Horizontal Lines scrolling on screen
I have an Optoma EP719 projector that was just cleaned (very dusty) and bulb replaced. However now I have another issue. When running the projector from my cable box, there are scrolling horizontal lines constantly. Any suggestions what this could be and possible fix? Thanks!
I had a similar issue with my Mitsubishi HD 1080. My power supply went out, I had it replaced and it works like new. However, just today I had AT&T U-Verse installed. When the cable guy was showing me the new HD channels all seemed good. This evening (about 5 hours after being installed) I started seeing these horizontal lines across my screen. The picture was still HD quality, but those annoying lines just wouldn't go away. Anyway, after reading a few blogs on-line suggesting interference or bad grounding, it hit me!!! The AT&T guy who installed my U-Verse (cable, internet and phone) had set the modem on top of my TV!!! It was just starring at me this whole time. So I removed the modem off the top of my TV and put it on a side table just to see what would happen and sure enough the lines were gone!!! You may not have the exact same problem, but it may be some type of interference (cell phone, modem, etc, either on top or around your TV that is causing the issue... Hope this helps. Thanks.
Posted on Nov 21, 2008
Optoma EP719 Projector "Pulse"
It is one of the fan, it is bent or out of place and cause reptead disturbance at cyclic intervals. The projector must be taken apart and examined on the inside
Jul 22, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
I have an Optima Model EP719 Projector. Suddenly I am getting white vertical lines and can't find a solution for removing them.
I would try switching out the DVI cable first. It could be faulty. This would be the easiest and cheapest solution to check.
Jun 09, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma EP719 settings?Colorwheel? Bulb?? Cable?
take the lamp out and shake the projector gently and tilt it in all directions and listen for something loose near the front of the projector. if you hear something it could be the light tunnel has collasped or the colowheel has lost its segments.
May 21, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma EP719 projector broken circular glass disk
The piece that's cracked is called a color wheel. I spoke with the parts department at optoma and they want $300 for a new color wheel for my ep 732h projector. I'm not sure if it's the same part but you can contact optoma on their website and they'll get back to you with a price quote for that part.
Jan 16, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
I have the Optoma ep719 and it will not power on. I plug it in the power light flashes. When you hit the power, the fans will come on and the bulb will light up for about 2 sec. Then it will go back to the...
some dry out, and you can't tell by looking at them. see if the colorwheel is spinning. if it chirps before it shuts down, or if it doesn't spin at all, replace it. otherwise replace the ballast.
Oct 27, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
My projector optoma ep719 has a blue screen went turn on with or without cumputer hook up
please check the signal and the display properties as per SVGA or XGA resolution
Jul 16, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma EP719 Projector Won't Power Back On
When you first replaced the bulb it went back on and then later it did not. Most projectors have a safety switch that it is activated upon the bulbs cover placed. Once the cover is removed it activates the switch and shuts down power to bulb. It sounds based on your remarks, that this switch may have intermitten problems. I would suggest, locate this switch and verify its operation. Or, make sure the bulb cover is placed and/or secured properly.
Feb 18, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Televison & Video Logo
305 people viewed this question
Top Televison & Video Experts
