Question about GE WBSR3140DW Top Load Washer
Timer broken I need help taking the knob apart to try and fix it that way.
    President:
  • GE Master
  • 2,651 Answers
Usually a timer knob lock located on the back of the timer itself, youll need to pull a small post out to unluck trhe knob and then it will pull right out reverse for installing new
Posted on Oct 31, 2008
Can't start washer the knob that you pull to it won't come out.
Dear Jill.
I fix washers, and it sounds like a couple things may be the reason for your problem.
1) The timer itself may be broken, and need replacement. Or,
2) The ears on the timer body may have broken off, preventing the timer knob from working.
(Remember, there are "a hundred" different kinds of washing machines, so it is really good to identify your machine completely whenever you ask for help.)
I have had several washers recently that were broken with the symptoms yours has.
The timer body (inside the control panel) is plastic.
Because someone was rough with it, or because the plastic got old and became more breakable, the ears break off easily.
The plastic ears are what hold the timer in position so the knob will work in-and-out correctly.
God bless your efforts.
Feb 16, 2017 | Washing Machines
Why can't I hear the timer ticking?
The timer, if it's the mechanical type that you have to push in the knob to select cycles, then pull out to start, is *not* repairable. From what you are describing, it sounds like the internal mechanism had broken and the timer needs to be replaced. There is a specific, small procedure for removing the dial and replacing it on the new timer--if you are unsure on how to do this, get a qualified tech to do it--otherwise you run the real risk of breaking the mechanism in the new timer. I hope I helped you!
Aug 10, 2015 | GE Washing Machines
I pulled the knob off and turning the shaft with pliars, but now the shaft is broken too. How can you by-pass the shaft to make the dryer start? Shall I open the pannel?
First all unplug dryer the shaft to timer is broken their no need to try an jump out timer you might in up just short dryer motors are some other parts .you need a new timer .go to your local appliance part store an buy a new one oh make sure you take the model.number in with. You ok.
Feb 19, 2015 | GE Dryers
Im replacing the timer on a whirlpool washer . how does the knob come off?
Quick and easy... I'm guessing you've already got the control panel taken apart so you can see the back of the timer. Just take out the black piece that holds the timer and knob together and attach the new timer replacing the wire mount and black knob
Apr 08, 2009 | Whirlpool LSR5132PQ Top Load Washer
Dash Control Unit Replacement
You can save a LOT of money by fixing it yourself.
All that is wrong with the knob are broken wires from the knob's PC board to the main PC board on the AC control.
All you have to do is remove the AC main control, take it apart, and resolder the broken wires from the PC board with the knob on it, to the main AC pc board. There are 3 wires, any number could be broken.
If you take it apart and solder the broken wires, this WILL fix your issue. Just make sure you put the wires back exactly where they go.
A FIXYA rating (4 blue diamonds) would be most appreciated for my assistance.
Mar 21, 2009 | 2002 Toyota Highlander
I need to replace the timer on a series 800 washer
Fix the timer on the washer so that it fills with the correct amount of water, and so there is the correct amount of time for each cycle. Make sure the washer is unplugged and take off the control knobs and the panel that lays over the knobs. The knobs could be either at the front or back of the machine. Check the wires that link the timer to other areas of the washer. If they are slack, push them further into place with pliers.
Change the timer by disconnecting the old one. Make sure the new timer is made for the brand of washer that you own. Unhook the wires to the old timer one at a time and connect each wire to the new timer.
Mar 02, 2009 | Kenmore 23822 Top Load Washer
Timer Switch
Same problem with Black & Decker CTO6160 toaster oven. Same switch. Must be they're all Chinese garbage.
Dec 28, 2008 | Euro-Pro TO160L 1380 Watts Toaster Oven...
Timer switch on GE washer
You don't state your exact model number, and the number off the timer is not the actual part number (it's some sort of part stamping number). Most likely what has happened is a plastic tab on the timer housing (which normally goes into a slot in the metal, and thus holds the timer at that point) has broken off. The fix is to replace the timer, but instead of buying a new timer, I usually fashion a Z type piece of metal which I can put one screw though into the metal and the other side holding the timer against the metal. Takes a little work, but it's a lot cheaper than a new timer.
If you want to take the timer knob off, you have to pull it out and use a thin tool, like a small screwdriver, to push the plastic clip off the shaft behind the knob, allowing the knob to then come off the shaft. Push the clip back on the knob when off, so that all you have to do to reinstall the knob is push it on and it will lock on the shaft again.
Dec 08, 2008 | GE WBSR3140DW Top Load Washer
Whirlpool ultimate care ll washer
on the back of the timer is a black plastic tab, you have to pull out on this tab in order to remove the knob. in other words you have to take apart the control panel to get to the timer just to take off the knob. :I
Jun 23, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Mid cycle stop
the thermostats need replacing thers 3 of them you can get to them from the front its better to take the door skin off first so you can see better then take the lower panel off.the thermostats are on the right hand side underneath.
Feb 12, 2008 | Asko D1716 Built-in Dishwasher
GE WBSR3140DW Top Load Washer Logo
95 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
