where it...
GENERAL PRINTER TROUBLESHOOTING ADVISE:
Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. If the printer has a cleaning option either on the printer itself through the menu system or on the computer through the print driver, you can use that afterwards. Some printers will let you re-run the cleaning utility several times. Keep in mind too that some printers will not print, even with full ink, if the exact type of ink it expects you to have is not installed. Double check that the ink is correct against the manual or written instructions inside the printer. Not every cartridge that fits the printer necessarily works.
Nov 08, 2009 | Brother MFC-465CN InkJet Printer
Brother MFC-465CN won't prink cyan
You got to re-check back the Ink Cartridge you've buy recently.. Sometime the ink already freeze inside the cartridge bcoz its been really-really-really long time they keep before the usage.. Ive also have experience about problem like this b4, so better re-check/change back the cartridge.. Or If the
printer head is not at the cartridge, it is seperate from the cartridge, you have to check back the printer head also.. normally all the new printer head comes together with the cartridge.. and prefer to use the Original Cartridge more than Pirated Cartridge ok.. Cheap Cartridge always giv a lot of problem, especially like Your problem.. Thats All, Good Luck and Happy Trying..
DEAth-MaN88®
May 08, 2009 | Brother MFC-465CN InkJet Printer
Colour ink runs out and can't print b&w page
with all brother printers all the ink cartridges must be full or the printer will not print brother tech
Oct 27, 2008 | Brother MFC-465CN InkJet Printer
My Brother MFC-465CN is printing text with alignment off and double text.
My Brother printer MFC-465cn is doing the same thing. I have workaround / worked-around it by disabling bi-directional printing. Then print is clear. It's as if the head is shifting an irregular amount on the opposite direction, like the head is loose.
Same for copies. If I use the PC interface to make copies, I can set the copy printing to be mono-directional, then copies are clear.
Sep 05, 2008 | Brother MFC-465CN InkJet Printer
Brother MFC-465CN InkJet Printer Logo
571 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
