Question about Indesit 24 in. IDL700 Built-In Dishwasher
Fault codes Our machine looks and sounds like it's going to do a full wash then it stops after about a minute and flashes the 1st and 3rd green LED's on and off. Any idea's ??
Could be blocked filter according to instruction book for IDL 730
Posted on Feb 22, 2007
My indesit washing machine WI121 is taking several hours to complete a wash cycle on quick wash which should take 30 minutes
Reading the error code
The fault on the appliance is signalled via:
1. the continuous rotation of the selector knob
2. the action, for the first 4', of the electrovalve and the drain pump
3. the door becomes unlocked
4. the led flashes:
the number of flashes indicates the fault code; the code should be read as follows:
· each fast flash (2/3 flashes of the led very close together) represents one code value
· the fault code is evaluated by counting the number of flashes occurring at 3/4" intervals from one another
· stop counting when the washing machine waits the equivalent of approximately 8/9" between flashes
· the procedure is repeated by the appliance cyclically
Dado
Sep 14, 2015 | Indesit Washing Machines
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
LG dishwasher error code after 2 minutes
fault with the programe as it has stoped in mid cycle
Aug 01, 2012 | Whirlpool Dishwashers
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Washing machine fills and washes properly then when emptying machine stops then starts does not rinse properly no problems when filling only emptying does not do full cycle beaps constantly with 3 lights...
Hi just read your posting.Now when the machine is beeping the lights that are lit will be in a row of 8 lights,Starting from the left to right which lights are lit when the machine is beeping,Is it the 1st and 5th or the 3rd and 7th ---etc---?Please reply with the additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 08, 2010 | Fisher and Paykel Washing Machines
My Aquasmart WL80T65D washing machine, stopped during a spin cycle and started beeping every second with a red spanner light flashing. I followed the manuals instructions to turn the machine off for a...
Hi just read your fault.Now from the information in your posting the lights that are on when the machine is beeping are the 3,4 and 8th lights.Now these lights are in a row of 8 lights and you started from the left.So from left to right the lights that are lit when the machine is beeping are 3,4,and 8.Is this correct?If it is correct then the fault on your machine is called COLD VALVE FAULT.The 3 reasons why this fault occurs is, 1st the wiring to the water valves is faulty,the 2nd is the cold water valve is faulty, or 3rd the control module is faulty.Have you or can you borrow an electrical test meter so I can help you narrow down which is causing the fault.Please reply with additional information on the questions and I can help you rectify this fault.Looking forward to your reply.
Oct 04, 2010 | Fisher Paykel EcoSmart GWL15
Machine stops and the following lights (in UPPER CASE) are lit with a beeps sound: Green, Green, GREEN, Green, GREEN, Orange, ORANGE, RED
Hi just read your posting.Now when the machine stops and beeps a series of lights will light up.They will be in a row of 8 lights.Starting from the left to right which lights are lit when the machine stops and beeps,Is it the 1st and 4th or the 3rd and 6th ---etc---?Also please supply the model number of your machine which is on a sticker on the back of your machine, top left.Looking forward to your reply.
Sep 26, 2010 | Fisher and Paykel Washing Machines
The washing machine fills with water but then appears like it struggles to spin and then it stops attempting to spin, then starts to beep and flash lights. the lights that flash are the middle green...
Hi just read your posting.Now the lights that are flashing are an ERROR CODE .On the row of 8 lights that these lights are flashing which ones are flashing,starting from the left to right of the row is it the 2nd and 3rd and 8th or the 1st and 4th and 7th ---etc---?Please reply with additional information and I can help you rectify this fault.Looking forward to your reply.
Jul 30, 2010 | Fisher and Paykel Washing Machines
Model GW611 the first and second last led flashes. fills up and wont go into wash cycle
If by first led you mean green to the left & amber to the right then that is fault code (130) & i think it is (Rotor Position Sensor) If you meant first to the right that would be red & green, code 65.no that doesn't sound right.its 130 & im sure thats rotor sensor.
May 25, 2010 | Fisher and Paykel Washing Machines
Indesit 24 in. IDL700 Built-In Dishwasher Logo
394 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
