Question about Compaq iPAQ H3955 Pocket PC
Hard reset does not wok in my ipaq H3955
Hello, I got an ipaq H3955 haven't used it for a while and battery was completely dead and when i charge it back it will not show the normal screen display, the only thing shows in screen is "align screen" tapping doesn't work, i tried hard reset and nothing happen. Please help...anyone can help would be greatly apreciated. Thanks, Karen
  • lukero Apr 01, 2008
  • Compaq Master
  • 13,433 Answers
The touchscreen may be broken, try hardreset again if it doesn't help contact your dealer or HP for possible repairs.
Posted on May 19, 2008
I can't make my IPAQ pass the align screen
Replaced LCD touch screen in Australia.  Cost $95.00 AUS Thanks for Fixya help you where really great.
Feb 12, 2009 | Compaq iPAQ H3955 Pocket PC
Will not start up after recharging the battery
Hello :-) I think that your battery is causing the problem. You might have charged you ipaq to many times with a cheap battery and the battery might be completely dead. Or the battery might just be defective.
Apr 12, 2008 | HP iPAQ H2210 Pocket PC
Full Reset
You need to press buttons 1 + 4 + Reset until the screen turn off, after that wait for 60 seconds and press the reset button again. remember that hard reset erase everything from your ipaq like personal information, programs that you installed, etc.
Xracer
Dec 05, 2007 | Compaq iPAQ H3955 Pocket PC
Ipaq h5555
I battery dead ? In some case, ipaq battery dead will not start. ================
Aug 05, 2007 | HP iPAQ H5555 Pocket PC
IPaq rx3115
I had a similar experience. My device would not charge via the usb charger so I connected it to my wall charger and it charged successfully.
Jul 07, 2007 | HP iPAQ RX3115 Pocket PC
Cannot power on...
How to correct iPAQ 5450, 5455, 5550, 5555 battery charging problems / dead unit syndrome.
The iPAQ 54xx or 55xx will not power on if the batteries charge is lower than 3.2 Volts, if your battery charge falls below the 3.2 volts level your unit will not turn on, you need to plug the iPAQ into a cradle or AC charge adaptor. Note the charging light on the iPAQ will not flash at all (normally flashes orange) until the battery charge has reached a minimum charge level of 3.2 volts. You then need to perform a normal reset, then the unit should switch on normally.
HP Procedure is as follows:
To charge and reset the iPAQ Pocket PC h5400:
i) Connect the iPAQ Pocket PC h5400 to an A/C power supply.
ii) Charge the battery to the minimum level of 3.2 Volts. This will take 5 to 30 minutes depending on the current charge level.
iii) Perform a normal reset.
iv) Power on the iPAQ Pocket PC h5400
It is recommended that you keep the iPAQ Pocket PC connected to the Universal Cradle or Cable when it is not in use.
Apr 30, 2007 | HP iPAQ HX4700 Pocket PC
Charging
If it's completely dead USB probably can't do it at all. There's a voltage threshhold, and USB only puts out about half the voltage needed to get over it. USB usually won't manage when thenbattery's below 30%. Try connecting the iPaq directly to the AC adapter.
Sep 11, 2005 | HP iPAQ RX3115 Pocket PC
My iPAQ will not charge or turn on ...
Can you get the iPaq hooked up directly to AC power? There's apparently a charging threshhold for badly depleted batteries that the USB port cannot get over.
Sep 08, 2005 | HP iPAQ H5555 Pocket PC
Compaq iPAQ H3955 Pocket PC Logo
235 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
