Question about Motorola Mobility RAZR V3
Unwanted caller can you type in a # or code to block a # from calling a rasr phone?
    Problem Solver:
  • 10 Answers
The best thing for you to do since the phone per se does not "block" calls is simply to make sure that this person's name is NOT in your phonebook memory, and then restrict calls to where those who are NOT in your phonebook will not ring through - unfortunately the calls will still be able to ring through to your voicemail though.
Posted on Jan 04, 2009
Wish to stop unwanted calls
That can be difficult, since even if the phone itself or your carrier has call blocking capabilities, most of the nuisance callers have many different numbers that they can use to call from, and will simply change to another one if you block one. The best solution is to have Caller ID, and any call that blocks their number, or any number that you don't recognize or expect a call from, simply don't answer it. That is the most effective way to stop the calls from coming, since they will usually move on if they receive no response.
Dec 18, 2015 | Uniden D1680-2 Expandable DECT 6.0...
Tip
How do I Block a Caller on my Android Phone
<p>Here we discuss how an Android phone callers to block. These steps can be useful where you want unwanted calls directly instead of manually reject the call blocking. Follow these simple steps to block a caller making a call to the phone. Please note that the various steps may be other manufacturers like Samsung and Sony Ericsson and HTC. But the base should be almost identical. <br /> <p><br /> <p>Option 1 Steps <br /> <p>1. On the All Apps menu, click Blocked callers<br /> <p><br /> <p><span> </span>2. Click Add caller.<br /> <p><br /> <p><span> </span>3. Select from people (which are your on phone book) or just add the caller (if you remember the number).<br /> <p><br /> <p><span> </span>4. If you like people, click Save to finish.<br /> <p><br /> <p>5. If you add the caller number, click ok to finish.<br /> <p><br /> <p>Option 2 Steps <br /> <p><span> </span>1. All applications menu, click Find People. <br /> <p><br /> <p><span> </span>2. Select the caller wishes to block. <br /> <p><br /> <p><span> </span>3. Calling on the Block, "switching to. <br /> <p><br /> <p><span> </span>4. Click OK to close the. <br /> <p><br /> <p>This "Blocked Caller" function can be disabled, as shown <br /> <p><span> </span>1. All applications menu, click people blocked. <br /> <p><br /> <p><span> </span>2. Select the caller that you want to release. <br /> <p><br /> <p><span> </span>3. About Block caller, change On Off. <br /> <p><br /> <p><span> </span>4. Click OK to close. <br />
on Aug 18, 2011 | Google Android
Block unwanted calls
yes, in phone number recall area. number history. find number you want to block hit settings then add to reject list.
Jan 30, 2014 | Samsung Galaxy GT-S5570
How can block a number and texts from unwanted caller
Hi
PUK code is called as PERSONNAL UNBLOCKING KEY.
Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.
To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider.
While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK code
DONOT enter the PUK code several times wrongly,It will block your sim card permanently.
This PUK code is FREE. You no need to pay any sum to get the PUK code
Thank You.
Jan 27, 2013 | Nokia E63 Cell Phone
How to block unwanted number
  1. The first thing you can do is to make sure your cell phone number is unlisted. This is a simple step but it's the first step in keeping unwanted calls from your cell phone.
  2. You can unmask the Caller ID on blocked incoming calls, obtain the phone number, and in some cases the name and address, of the "anonymous caller" by using a service called "TrapCall." You can also listen to your voicemail over the internet.
    TrapCall allows you to unmask numbers, record your calls, voicemail transcriptions, block unwanted callers, and gives you caller id for your cell phone. See resource link.
  3. Register your number with the "National and State Do Not Call Lists." The National Do Not Call list is run by the Federal Trade Commission and you can sign up online at the resource link below.
  4. Even after signing up for the "Don't Call List" and getting that unpublished number there are still those times when the telemarketer finds a way to get through. You can also get unwanted calls from ex-boyfriends and ex-girlfriends'. These people have your number from your previous relationship. You don't want to change your number, but a few over-zealous ex-mates may not go down without a fight and will continue to call after you have told them to stop! In this case, you'll need a call blocking device. These devices allow you to control who calls you, and gives you the ability to permanently block their numbers. See the resource link at bottom of article for a list of these devices.
  5. Set up an account with "Reverse Phone Detective" service in order to find out the Unknown numbers that appear on your caller display. This will allow you to see who and where the number is coming from. Check the resource link "Reverse Phone Detective" below.
Don't rely on your cell phone provider to block unwanted calls for you. For some inexplicable reason, most carriers do not provide you with the ability to block unwanted callers.
My best bet is to go with the google voice number(you can do a lot of things besides blocking unwanted numbers and its free) ..
here is the link to find more information about it
https://www.google.com/accounts/ServiceLogin?service=grandcentral&passive=1209600&continue=https://www.google.com/voice&followup=https://www.google.com/voice<mpl=open
May 12, 2011 | Nokia C3 Cell Phone
How can i block a number on a nokia 6500c my service provider can not is there any other way for blocking unwanted calls
The 6500c does not support conditional call forwarding (CCF) which is useful if your carrier does not provide blocking services. I have owned several nokia, a samsung, two LG, and currently have a blackberry 9330. If unwanted calls are a serious problem, consider upgradeing to a mobile phone that supports CCF. Conditional call forwarding can be used to forward any unwanted phone number includeing calls from unlisted, unknown or restricted callers. Depending on where you live, the call can be instantly forwarded to a service, such as trapcall.com, that unmasks the caller in addtion to providing the standard message "This number is no longer in service" for example.
Apr 25, 2011 | Nokia Cell Phones
How do I block calls on my wildcard phone?
Until now, it has been difficult, if not impossible, to block selected phone numbers from ringing your phone. Various features that are offered by some telephone service providers have provided limited relief, at a cost, but until the introduction of the Caller ID Manager, a total solution was not available.
With the Caller ID Manager, you can easily block phone numbers and anonymous callers without added monthly fees. You can now block phone calls from any number that you choose, including local, long distance, international and cell phone callers. A 'Wildcard' feature is included for those who wish to block calls from entire area codes, prefixes, or number sets. You also have the option to block phone calls during specified hours, either on a one-time or daily basis, using the built-in scheduler.
Nov 14, 2009 | Kyocera wild card Cellular Phone
Black list for nokia N73
i have Smartphoneware Best Blacklist v2.01 to block you unwanted call Automatically rejects unwanted callers. Real-time incoming
number analysis and instant reject. Easy to configure and
use. Your phone will be always busy for unwelcome calls! sent your email i will sent you thx
Sep 15, 2009 | Nokia N73 Cellular Phone
Block Numbers
CallFirewall - a freeware smartphone app
Whitelist, only callers and/or sms from list
Blacklist, no callers and/or sms from list
Accept only from contact list
Reject All Calls
Reject all calls beginning with ### (i.e. an area code or provider like everything beginning with 800)
Reject and send the rejected callers an sms message
May 12, 2008 | Samsung BlackJack Smartphone
Motorola Mobility RAZR V3 Logo
71 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
