Question about Philips Car Audio & Video
I have a Philips DC508D stereo car radio made for Daewoo ( C. 1995 ) , and suddenly all FM radio seems locked with no output. Cannot change channels and cannot search or set channels. All AM radio is fine. Any idea of solution? The FM worked fine until a few weeks ago. Regards, Ian
  • 883 Answers
SOURCE: Sanyo Car stereo fm doesnt work
there is a broken solder joint on the board inside and the temperature effect is causing the minute flexation of the broken solder, acting as a bad switch.
Posted on Jun 05, 2007
SOURCE: VOIP321 is unregistered
I had a similar problem. I unregistered the main handset & then when I attempted to re-register it, I had the same issue (handset attempts the registration process & eventually fails). I tried everything including pressing the "Reset" button on the back of the basestation & downloading firmware version 1.0.4.80 (started with 1.0.4.50). Turns out I had to press & hold the "Page" button on the basestation while the handset is attempting the registration process.
This info is in the manual. I know, I should have read the manual first. But at least I'm not alone; the guy at Philips told me to return the product because it must be defective.
It appears that the registration process is a security process/exchange between the basestation & handset. I'm not certain how standard this process is (i.e., whether differing manufactures utilize the same security protocols). If not, it is likely that other manufacturers' handsets cannot talk to the basestation. I mention this because you said you registered the main handset multiple times, so it sounds like you are familiar with the registration process.
Nevertheless, this might help others who decide to spend their weekend pressing the "reg" button a bzillion times, watching it fail as many times, & looking for answers on
Posted on Dec 23, 2007
leethedeuce
  • 4472 Answers
SOURCE: I have recently fitted a
check the ground.
Thanks,
Lee
Posted on Jun 30, 2008
SOURCE: I own a 1995 Nissan
Buy a new one!
Posted on Jul 10, 2008
SOURCE: Help
do u like ur head unit (Pioneer DEH3700MP) , cuz i bought mine @ a car show for $40.00
Posted on Jul 12, 2008
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
Indash am/fm cd cassette player keeps spitting out cd's
Your CD may not be music CD. Some car radio doesn't accept MP3 or WMV files. Change it to a good radio such as JVC car radio.
Aug 22, 2014 | JVC AM FM CD DET FACE CAR STEREO
My Philips AJ3980 radio suddenly has no sound. Also, the band "MW" appears in the display and I'm unable to tune AM stations. The clock seems okay. Thanks for your help!
1. Press the RADIO button to switch on the radio.
- Radio touch screen controls appears throughout
radio operation
- The radio frequency and waveband appears in the
display for 10 seconds before reverting back to the
clock display.
2. Press the BAND button to select your waveband FM/AM.
3. Tune to your station manually or automatically
by using up / down.
Here is a figure to help find the control buttons:
Please change waveband to FM.
Thanks.
gylacz
Jun 20, 2011 | Philips AJ3980 Clock Radio
It seems as my stereo is locked up. I can't
Your question is lacking some detail , is this a stock radio , after market , and what brand and model . Pictures can help , depending on the siuation code be s radio key is needed or if it's after market do you have a remote ? Try to change stuff with that , could be buttons inop or worst case it's just done. Good luck
Aug 31, 2017 | Alpine CDA-9884 Car CD/ MP3 Player
Receiving AM & FM stations but NO AUDIO OUTPUT
Please post the make and model number of your radio to help us help you.
The more information you provide, the more specific and accurate our solutions can be.
Apr 15, 2010 | Audio Players & Recorders
Can't change channel of a Motorola Visar Handie-Talkie FM Radio Model: H05RDD9AA4DN It seems that this radio operates in only one channel and I need to be able to chanmge channels. However everything else...
The Visar has a channel lock feature. If you hold down the two channel buttons at the same time, it will do one of two things depending on the settings. Either the channel will lock, or the channel numbers in the LCD will flip.
If you press the channel button and the "popples" "pop" (for lack of a better word) then the channel selection buttons re most likely OK. To fix it you just press both channel buttons at the same time for about 5 seconds. It will beep and you should be able to change the channels. If not, then it needs to be repaired.
Sep 17, 2009 | Motorola Radio Communications
Cannot play ipod in 99 daewoo lanos
instead of pressing the left/right scanning buttons hold them and then let go when you want to stop
Aug 15, 2009 | Daewoo Lanos 1999 Car Radio/stereo...
Playing video audio through car stereo Toyota Matrix
You're probably gonna need a wired FM modulator. That part will take an audio output and run it into your antenna plug on your radio. It will use a FM channel, but it's wired directly to your stereo. So no static as found with wireless FM transmitters.
Jan 20, 2009 | Audiovox AVD300T Car DVD Player
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Philips SAA7130 TV Tuner
Driver you have is not compatible! try to down load a newest version!!! and look on sound manager if mute is off
Jan 21, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Car Audio & Video Logo
52 people viewed this question
Top Philips Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Philips Car Audio and Video Expert? Answer questions, earn points and help others
