Intake Air Temperature Senor problem. How to fix recurring problem?
SOURCE: oil come out the air cleaner
Too much crankcase pressure or the breather pipe is split/dosconnected. The crankcase breather goes into the rear of the air filter and the crankcase gasses are drawn in to the cylinder with the gas/air mixture and burned
SOURCE: what type of motor oil used in 1994 harley davidson 883
harley recomends that you use their oil but i would be carefull because it is a cynthetic now if you were using regular oil what that will do is clean all the old build up out of the motor this can be bad because after time there are pin hole leaks that occure but the build up stops it from leaking but if you use cynthetic you cant go back to regular oil it will gum up on you and ruen your motor so you got to find out what has been put in it. but use a 10-30
SOURCE: removing harley davidson ultra classic gas tank
Drain the fuel either by siphening or removing the cross over tube at the front of the tank and letting it drain that way or just block off those cross over lines and leave the fule in the tank for removal.
0) remove seat
1) drain fuel
2) undo cross over line (bottom front of gas tank.
3) shut off pet **** and remove fuel line from pet ****.
4)there should only be 2 bolts holding the tank on, one at the top front of the tank and one at the back of the tank.
All in all a pretty easy (but possibloy messy) job.
SOURCE: my 2000 harley davidson motorcycle wont hold a charge
Get access to the battery terminal posts, star the bike and set the meter to "Volts DC". Touch the leads to the positive and negative posts and see what the meter reads. If the voltage is between 13-15 volts then the bike is charging, if thats the case the bike is charging but your battery is hooped. Start with that and if the bike isnt charging then write back again for trouble shooting instructions.
