Question about Kenmore Elite 45986 Front Load Washer
Water trickles into Kenmore front load while machine is off and door is open
After finishing laundry on Sunday, I left the washing machine door open to try to prevent a recurrence of that horrible odor that sometimes permeates a load of laundry. Late Tuesday night, I traced the water leaking from the ceiling of our garage up into the second floor laundry room where I discovered the bottom of the washing machine tub was full of water and a small stream was trickling out of the open door. Water had puddled on the floor and was making its way down through the first floor ceiling. I turned the water valves off at the wall, ran the drain cycle and unplugged the machine. Now what? Any ideas on why water would be entering the machine even though the machine was off and the door was open (unlatched)? The only thing I've done differently lately is cleaning the rim under the rubber boot after running a long, hot bleach cycle without clothes in hopes of mitigating the odor problem. The washing machine is a Kenmore Elite HE 3t (110-44921-300) purchased in 2004.
  • 1 more comment
  • wyldkattz Oct 31, 2008
    Thank you for your quick response. We'll be checking the water inlet valve this weekend to see if replacing it is a DIY project for us or not. I'll let you know how it turns out (with a rating later). Thanks again for your response.
  • wyldkattz Dec 03, 2008
    That was it! Thank you very much for your excellent advice. We replaced the water inlet valve and have not had a recurrence of the leak. Once you identified the problem for us (and even gave us the part number), we were able to repair this problem ourselves. Thanks again!
  • CrazySan Dec 05, 2008
    I have the same problem... However I turned the water off to it last week and it still is leaking... Is it still the water inlet valve??
    President:
  • Kenmore Master
  • 2,651 Answers
Sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Posted on Oct 31, 2008
Door stuck closed after wash is done
If the water in the machine is above a certain level a fail safe on the door lock will not allow it to be opened. Check the filter, make sure the machine has completely drained. Obviously, there may be a problem with the lock itself but try this first.
All the best
Mar 20, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore washer, model c45092
in all cycle with seven min left washer, m-c45092 stop and door open no spin cycle. pete.
Apr 19, 2010 | Kenmore 45081 Front Load Washer / Dryer
Washer Glass window in front load door glass is broken.
they should replace it. sounds like problem with unit.proberly only replace door . good luck with it.
Apr 08, 2010 | Kenmore Front Load Washer
Front Load Washing Machine Filling On It's Own
the inlet valves are shot. what happens the coils in the inlet vales can no longer hold the water from going into the unit, causing water to run into unit when not in use. replace the inlet valves and you should be good to go. the inlet valves can be removed by, removing top panel(3screws in back), disconnecting hoses, taking the small clamp on the small hose connected to the dispenser. theirs a small screw holding the inlet valves from back pane, remove old inlet valves and replace and you should be all set. hope it helps.
Apr 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Laundry smells like mildew after washing
Front load washers retain water that you cant see or get to. There are cleaners for washing machines available. I clean mine every month with alot of bleach , try pouring a half gallon of bleach in the soap insert on a normal wash cycle and an extra rinse would not hurt no clothes of course.
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Mildew
all front loads all brands have same issue with mold people today tend to use less bleach CHLORINE BLEACH that is ..allow machine to fill with hot water normal wash pour 2 cups CHLORINE BLEACH in water allow to wash a few min to mix open door and with cloth wash inside of door gasket be sure to roll gasket back and wash underneath lip allow to finish complete cycle should remove most of mold try to this every few months..also leave door open between use to allow moisture to dry out as much as possible like i said YOU ARE NOT ALONE
Jun 27, 2008 | Kenmore Elite 45986 Front Load Washer
Asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
Mar 06, 2008 | Asko W6021 Front Load Washer
Leaking door at the bottom
the vacuum which is to be created between the door and the tub must be not working......try cleaning the door ..some unwanted things may be blocking this to happen
Jan 02, 2008 | Whirlpool LHW0050PQ Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
469 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
