Question about RCA D61W130 61" Rear Projection Television
Tv turns off after a few minutes
My tv turns off after a few minutes of use
  • LGILLMAN Nov 25, 2008
    TURNS OFF WHILE WATCHING THEN THE GREEN LIGHT WILL GO ON AND OFF AS IF IS TRYING TO POWER ON AGAIN.SOMETIMES IT WILL COME BACK ON SOMETIMES NOT. ANY SUGGESTIONS?
  • Anonymous Dec 11, 2008
    Mine is the 52" model and does the exact same thing. Won't go more than ten minutes without shutting itself off. Only way to get it on again is to unplug it to reset itself. However it is basically unwatchable, since it keeps shutting itself off.
I had the same problem with my D61W130. It would turn off and on intermittently. Called a TV repair shop and they said this model was known for it's poor soldering connections on the power board. They came out and took it apart and re-soldered the board. It cost me almost $300 bucks but it seems to have taken care of the problem. It's working great now.
Posted on Feb 20, 2009
Tv goes on and off a few times then turns off
Thats a common symptom which is usually caused by the Small signal board. You can get a replacement small signal board from www.tvrepairworld.com
Jul 16, 2010 | RCA HD52W66 Projection Television
I have a KP65Wv700 Sony Tv it turns red after a few minutes of watching tv. I turn the tv off and on so see a few minutes of normal colors but start gettinmg red again any ideas
I'm afraid, its RED Picture tube problem that will be replaced.
It is qualified tech job to replace picture tube in rear projection TV because there are few adjustments required after replacement.
Please call local tech for fix tv.
Thanks.
Dec 14, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Tv screen goes gray after a few minutes
SOUNDS LIKE MAIN BOARD/BUT IT COULD BE CONTROL BOARD/REPAIR SHOP
Dec 04, 2009 | LG 37LC2D Television
When I turn my TV on it plays just fine for about 10 minutes. Then it goes to black and white. If I turn it off for a few minutes and then turn it back on, the color returns for a few minutes and them goes...
The tube harnesses may be a little loose and when tube warms they short. Try adjusting the wiring harnesses. (Only attempt to do so if you have electronics knowledge.)
Nov 20, 2009 | Philips Magnavox 27MS343S 27" TV
Just replaced lamp a week ago and tv worked fine
2 things will cause this Lamp is defective, or Fan to lamp quits running this will shut TV OFF, if the fan quits running while Lamp is on it is design to shut Lamp Off to prevent Damage to Lamp IF Fans are ok It will be the Ballast board It is what turns Lamp on.Look on E-Bay for Ballast board if it turns out thats what you need or call Encompasss Electronics 1-800-638-3328
Sep 19, 2009 | Toshiba 62HM95 62" DLP HDTV
Tv turns on then turns off with no picture
What make and model set do you have?
Feb 14, 2008 | Televison & Video
TV shuts off after few minutes
tap it on its side then try to turn it on and see if it stays on if it does bad solder connections
Aug 11, 2006 | Sanyo DS31520 31" TV
RCA D61W130 61" Rear Projection Television Logo
453 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
