Just bought this off a guy didnt have the remote and it turns on and the radio works and it plays cds but the screen will not come out .. i press the open/close button and it beeps twice and thats all it dose i can see the screen light up inside but thats all it dose
SOURCE: I HAVE PANASONIC CQ-C700U STEREO PLAYS ON ALL
are you running the rest of your speakers off an amp? if so, it sounds like you have the amp remote wire connected to the power antenna wire. on some radios there is an amp remote wire and a power antenna wire. the power antenna wire loses power when not listening to the tuner (radio). usuall there is a solid blue and a blue with white stripe. the blue with a white stripe should be amp turn on.
Testimonial: "YOU GUYS ARE RIGHT ON! THANKS FOR YOUR HELP IT WAS GREAT >"
SOURCE: Panasonic cq-c8303u Car stereo problem
There is for sure a hook up problem my friend. There should be a memory wire that always has power to it even when the car or the ignition is off. Then there is a switched type wire that only comes on when the cars ignition is on. Check both of these wires in the car. Check the car wiring diagram to confirm this. To confirm the wiring in this vehicle, I Good Luck with this install. And if all else fails, don't take a chance and blow out the unit, take it to a pro to be installed. Good Luck found the right wiring diagram for your car. Confirm this wiring diagram with this one you have. Go here:http://www.the12volt.com/installbay/stereodetail/955.html
SOURCE: panasonic CQ-VD7001U no sound
YOU WILL NEED THE REMOTE CONTROL BECAUSE YOUR RADIO HAS A SECURITY CODE. WHEN YOU GET THE REMOTE CONTROL THIS IS WHAT YOU NEED TO DO: TURN ON YOUR RADIO WITH THE REMOTE CONTROL AND THE SCREEN WILL REQUEST THE SECURITY CODE,YOU JUST NEED TO PUSH AND HOLD FOR ABOUT 15 SEC THE SKIP>> BUTTON ON THE RADIO;THAT WILL CLEAR THE CODE
You need the remote control that goes with this DVD player to make it work it has two security devices. One you remote, you must push the power button on the remote the first time you use it. Two the security code, it is a four digit code that must be entered anytime that the device is installed into a different car. If it's code is not setup yet the code is 0000, otherwise you need to get the code from the person that installed it. There is no way to bypass the these two steps.
