Wiring connection diagram for emerson electric motor
I need a wiring connection diagram for an Emerson #S63CXSJA-4114, 1 hp,  120/230 volt, 3450 rpm.  The terminals are marked 1, 2, 3, 4.   Is this motor reversable through wiring changes ?  Also, what changes do I make to changefrom 120v to 230v ?
5 Suggested Answers
Just_Bobz
  • 448 Answers
SOURCE: need wiring diagram
If you're not a licensed HVAC tech......no you don't
Posted on Feb 21, 2009
SOURCE: Wiring Diagram for a Emerson Motor in a Tempstar Central A/C
EMERSON 1/4 HP MOTOR 5 WIRES BLACK BLUE BROWN WHITE RED LOST MY DIAGRAM 115V1075 RPM 3 SPD HOW DO I WIRE IT TO THE COMPRESSOR
Posted on Jun 08, 2010
james3751
  • 614 Answers
SOURCE: i have a dayton 1 1/2 h.p electric motor, and need
Line is L1 L2 L3 to line voltage. wire nut 4-7 together wirenut 5-7 together and wirenut 6-9 together connect 123 to line for low voltage 123 together 456 together 679 together. This works on all dual voltage 3 phase motors. Some of the newer Daytom motors have a plug that you just turn for changing voltage. Rudty
Posted on Jun 07, 2009
jumptrout51
  • 3361 Answers
SOURCE: need a wiring diagram for emerson k55hweym 3739
green is ground. white is common. blue and orange are hi speed/low speed. brown goes to the capacitor.
Both motors should have the wire diagram on the side of the motor.
Posted on Jul 04, 2009
  • 41 Answers
SOURCE: fan motor replacement
with the model number the supplier shoud be able to tell you what you need but some sell universal variable speed motors with long shafts so trim to fit might come in to play
Posted on Nov 21, 2009
Me again the motor have 2 capacitors 1 for stating and the other for running the stating capacitor is faulty and cannot se the data need help thanks
take it to a motor repair/ rewind shop with the motor details ( volts , watts , amps cycles etc and the shop will be able to match it
Jan 09, 2017 | Heating & Cooling
Rheem wiring diagram model RPKA-025JAZ
Contact Rheem directly to request the wiring diagram
Jan 07, 2017 | Heating & Cooling
Replaced ac unit with new compressor. Fires up as usual but compressor wont start.No fault code coming on controller. Whats the problem?
possible causes include
excessive gas
low gas
relay not working,
faulty thermostat
faulty start/run capacitor
bad circuit board
Jan 03, 2017 | Heating & Cooling
Johnson Starley boiler main board fuse blowing
Chances are the fuse on the circuit board is for control circuit protection. Take note of the location of all the thermostat connections on the circuit board and remove them. Do this with the power OFF. Replace the fuse and re establish power. If the fuse did not blow, the problem is in the wiring to or from the thermostat. It could even have the insulation rubbed through and making contact with the side of the boiler or a mouse could have chewed through the insulation causing a short to a metal object.
Once the issue with the thermostat wiring is resolved, reinstall the low voltage connections and you should be good to go.
Jan 08, 2015 | Heating & Cooling
White Rogers digital thermostat displayed "lo".
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. After replacing the battery you need to do the reset operation. If you need further assistance please contact us at 1800-284-2925.
Sep 24, 2012 | Heating & Cooling
Heating & Cooling Logo
2,603 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
