Question about SanDisk Sansa E280 MP3 Player
Player is stuck in a given mode
I plugged my player into the computer to recharge it. Initially I did this without first pressing menu. I then got a message that it was connected but it didn't recharge. I then unplugged it pressed menu changed some settings and it got stuck in a given mode (Radio Options - Delete all Presets) and no amount of pressing or turning anything will unstick it. What to do?
  • Anonymous Nov 14, 2008
    player is stuck in a given mode problem completly freezez up and goes back to the on screen not the menu
  • eljo Nov 14, 2008
    After I requested help I managed to find my installation disc and that was what they suggested - I tried it and it worked.
    Thank you very much.
Did you hold the power button for 15 seconds until the unit resets?
Posted on Nov 08, 2008
I have a ml638b digital media player, video and music, and i think i accidently deleted the firmware, it does not turn on, but wen plugged into a computer it works fine, how do i fix it?
The gpx ML638B has 2 modes while plugged into the computer. 1 as a usb mass storage, the other i believe was called an mtx device. these modes are switched by pressing the "mode" button on the side while connected to the PC. try switching between the 2 modes and browsing the drive letter it is assigned to to find and delete songs individually.
when all else fails you can always select from settings menu to format which will delete everything. and or you can use the master reset button using a pin or paper clip in the back of it.
As for only turning on when it is connected to the PC. then most likely your internal rechargable battery isnt charged enough yet or has bit the dust. try lleaving it plugged up for a few hours to charge fully through the usb connection.
Aug 04, 2010 | GPX MW3826 MP3 Player
Delete all current content from sansa E-250 mpc
follw the given steps-
  1. Check to see that the player is in MSC mode by going to the USB mode section in the "Settings" menu.
  2. Plug the SanDisk Sansa MP3 player into your computer.
  3. Click on the "Start" menu.
  4. Click on "My Computer."
  5. You will now see a drive for the device and one for the SD card.
  6. Double click on the "Sansa device."
  7. Select the music file you wish to delete.
  8. Press "Delete" on your keyboard.
    Thanks,
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Nov 18, 2009 | SanDisk Sansa e250 MP3 Player
Stuck ipos in disk mode
Plug it into the computer, and in the ipod's main screen, uncheck the box that says allow disk mode. Hope this works!
Aug 31, 2009 | Apple iPod nano 3rd Generation
My iPod 160 GB Classic is stuck with just Apple logo on screen. Initially, my MacBook recognised my iPod but now it won't even recognise it. It won't restore it and message suggested I need to use updated...
Try forcing the iPod into disc mode to restore.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
If this does not make the iPod connect to your computer, I would suggest checking out www.rapidrepair.com for further ideas and options to your issue.
Jun 22, 2009 | Apple iPod classic MP3 Player
My 30g ipod is stuck in the restore mode. i follow the instructions on how to restore it, and everytime i plug it into the computer, it says it needs to be restored. how do i get it out of the restore...
Try this out: And let me know the status
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
Then try restoring the ipod using Itunes...
Feb 23, 2009 | Apple iPod MA446LL/A MP3 Player
Recovery Mode
Hi! I think you should try this (i've already tried it and it works):
1- Unplug your Zen from your Computer.
2-Turn off your Zen (if you can't do it, press the "Reset" button)
3- BEFORE turning on your Zen, press your "Play" button and hold it while you turn on.
4-When a format menu appears, select the "Format All" option (you'll loose all your Zen data).
5-When the format menu reapears, select the "Reboot" option and listo! You have your Zen as new and should not have problem. Good luck!
Aug 16, 2008 | Creative Labs ZEN V Plus MP3 Player
Sansa Clip Stuck in FM mode - Won't go into music menu
Press the little button that looks like a house to go back to main menu
Aug 13, 2008 | SanDisk Sansa Clip MP3 Player
YP-T9J Screen stuck on transferring files do not disconnect
Vegggie Boy is mistaken. You should press and hold the red record button while pressing the menu button. The player will reset itself to normal operational mode.
Jun 14, 2008 | Samsung YP-T8 Digital Media Player
Craig Mp4 player problems
keep it on for a few days intil it turns off then plug it hold play button then press menu then it should work
Dec 31, 2007 | Audio Players & Recorders
Sansa e140 just need some help with menus
When you power on your MP3 player it will go to the FM radio. 1. Press menu.
2. Go down once and you'll be on "Mode". Press the right button to access the mode menu.
3. You either press the enter button after accessing the menu or go down to select Playback mode (I forget which one it is).
Good Luck!
Dec 26, 2007 | SanDisk Sansa e140 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
95 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
