Question about LG Flatron F700P 17" CRT Monitor
Green-Amber-Amber Code? Hi, My LG Flatron F700p doesn't start. The light indicator is amber if there is no signal as usual. If there is video from the computer the light start blinking in pattern green-amber-amber, green-amber-amber, ... over and over again for several minutes and then goes amber - I think it's an error code - right?. The monitor doesn't even try to go on. Can I identify the problem by this error code? Any suggestions? Thanks in advance
I know that my post is very belated, but I think, will be helpfull for someone henceforth...
First of all, there is one "chronic" problem with LG monitors: solders. Check soldering of Video Amplifier IC303, Flyback Transformer, Q833( ! 210V) , deflection coils socket, Vertical IC601, XTAL X401 and so on...
In Your case, probably the cause of "green, amber, amber" lights is lack of 15V on the Verical Amplifier IC601. DPMS is activated, and monitor does not work at all, even power off.
Replacing Q912 (2SA1273) solve the problem. I replaced him with 2SA1680 PNP 1A 900mW 60V, and all is OK.
This problem is fundamental for ALL 17'' Flatron monitors, repaired by me (over 30).
Wish Happy Repairing!
Best regards, Ico.
Posted on Jan 12, 2008
    President:
  • 2,022 Answers
Check your vga data cable is properly conected or not and also chek the keybord status by pressing the nuk lock key see the led is on an and off when you pressing the num lock key if it is not changing there is problem in cpu. bye
Posted on Sep 25, 2007
Dell poweredge t110 server Amber error light on front panel blink one time
Had the same thing happen to me today and in my case it was a code 18 as they come...
It started while I was installing a video card adapter for a dual monitor setup. The solution - I had to simply close the side panel I had left open for testing and then reboot the server. The intrusion alarm went off.
Feb 02, 2012 | Dell PowerEdge T110 Server (GB/2GB)...
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
The on/off of pc monitor (LCD) is blinking.
Most LCD monitor (depends on the brand) power indicator light will either turn from Green to Amber, or flashing Amber, or flashing green, when it does not detect video signal feeding it. So it may be normal with your monitor. Are you haivng problem with the display? If it displays he pictue OK then there is nothing to worry about.
Apr 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Charging the battery the amber light comes on, but then after a while the amber light flashes. Does this mean the battery is charged? It used to turn to green with the battery that came with my...
if it turns green that means that it is charged, but it then if it turns amber that means that it is going bad
thanks
hope this works for you
Aug 27, 2008 | Acer Computers & Internet
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Monitor Acer Problem
I agree it isn?t the monitor but I would suspect the video card you are connecting it to or the PC itself. Generally if a monitor doesn?t detect a video signal it will go into hibernation mode, typically displaying a no signal warning and changing the LED color from green to amber. When you start the computer is anything displaying at all? Are you sure the PC is powering up and booting?
Jul 22, 2007 | Acer AL1916W 19" LCD Monitor
Flatron LG monitor safe mode
Your monitor goes to Power Saving Mode when the signal it is receiving is not correct. In all probability this is not a problem of the monitor itself, rather you should check the connections and the computer the monitor it's connected to. For example you could try a different RGB cable and try it in a different computer.
Apr 13, 2007 | LG Flatron L1951S 19" LCD Flat Panel...
LG Flatron F700P 17" CRT Monitor Logo
574 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
